#267 |
Drives: 2015 FR-S Release Series 1.0
Anyone know the spring rates for the ST Sport springs?
http://www.revworksinc.com/ST-Suspen...-S_p_1045.html |
#268 |
Drives: Honda Accord Euro
Eibach's springs drop is wrong, Pro kit is 25/20 mm and there are 2 versions US/Euro of their rates
#269 |
Drives: 2016 HyperBlue BRZ
Front Sway Bar
I'm new to getting technical with my car. I need to upgrade my front sway bar on my 2016 HyperBlue BRZ and want to know what manufacturers are best? i don't want to spend a ton, but I also don't want to go cheap. I've heard Strano and Eibach, but are there others that are better for the twins?
#270 | |
This is from another thread:
#271 | |
I do like them quite a bit, but for that application there are other options that would suit you better. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | rx3 (10-23-2015) |
#272 | |
If you're only using slicks, you'll want to look higher up the food chain. Why look at (relatively) low end coilovers, when you're using top shelf tires? PM me if you'd like to consult on your build and figure out what would suit your build and skill level better. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | rx3 (10-24-2015) |
#273 |
Drives: 2014 GT86
That understeer balance biasing .. is that from square spring rate by chance? IIRC rates in rear should differ from front due motion ratio. But then again several coilovers released for toyobaru have square stiffness for springs, including supposedly good/quality ones. I wonder why such choice, what pros & cons versus staggered rates as per OE? If pros outweight cons, then why staggered choice for OE? Don't know what to think, maybe you can enlighten me?
#274 | |
1. Different drivers may prefer a different balance OR different applications (autocross vs. track) may have different needs. 2. Spring rates are not the only variables that control balance. 3. OE is very bumpstop active, so the OE spring rates should be taken with that in mind because it makes a large difference. In general, with cars using lower spring rates of around 7 kg/mm and below we (RCE) often stick with even spring rates. When we go firmer than that, we start thinking about firmer rear spring rates. But either way, we are always flexible with driver preference and the rest of the set-up. That's just us. ![]() - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Scargod (01-30-2022) |
#275 | |
I did ask around what the people I'm racing against are running and they appear to be always higher than 10k despite our bumpy courses (unfortunately hardly anyone is running a GT-86/BRZ). Even a small light Citroën Saxo is running 12k on the front axle. For lack of a better example (I know it's a much heavier car), this stock M4 is running 15k on the front axle and he's usually also winning at the slalom events. [ame="https://www.youtube.com/watch?v=Q7ptqZ3TMVI&t=8m55s"]Amazing BMW M4 Coupé from Swiss Hillclimb Champion Albin Mächler! with Full-Onboard - YouTube[/ame] Apparently a stiff suspension does work. On the other hand I was able to win slaloms on the almost stock suspension with racing slicks against Honda Integras DC2 on KW competition coil-overs. (Occasionally I dealt with some tire roll over and I had to turn the tires inside out because they wore quickly on the outside shoulder. But, it did work). The reason I found the Öhlins appealing, is because there are not many parameters one can tinker around with but I think they might be too softly sprung and for road legality reasons my choices appear to be limited to: Öhlins, KW (only clubsport and competition), Tein and Intrax. We have 14 slaloms each year (each on a different course and each slalom consists of only 2 practice and 2 race runs) and we only have one practice day to set the car up. So any coil over which offers a lot of knobs/options for fine tuning purposes is overkill to my mind. |
#276 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#277 |
Thanks. I'm not saying that higher spring rates are needed. Maybe this car would do fine with 6k square. I'm just wondering why the rest appear to be running much higher spring rates.
I think Sachs performance would come with the necessary paperwork, but as far as I can tell they don't come with camber plates and those I definitely need. (I do need a coil-over kit which does come with camber plates and the paper work with it, which is why the KW V3 as an example is not an option). |
#278 |
Drives: 2014 GT86
Different people have different driving habbits/patterns. Different coilover manufacturers target different niches. There is no 'best' spring rate that will fit best everyone. For some best is 3K, for some 6K, for some - 12K. Some use toyobaru as track-only car, some daily drive it only + have to listen opinion of comfort of significant other, some mix DD & few track days. To each his own, and what is best and who are those 'some' with opinions depends on threads you visit for info
#279 | |
Anyway, a lot of the off the shelf coilovers are geared towards a road & track compromise set-up. The Ohlins are one of the best of those types of "easy" set-ups...but may not be ideal for you if you want something a little more hardcore. To get something truly track focused, it's best to look beyond the easy off the shelf stuff and talk to someone about a customized set-up. Over here stateside we have a few companies (like ourselves with our custom KWs) that have some track focused coilovers with "default" rates, but we encourage a conversation so we can customize things for each user. CSG I believe is the same with their higher end Teins. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#280 |
Drives: Intereted in 86 but now got G37
Do you guys have interest in Taiwan OEM coilovers? thank you!
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 03:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 12:52 PM |
