Old 04-18-2014, 12:01 PM   #673
chimmy
Because BOXER
chimmy's Avatar
Drives: Asphalt FR-S
Originally Posted by OURO3OROS View Post
There isn't a horizontal adjuster, is there?
There is. I believe its the screw thats practically crammed up in the fender area. Either use a small 8mm rachet or usea flat head through an opening on top of headlight. Either way, its irritating.
chimmy is offline   Reply With Quote
Old 04-18-2014, 12:02 PM   #674
Msnicoleeeee
Msnicoleeeee's Avatar
Drives: Firestorm FRS
Originally Posted by Fett4Real View Post
You were able to put them on but cant align them yourself?
I mean theres literally 2 bolts that u use to align them...one moves left and right one moves up and down...
Sorry, I didn't make myself clear enough. I had them installed by a shop.
If I had known there were 2 bolts, I would've done it myself, but I'm the furthest thing from a mechanic so I have a shop to do it for me. Thanks.
Msnicoleeeee is offline   Reply With Quote
Old 04-18-2014, 04:42 PM   #675
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Ahhh and they didnt aim them? Id take it back to them and have them finish the job they started
Fett4Real is offline   Reply With Quote
Old 04-18-2014, 04:43 PM   #676
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Fett is correct
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-20-2014, 09:42 AM   #677
Msnicoleeeee
Did anyone have a problem with their Winjets having a gap? Pics will show what I'm talking about.. This is my left headlight. You can see the wiring in pic 2. Right side is fine though.. I'm not sure what to do so if anyone has any suggestions on how to fix it, it'd be great!
Or is that how it's supposed to be?
Old 04-20-2014, 10:22 PM   #678
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
The gap is normal that red and black wire has a bit of slack - it can be fixed by opening up the back and pulling the slack towards the back cover
86SPEED is offline   Reply With Quote
Old 04-21-2014, 11:10 PM   #679
GT/86
I LOVE YOUR GT86
GT/86's Avatar
Drives: 2017 BRZ with PP 1982 Datsun210
I'm planing on getting this winjet headlights but
I'm not sure of the LED are they bright enough ?
GT/86 is offline   Reply With Quote
Old 04-21-2014, 11:11 PM   #680
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Bright enough for what? I have them wired to the fuse box and they're pretty bright....
Sent from my SCH-I545 using Tapatalk
Old 07-18-2014, 06:20 AM   #681
Mad1723
Mad1723's Avatar
Question: Does anyone have issues with reflection of the silver trim around the projector? I have the annoying light reflection outside of the normal output on both far sides of the car. It seems to be coming from the silver trim around the projector.
The problem is worst since installing my Diode Dynamics HID kit.
Edit: To make matters worse, I realised why my kit had a shitty output.. The Diode Dynamics kit comes with H11 bulbs, Winjets use H7 bulbs. Welp, new HID kit will be required.
Mad1723 is offline   Reply With Quote
Old 07-18-2014, 08:14 AM   #682
tonystewart
Install Morimoto D2S 3.0 Projectors
Old 07-18-2014, 09:14 AM   #683
Mad1723
Mad1723's Avatar
Yeaaaaaah, not yet. Don't want to remove the whole headlights to do a retrofit. Not yet anyway. I'll just switch my H11 HID to my fog lights and buy an H7 kit.
I'll see if the H7 bulb fixes the Halo problem, I'm suspecting it's due to the wrong bulb being installed now.
Old 07-26-2015, 03:36 AM   #684
Holyshiba
Drives: 2013 FRS
Originally Posted by 2beFrank View Post
Well.... I'm kinda salty now
Dun worry it's k
Holyshiba is offline   Reply With Quote
Old 10-19-2015, 05:14 PM   #685
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Has anyone taken apart the black winjet headlights to paint the little bit of chrome around the projector black? Haven't seen it anywhere yet and considering a pair.
Instagram: trevor.parque
Old 10-23-2015, 03:57 AM   #686
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
http://www.ft86club.com/forums/showthread.php?t=63266
That's exactly what this person did and he did it quite well I might add, while you're in there it would be awesome to do a full retrofit, and drl mod as well
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 01:26 PM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 12:42 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
