Drives: 4-Runner Sport - 13' BRZ SportTech
Rod Swap
Does anyone have experience swapping rods on an FA20?
My spare motor has a bent rod, and I'm finally getting around to having time to be able to swap it out. I remember reading that it was designed in such a way that you didn't need to split the block to replace a connecting rod. Can anyone with experience confirm this? I'm assuming you go in through the oil pan, remove the front chain cover, and then the bottom portion of the block? Help and insight is appreicated
Top Tier Imports - Check out my build journal HERE
#2 |
Drives: Late 2014 Subaru BRZ
I don't think you'll be able to remove the wristpin without pulling the head too. But ya flip it over on your motor stand and remove the oil pan and timing cover.
I would crack the case open and check all the main bearings though. Who knows what the shape of them are and it's not worth all that trouble to skip not cracking the case to save time. You might find yourself removing the engine because of something else. Bearing kits are cheap.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
| The Following User Says Thank You to GsxrMe For This Useful Post: | protpibe (10-21-2015) |
#3 |
While you are in there take a look at the oil galleries and such.
http://www.ft86club.com/forums/showt...40#post2425140
| The Following User Says Thank You to Tcoat For This Useful Post: | protpibe (10-21-2015) |
#4 |
101 refresher (in case ya need it) ......
http://www.revvolution.com/blog/2014...he-fa20-4u-gse humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | protpibe (10-21-2015) |
#5 |
Resident Gear Head
You have to pull the heads the rods and Pistons come out the sides. This not like an EJ block with wristpin access holes.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | protpibe (10-21-2015) |
#6 |
Thanks for the info guys.
God there's a lot of sealant on these motors lol.
#7 | |
I'm ready to tear into mine just to clean out all that shit. Not joking.
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| 2JZ Swap Kit? | Moe23 | Engine Swaps | 37 | 10-27-2016 07:04 PM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 11:14 AM |
| BRZ Swap!!!! | EnviedIke | Engine Swaps | 59 | 07-30-2014 06:32 PM |
| 2jz swap | p3raltaboi | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 06-11-2014 08:09 PM |
