Old 09-02-2015, 07:38 PM   #547
slim blanco
slim blanco's Avatar
Drives: 2017 86
no rings and no problems here. just star pattern the lugs like you're supposed to and you'll be fine.
slim blanco is offline   Reply With Quote
Old 09-02-2015, 10:50 PM   #548
N234
N234's Avatar
Drives:
Hub rings are by no means necessary.
They are convenient for the person who swaps your wheels.
They do not carry any load once the lug nuts are torqued to spec.
They support the wheel in place while you hand-place the lug nuts.
-Nat
N234 is offline   Reply With Quote
Old 09-12-2015, 02:03 AM   #549
Astroboy
Astroboy's Avatar
Drives: None
Would a 225/45/17 mpss be fine on these wheels? Or is it a bit stretched?
Astroboy is offline   Reply With Quote
Old 09-12-2015, 09:37 AM   #550
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Too stretched IMHO
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Astroboy (09-12-2015)
Old 09-12-2015, 09:38 AM   #551
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by drewbot View Post
Too stretched IMHO
That's what I figured
Sent from my LG-D850 using Tapatalk
Old 10-05-2015, 01:20 AM   #552
ravisraval
Drives: 2013 FRS
Is there a groupbuy for these in black? Can't find one.
ravisraval is offline   Reply With Quote
Old 10-06-2015, 08:03 AM   #553
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
What's the driving feel like with such huge tires and wide rims? I feel like this setup looks amazing, but i'm worried that it will make the car feel heavy in regards to handling. True or false?
I'm just comparing, cause i wanted these in the SBC but they only make them in larger sizes, while i wanted more like 17x7.5 cause they are light and i can use 215/45/17 tires.
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 10-06-2015, 09:58 AM   #554
df.dima
Drives: FR-S and Mazda 3 Sky
Here is a nice post I saw a few days ago, this pretty much answers your question:
http://www.ft86club.com/forums/showp...74&postcount=8
Not sure I can categorically agree with all yet
#1 for sure, I pretty much went up by +1L/100kms when I switched to wider setup. Partly because more fun, partly just physics.
#2 can not confirm, with the nameless axle back, I dont notice any difference in noise
#3 Slightly, feels that way. I think this can be influenced by your alignment too.
#4 Have yet to see
#5 Did not notice any difference in ride quality. I actually think because of the rubber, in some way its more pleasant.
One thing not mentioned, in my opinion, steering is a little bit heavier, its noticeable at first, for about the first hour, then you get used to it.
I'm talking here about lightweight 17x9 setup with 245 tire. Going 18 + wider tire the effects will probably be even more noticeable. One thing to keep in mind is your alignment to manage the poke, you will need at least 1.25-1.5 degrees of camber up front to make it look reasonable. Rear At 1-1.25 looks good too.
Don't worry too much about making it worse, its a blast with better tires, plus it looks good too, I think 17x9+35 or so is a great balance for looks and performance.
Go out to the meets, maybe someone can let you drive their car with similar setup to get a feel, you can hop back in your car and immediately compare.
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
Mr.Impreza (10-06-2015)
Old 10-20-2015, 03:01 PM   #555
mixxxx
mixxxx's Avatar
Enkei RPF1 17x9+35 and Michelin Pilot Super Sports 245/45/17
mixxxx is offline   Reply With Quote
The Following 2 Users Say Thank You to mixxxx For This Useful Post:
akahenry (11-08-2017), Mr.Impreza (10-22-2015)
Old 10-21-2015, 09:51 AM   #556
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
ZN6_0974 by Jason Lam, on Flickr
ZN6_1023 by Jason Lam, on Flickr
ZN6_1018 by Jason Lam, on Flickr
17x9 +35 RPF1
245/40/17 Dunlop Direzza Z2
-3.5 Camber Front
-3 Camber Rear
Kuri is offline   Reply With Quote
The Following 9 Users Say Thank You to Kuri For This Useful Post:
Aztec (10-21-2015), dattran86 (10-27-2016), DustinS (10-21-2015), kevaughan (04-11-2022), nisti (10-22-2015), racing_reject_001 (10-28-2015), SkAsphalt (12-04-2015), Surok (01-09-2018), trigger happy (11-14-2015)
Old 10-21-2015, 11:19 AM   #557
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Having trouble finding the answer to this. (Did search but was confused)
I'm planning on going with these 17x9 RPF1's with 235 tires. Will they clear on a 100% stock BRZ suspension setup? Do I need a different offset to make it work?
xsnapshot is offline   Reply With Quote
Old 10-21-2015, 12:07 PM   #558
Kuri
Kuri's Avatar
245 should be able to clear.
we have two guys on 245/40/17 on the same wheel and offset.
Old 10-21-2015, 12:42 PM   #559
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
17x9 +35 RPF1
-3.5 Camber Front
-3 Camber Rear
This makes me want to lower more and get that camber dialed in. Looks perfect
I'm running 17x9 +35
But only -1.4 front
And -1 back
How does that setup handle?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
BRZHarley (10-21-2015)
Old 10-22-2015, 09:35 AM   #560
Kuri
Kuri's Avatar
But only -1.4 front
And -1 back
Pretty well. I track pretty often so this was the track mechanic recommended because I kept rolling my tire in long sweeper/carousel type turns. I have also a slight toe out on all wheels. (Better rotations) [Track stuff]
I did -2 for a good awhile. It's flush with the fender.
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
