Old 10-20-2015, 03:50 PM   #15
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Originally Posted by jiaim View Post
Go harrop
It seems the Harrop is new , correct me if i think wrong , i did not find any review about that
Toyota86.ir is offline   Reply With Quote
Old 10-20-2015, 03:52 PM   #16
DAEMANO
Time Traveller
If cost is not an option and in your climate definitely get both an intercooler and oil cooler, even at 5psi.
The Following User Says Thank You to DAEMANO For This Useful Post:
Toyota86.ir (10-20-2015)
Old 10-20-2015, 03:53 PM   #17
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by Toyota86.ir View Post
We use hks oil cooler kit.
Do you have any idea about power gain in E85 5psi boost if we use intercooled version?
I think Jackson Racing is the one you might want to be going. So far I've heard nothing but good things about it.
Instagram: trevor.parque
The Following 2 Users Say Thank You to MisterSheep For This Useful Post:
rb6freak (10-20-2015), Toyota86.ir (10-20-2015)
Old 10-20-2015, 04:01 PM   #18
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I guess cosworth be better on paper spec but i have no idea about jakson racing
You can't go wrong with either. With your friends current set up, they'd both be fine. But they are different types. Cosworth is a PD and JR is a centrifugal. But JR has a lot of good reviews. I have a Cosworth so... I'm a little biased haha.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 10-20-2015, 04:14 PM   #19
Toyota86.ir
Cosworth need no oil and it looks more beautiful to me.
PD are good on low to mid on paper and for 270bhp i guess low should be fine .
Cosworth use eaton , we know eaton is a good company , overally cosworth has more stars on paper but in real world we should hear customers experience.
Old 10-20-2015, 04:18 PM   #20
weederr33
weederr33's Avatar
Technically is does use oil. Cosworth just claims you don't need to change it for some 50,000 miles. But compared to others, it doesn't use as much. HOWEVER, because it uses an A2W intercooler, you do have to keep tabs on the coolant reservoir. It uses a mixture of 25/75% antifreeze/ water.
Old 10-20-2015, 04:19 PM   #21
Toyota86.ir
It has positive reviews in this club and i try to find most reliable kit because we do not need extra power at 270bhp
Old 10-20-2015, 04:20 PM   #22
weederr33
weederr33's Avatar
Also, I've only had a few issues, which are mentioned in my build thread. But nothing catastrophic.... yet. Also, I'm running of Cosworth's base 2.3 tune. For you, you'd need a custom tune.
Old 10-20-2015, 04:21 PM   #23
MisterSheep
Killed Scion
But the thing is with the jackson racing is that they do offer a higher boost pulley just in case in the future you want to run more boost.
Old 10-20-2015, 04:24 PM   #24
Toyota86.ir
Did you had any problem before and after installing cosworth?
Did it had clean fitness?
Old 10-20-2015, 04:27 PM   #25
Toyota86.ir
Yes , we should use E85 custom tube by our tuner Mike (moto-east) with 5psi
Old 10-20-2015, 04:30 PM   #26
Toyota86.ir
Sometime we think 270bhp is ok and no need to increase it but in future we go to change the boost. I'm not sure about future but i guess my friend stop it.
Old 10-20-2015, 04:43 PM   #27
weederr33
weederr33's Avatar
Everything fits great. The issues were with the tune. Like the cruise control causing a CEL because of some wire possibly being pinched. The other was something about running lean, but I think that's because I didn't tighten the charge pipe clamps good enough when I changed the air filter.
Old 10-20-2015, 04:45 PM   #28
weederr33
weederr33's Avatar
Oh, yeah the smaller pulley with the JR kit is a nice upgrade option. And with your set up, plus E85 and a smaller pulley you should easily get passed 270 hp. Not sure if you mean at the wheels or at the crank. Either way, it should do just that.
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
