#15 |
Drives: "I drives like a Porsche"
That was a good explanation of all the different modes you can turn off, and I am still confused. Lol. Still having a blast anyways........if god were a car he would be an FRS.
#16 | |
I aint no snitch
Drives: 330i, C300, "00 lude, "94 Accord
#17 | |
Also, there is always a perceived lag between you wanting more pulling power (more torque) and the AT committing to it. I say "perceived" because that's exactly what it is. When you commit the throttle to it, the AT adjusts quickly, much better than any other AT I've driven, but it seems like a lag because you've already committed your mind to it before the car takes action. In a MT you think and do at the same instant so the car feels like its "reading your mind". With now around 1500 miles on my AT, what I have adjusted to doing is using the paddle shifters as part of that process. If I know I'm going to pass, I now think and "shift" at the same time. Since the paddles always work, it puts those two action back together and the response is much more satisfying for me. Last edited by Dadhawk; 06-05-2012 at 03:10 PM. |
#18 |
Drives: MS3
When I am finally ready to buy one it'll be an Auto. I'm currently driving a VW DSG and it shifts like a dream. Have any of you ever driven a DSG that you can compare the FRS Auto with as far as gear changes? there is all kinds of info saying some of the components are from the ISF but some dispute this. Thanks.
#19 | |
The one thing I didn't like about the FRS automatic was it felt like the torque converter took a while to lock up in 1st gear, whereas in the GTI, the clutch fully engages before 1500 rpm. But that probably has more to do with the GTI's low end torque than anything. The automatic in the FRS a nice transmission overall and probably smoother in everyday driving, but not quite as good as the DSG in my opinion. |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | ZmZMWagon (06-05-2012) |
#20 |
Drives: Toyota
Hi, what is the RPM cruising 80mph with the automatic?
#21 | |
Drives: MS3
#23 | |
Drives: Toyota
The engine wear will be less on the AT. Suitable for long road trips for less noise and gas mileage. |
#24 |
Drives: Scion FRS Ht Lva(AT)
Great comments Dadhawk
Dadhawk Quote:Here's my thoughts on it based on completing a road trip through the NC mountains. I can tell you, you won't be in 6th gear if climbing for any significant distance in the AT. It drops pretty quickly back to 5th and even 4th. 6th is definitely a "cruising gear". No real work gets done there. That 6th is a cruising gear would make perfect sense when you look a chart of rpm/speed for the various ratios. MT means lots of shifting in city driving, AT means more shifting on the highway than might seem familiar. Dadhawk Quote: Also, there is always a perceived lag between you wanting more pulling power (more torque) and the AT committing to it. I say "perceived" because that's exactly what it is. When you commit the throttle to it, the AT adjusts quickly, much better than any other AT I've driven, but it seems like a lag because you've already committed your mind to it before the car takes action. In a MT you think and do at the same instant so the car feels like its "reading your mind". That sounds to me like what might be the primary difference between AT and MT, in terms of feel: that you do not/cannot get the same sense of connection/throttle response. Sounds like you are saying the AT is better at the sense of connection/ throttle response than a conventional automatic? Is it a lot better or just a little better. When it shifts in "D" to a new gear, you still get a perceived lull? I am thinking the question is does it drop out of torque converter clutch lockup every time it shifts or once locked the torque converter stays locked in gears 2-6? I think I read somewhere that only 1rst does not have torque converter lock up. This is one thing I have read about the IS-F 8 speed: "...A new torque-converter lock-up control was developed that allows for a direct, crisp gear change through the constant lock-up of the torque converter in the second through eighth gears...." Edmonds Inside line had this to say about the IS-F: "....If the IS-F's engine seems complicated, get a load of its one transmission offering. This eight-speed automatic is adapted from the tranny in the LS luxo barge. Leave the shifter in fully automatic mode and you can never quite shake the impression that there are three too many gears in the box. It seems to always be lounging around in 7th on the highway and dithering among its many gears around town. Downshifts are slow to come. When it finally finds a nice low gear, the engine is spinning wildly, the engine note has turned angry and you've got more power than you asked for, plus it arrives later than you wanted it. Use the automatic mode only for traffic jams. It's better to leave the transmission in manual mode and use the steering-column-mounted shift paddles to choose from the myriad gears. In all but 1st gear, this transmission uses a lock-up clutch to connect the engine and transmission, something like a conventional manual powertrain. When you combine the crisp feeling of engine response that results with tremendously quick upshifts and downshifts (with automatic throttle blips), the complex transmission becomes one of the most entertaining sequential-shift automatics...." Appreciating that the FRS automatic is a development, has two fewer gears (hopefully leaving out two of the extraneous extras) and probably other improvements, does anything said about feel/perception sound familiar? Dadhawk Quote: With now around 1500 miles on my AT, what I have adjusted to doing is using the paddle shifters as part of that process. If I know I'm going to pass, I now think and "shift" at the same time. Since the paddles always work, it puts those two action back together and the response is much more satisfying for me. I noticed the responsiveness with the paddle shifters as a good thing! Did you feel you could get on or just stay on the throttle for a more seemless response when paddle shifting? |
| The Following User Says Thank You to smbrm For This Useful Post: | KalbiCool88 (04-28-2015) |
#25 | ||||||
Thanks.
I think the key is that when you hit the paddle it does what you want when you want it, not when the computer wants it. For the most part, none of us drive like an standard AT is programmed so it always seems to lag. When using the paddles, except in the extremes (when shifting will over-rev or under-rev) the auto does exactly what you tell it the instant you tell it. Standard AT when manually shifted goes: Manual Shift->Computer holds a committee meeting->Decides Yea, well OK->Slow deliberate shift. FR-S AT goes: Manual Shift->Shift. It doesn't have to think because it knows when the shift up/down will not break "the rules "at any given time because it constantly evaluates the situation. You can tell this because of the shift lights which will light up in either direction depending on what is valid. |
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
#26 | ||
You articulate perceptions quite well! Thanks for you insight. |
| The Following User Says Thank You to smbrm For This Useful Post: | Dadhawk (06-05-2012) |
#27 |
Re-member
Drives: Toyota camry
FYI: The auto does not lock up in first, second through 6th only. Thats why it felt like it took longer than in the GTI
Nothing decays like progress, and nothing preserves like neglect.
#28 |
Drives: scion frs black, stock
Question? If i was interested in having the gears change quicker, would upgrading the torque converter solved that?, As well as get me prepped for when I add the tb/or/sc?
Thanks in advance for any advice, first time posting :} |
