Old 10-17-2015, 02:49 PM   #12867
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Sti Battery Tie Down.
This might hold the optima yellow top battery better than Cusco tie down does.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-17-2015, 03:24 PM   #12868
icybrzzz
Drives: 2015 Scion frz
RPF1 17x9 +35 with 245/40/17 Michelin PSS + nameless track pipe
icybrzzz is offline   Reply With Quote
Old 10-17-2015, 03:26 PM   #12869
nisti
nisti's Avatar
Drives: BRZ & XV
More pics of this please.
Exact wheel/tire setup I want to eventually get.
nisti is offline   Reply With Quote
Old 10-17-2015, 03:28 PM   #12870
icybrzzz
I'll try to get some better photos asap! Stock suspension too btw with no rubbing issues.
Old 10-17-2015, 03:39 PM   #12871
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by LWAA View Post
I'm interested in one of these. Can you keep us up to date on what you do and what difference it makes?
Will do. I don't know if Stage 1 really registers on the butt dyno, but the AVCS is noticeably a little bit more aggressive and it feels a little bit smoother. I have headers that I need to install, so I'm sure that'll be more noticeable with a Stage 2 map. The upside to OFT is that all of the maps are open, so you can tinker to your heart's content, if you're so inclined.
jawn is offline   Reply With Quote
Old 10-17-2015, 04:35 PM   #12872
kberkel
kberkel's Avatar
Been experimenting with wrapping the door piece in Alcantara. Overland said they glued the whole piece.. but I couldn't get nice clean edges doing that.
My latest try was pretty successful.. but I don't think it's gonna hold up to the heat/cold. I glued the center and used scor-tape on the edges.
It's ridiculously tedious.. you can see a few spots I messed up near the back of the door.
So.. I've decided I'm going to make a fiberglass cover piece this week so I can do everything separate from the door. Then I can also pad it and get more creative.
While the panels were off.. I also deadened the doors and added MLV/CCF. I've had the panels off for a while and the car was deafening before.. but so far it seems much improved.
kberkel is offline   Reply With Quote
Old 10-17-2015, 07:34 PM   #12873
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Installed my Maximal Performance oil cooler kit today. Easy install... but man AN fittings are a gigantic PITA for high pressure. Getting the fittings to seal on the lines with no weeping took a LOT of torque. Looks good though and keeps oil temps under control VERY well. I'm looking forward to my upcoming track day!
I also swapped my brake pads out for a Carbotech XP10/XP8 combo. I think it's completely overkill for the stock tires, but I'll find out soon enough. Pretty noisy, but they bite like crazy. Feels great!
Old 10-17-2015, 09:37 PM   #12874
craigpitts7
craigpitts7's Avatar
Drives: 2013 WRB BRZ
Gave her a bath
craigpitts7 is offline   Reply With Quote
Old 10-18-2015, 07:34 PM   #12875
_______
_______'s Avatar
Drives: SWP Subaru BRZ
Tomei UEL headers installed to go along with my Invidia catted front pipe and Q300!
_______ is offline   Reply With Quote
Old 10-18-2015, 08:31 PM   #12876
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Bet you've got a smile on your face! I have the same setup except with the nameless catted front pipe. Sounds PERFECT imo. I get nothing but compliments.
spdfreak is offline   Reply With Quote
Old 10-18-2015, 10:43 PM   #12877
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Originally Posted by craigpitts7 View Post
Gave her a bath
What tire and wheel setup do you have there? Looks good.
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
MGPAX is offline   Reply With Quote
Old 10-18-2015, 10:45 PM   #12878
icybrzzz
Heres another
Any specific angles you would like to see? Will be taking pics with my DSLR this coming weekend if all goes well. No more cellphone pics
Old 10-19-2015, 12:20 AM   #12879
MEKO
MEKO's Avatar
Drives: F30
Uploaded photos of her.
Went cruising with VQ Engines.
If you no longer go for a gap that exist, you no longer a racing driver... Ayrton Senna
MEKO is offline   Reply With Quote
Old 10-19-2015, 01:33 AM   #12880
mixxxx
mixxxx's Avatar
Enkei RPF1 17x9+35 and Michelin Pilot Super Sports 245/40/17
mixxxx is offline   Reply With Quote
