Old 10-17-2015, 09:57 PM   #1
TicoWalrus
TicoWalrus's Avatar
Drives: 2015 WRB Subaru BRZ
Need help with identifying exhaust leak
Hello,
I just recently installed my Openflash Headers and flashed my car to the stage 2 UEL tune. I am pretty new to the whole OFT, but I decided to data log afterwards and took a short drive and noticed my LTFT was really high. after looking around the forums, I learned this means I'm running very lean. Could this be because of an exhaust leak in the connection to either engine or overpipe?
Here are the datalogs, there are 3 short trips in one log.
http://www.datazap.me/u/ticowalrus/l...8?log=0&data=1
Any help/info would be greatly appreciated!
Thanks!
TicoWalrus is offline   Reply With Quote
Old 10-18-2015, 12:14 AM   #2
phrosty
Check your O2 sensor.
phrosty is offline   Reply With Quote
Old 10-18-2015, 12:24 AM   #3
steve99
Drives: FT86
Originally Posted by TicoWalrus View Post
Hello,
Thanks!
something weird is going on with the logging, at times, looks more like logging issue that car issue.
connect you oft to internet and let it upsat make sure your on latest version of openflash manager 1.21.0 i think.
then try logging again
high ltft doesnt mean you running lean it just means the ecu is applying a lot of correction to try to get the correct afr, this couls be due to bad maf scaling due aftermarket intake or exhaust leak ect or wrong fuel ie e85 on a petrol tune.
parts of log look ok but then some parameters are weird ie iam=0 and then ltft -100, thats impossible max is 30, looks like logging problems
Old 10-18-2015, 12:22 PM   #4
TicoWalrus
TicoWalrus's Avatar
I was actually about to do that today because I felt the O2 sensors might have not been threaded properly. I attempted to thread them in, but they only went in so far. I did not want to damage them. I assumed that was as far as they would go on this header. Do they go in completely like in the stock headers? If so, any tips on how to help them go in all the way/properly?
I believe that sudden drop with ridiculous numbers was from when I stalled at a light due to the dead spot after tuning. However, i updated my OFT and did a log today on the way back from home. The LTFT has gone down, but are still pretty high, in the 12-15 range. Here is the log:
http://www.datazap.me/u/ticowalrus/l...og=2&data=1-11
Do you think its a logging issue still? I am going to check my O2 sensors late today as advised by phrosty to cover all bases.
Old 10-18-2015, 04:10 PM   #5
steve99
Drives: FT86
Yes 02 sensors should screw in all the way easily If they don't then dont force them.
remove 02 sensors and run a M18 by 1.5mm pitch thread tap/chaser through the 02 sensor bungs in header they often distort a bit when welded in.
02 sensors will then screw in easily all the way.
Yes it looks like you have a leak in exhaust near or at sensors. High LTFT positive at idle and low rpm then ok higher rpm.
you also have a car than runs quite rich on oft maf scaling it going to 11.25 which is limit of o2 sensor rich wise. above 3500 rpm.
you would benifit from adjusting maf scale, or copying in one from here
http://www.ft86club.com/forums/showthread.php?t=94822
but fix o2 sensor/exhaust leak first
Old 10-18-2015, 04:13 PM   #6
TicoWalrus
TicoWalrus's Avatar
I got under the car and reinstalled the headers again. when uninstalling, saw black on one of the ports to the manifold, and to be safe i tightened my O2 sensors again, reinstalled everything, and tightened. I took a couple logs diving around. Do these look like the normal readings i should be getting?
http://www.datazap.me/u/ticowalrus/l...ta=1-2-9-10-11
http://www.datazap.me/u/ticowalrus/l...=1&data=1-9-11
And thanks for the info on the MAF scaling, I will definitely look into it!
Old 10-18-2015, 04:28 PM   #7
steve99
Drives: FT86
looks a lot better.
did you use new gaskets ?, if you reuse old ones it will generally leak after a while. They only crush to shape once.
Old 10-18-2015, 04:32 PM   #8
TicoWalrus
TicoWalrus's Avatar
looks a lot better.
I used my new pair of grimmspeed header gaskets, but I re-used the gasket connecting to the overpipe. Is there a specific name for that gasket so I can look it up to buy?
Sent from my SM-G920T using Tapatalk
Old 10-18-2015, 04:50 PM   #9
steve99
Drives: FT86
just header to overpipe gasket i believe
Old 10-18-2015, 04:51 PM   #10
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
http://www.ft86speedfactory.com/suba...sket-1100.html
jawn is offline   Reply With Quote
Old 10-18-2015, 04:51 PM   #11
TicoWalrus
TicoWalrus's Avatar
Ok, great! Thanks a lot for your help with everything! Really appreciate it!
Thanks for the link!
ofh, oft, openflash tablet, openflashheader
Exhaust leak? Joeycokeboy Engine, Exhaust, Transmission 6 06-05-2015 12:29 PM
Exhaust leak? Jman1759 Engine, Exhaust, Transmission 4 11-29-2014 11:11 PM
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 01:08 PM
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 08:09 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
