Old 10-12-2015, 10:06 PM   #2997
CSG Mike
CSG Mike's Avatar
Originally Posted by Binary_fission View Post
Thanks Mike, any particular catch can you recommend? Also dual or single?
Sent from my SM-N910T using Tapatalk
The Radium Dual setup is nice
p.s. we have them in stock
Old 10-13-2015, 01:43 PM   #2998
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Got the P0172 and P1170 twice in a month now. All the same symptoms of everyone else. Car was sluggish, felt like it retarded all timing and threw a lot of fuel at it. Cleared the codes, went back to normal... guess it's time to clean the MAF.
Talked to Jackson Racing a while back about this issue - they said clean MAF and try to keep the harness extension away from the alternator, that it can cause interference.
Just in case - has anyone found the part #s for the MAF o-rings? Where do you order them from? I fear mine may get damaged when removed.
axelthrasher is offline   Reply With Quote
Old 10-13-2015, 01:59 PM   #2999
CSG Mike
CSG Mike's Avatar
CSG can mail you an extra. Just PM me your mailing address.
Old 10-13-2015, 05:21 PM   #3000
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Hey Oscar thank you for reply.
Now I don't need it because it's bad for the car, or it doesn't do good nor bad just pretty much waste if money or its optional for track guys?
I don't track the car but i do take it to canyons once in a while and like to push it above 6k rpms.
I'm saying it is not needed/required with our supercharger system.
There are plenty of guys running them. When done correctly, it is not a bad thing in the system. On our end though, we see a lot of people that have problems and then call us with oil everywhere in their system. I am not sure WHAT they are doing, but it is a common tech call.
Also, we just ran the SCCA National Championship Runoffs at Daytona with our supercharged FR-S. We did not run a catch can.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
Old 10-15-2015, 12:16 PM   #3001
shattered_memory
Drives: Satin White BRZ Limited
I am thinking of going with the Jackson racing carb kit with the oil cooler. I am also thinking of upgrading to sticky 215 tires (zii starspecs, Rs3's, re-71, ect..) My question is...will I have traction issues with 215 tires, or should I upgrade to wider wheels and tires? I will mostly be driving in the street with occasional HPDE track days.
shattered_memory is offline   Reply With Quote
Old 10-15-2015, 01:28 PM   #3002
CSG Mike
CSG Mike's Avatar
Traction will depend on the conditions you're driving in. With stock tires, 1st gear will spin unless you're on a very clean surface.
Let us know when you're ready for a kit! We can make a package with some wheels and tires; most people that are boosted upgrade to something a bit wider, both on the wheel and tire end.
Old 10-16-2015, 01:51 PM   #3003
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
The last post is stock height w/ 225 50 17s. That might work for you. http://www.ft86club.com/forums/showthread.php?t=28017
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 10-16-2015, 02:17 PM   #3004
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We had the opportunity to tune with our Flash & Go Tune on another Jackson Kit with only one part being different between the two cars. Can you guess what caused the power loss above 6200 RPM on both E85 and 91 octane?
Cheers,
William Knose
Old 10-16-2015, 02:18 PM   #3005
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Dirty MAF?
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 10-16-2015, 02:51 PM   #3006
DeliciousTuning
Originally Posted by ScionOfHorus View Post
Dirty MAF?
We're looking more at a particular aftermarket modification, not a mechanical or electrical problem.
Sincerely,
Zach
Old 10-16-2015, 03:10 PM   #3007
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Almost looks like you are running out of fuel on e85. Port fuel injectors?
industrial is offline   Reply With Quote
Old 10-16-2015, 04:05 PM   #3008
CSG Mike
CSG Mike's Avatar
Originally Posted by DeliciousTuning View Post
Nearly perfectly skewed torque curve?
I'm gonna guess a longer manifold. Or Crawford "Power Blocks".
Old 10-16-2015, 04:16 PM   #3009
DeliciousTuning
Old 10-16-2015, 07:53 PM   #3010
Sleepless
Drives: 2016 FR-S
Odd, I have the power blocks and don't have a skew like that. This is on 92
Sleepless is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
