#2983 | |
I believe it might be higher than that. @SPCorBUST is around 370 whp on a JRSC c30, high boost pulley on e85 with catless header, custom Church tune. I don't know if his front pipe is catless though. |
| The Following User Says Thank You to dj2020 For This Useful Post: | SPCorBUST (10-11-2015) |
#2984 |
I have a cat in the front pipe. My next trip to Church will be with a new fuel pump, no cat front pipe, and Ace type B headers with the 250 overpipe. Seems like the kit could be maxed out at that point, but tbh I'm already very, very happy with 370.
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#2985 | |
Which pump did you end up going with? I ordered a Denso 265lph, just waiting for it to arrive. You didn't like the pump you had when you were running the KW kit? |
#2986 | |
Drives: FRS
Can anyone confirm if you do need dual catch can or not. Sent from my SM-N910T using Tapatalk |
| The Following User Says Thank You to Binary_fission For This Useful Post: | dj2020 (10-11-2015) |
#2987 | |
Nobody's answering because it's heavily dependent on your supporting mods and tuner's decisions. |
#2988 | |
Drives: 2014 FRS
#2989 |
Drives: 2013 White FR-S
I didn't mention supporting mods because the only mods I have are the pipes. I guess I should have clarified that. I would just get the JRSC w/ oil cooler and catch cans. 285 is quite the jump over 240. Getting rid of cats and having an aftermarket exhaust makes that much of a difference? Good to know. Thanks!
#2990 | |
285 is a blind guess. |
#2991 |
Drives: 2014 BRZ
Re: Dual catch cans...
Note that the JRSC oil tank is mounted on the driver side where most install the second can.
| The Following User Says Thank You to Sleepless For This Useful Post: | Binary_fission (10-12-2015) |
#2992 | |
Drives: JR FR-S,
-Oscar Jr. |
#2993 |
Drives: JR FR-S,
#2994 |
Drives: FRS
Hey Oscar thank you for reply.
Now I don't need it because it's bad for the car, or it doesn't do good nor bad just pretty much waste if money or its optional for track guys? I don't track the car but i do take it to canyons once in a while and like to push it above 6k rpms. Sent from my SM-N910T using Tapatalk |
#2995 | |
An easy test is to see if any of your charge pipes have a very fine layer of oil on them after some extended driving. If you do, you'll want catch cans. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Binary_fission (10-12-2015), clayrush (10-12-2015) |
#2996 | |
Drives: FRS
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
