#15 |
To me they are have great visibility. Signs pop out more and just the absence of the yellow halogens is worth it. Yes they are plug and play. No external driver.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#16 |
Grip>Drift
Drives: FRS
What about 9006 bulbs or whatever the DRL/Bright is?
#17 |
Those are still on their way. They are 9005 for the DRL's
#18 |
Grip>Drift
Drives: FRS
Let me know. I've been running 3.3k for those and I want something brighter for DRL. If they are gonna be on I want people to see them. Sent from my iPhone using Tapatalk
#19 |
They should be fine, the ones coming for the drl's are 2000lm each also so it's like having low beams on. You'll be seen no problem.
#20 |
Drives: 2014 BRZ Limited
Those yellow lights look like shit. Did you get them at this place?
#21 |
No I didn't get them from there. They look great!!
#22 |
#23 |
lol, obviously you have a reading comprehension issue. I clearly wrote that I didn't use the yellow. Thanks for your kind words!
#24 |
Drives:
I've actually been running these in my fog lights for awhile. Couldn't be happier.
2013 UltraMarine Fr-S - Open flash tablet, Open flash UEL Header, Injen Intake, E85
| The Following User Says Thank You to Josh Ehlert For This Useful Post: | stevesnj (10-13-2015) |
#25 |
Because you guys have stock headlights, are you guys cool with running no high beams then?
#26 | |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Also @stevesnj jsut to confirm... the "8000k" H11 kit also comes with the 3300k and 6500k? |
#27 |
The high beams are the DRL lights with the low beam projectors. Low beams the DRL's are off. So I have highs still.
#28 | |
| N/A typical oil temps | JB86'd | Engine, Exhaust, Transmission | 13 | 12-16-2014 01:42 AM |
| Oil temps with JR SC and JR oil cooler | dp1 | Tracking / Autocross / HPDE / Drifting | 87 | 11-14-2014 01:35 AM |
| Oil Temps | Fish Eagle | AFRICA | 13 | 07-22-2014 06:53 PM |
| Intake air temps | mrk1 | Engine, Exhaust, Transmission | 2 | 07-10-2013 08:56 PM |
