Old 10-11-2015, 04:53 PM   #15
stevesnj
stevesnj's Avatar
Originally Posted by calmtigers View Post
Look good to me! Are they significantly better for visability / I assume these are plug-n-play?
To me they are have great visibility. Signs pop out more and just the absence of the yellow halogens is worth it. Yes they are plug and play. No external driver.
My 2016 Build thread
Old 10-11-2015, 05:10 PM   #16
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
What about 9006 bulbs or whatever the DRL/Bright is?
Old 10-11-2015, 05:12 PM   #17
stevesnj
stevesnj's Avatar
Those are still on their way. They are 9005 for the DRL's
Old 10-11-2015, 05:44 PM   #18
BlaineWasHere
Grip>Drift
Drives: FRS
Let me know. I've been running 3.3k for those and I want something brighter for DRL. If they are gonna be on I want people to see them.
Old 10-11-2015, 05:59 PM   #19
stevesnj
stevesnj's Avatar
They should be fine, the ones coming for the drl's are 2000lm each also so it's like having low beams on. You'll be seen no problem.
Old 10-11-2015, 06:01 PM   #20
extrashaky
Drives: 2014 BRZ Limited
Those yellow lights look like shit. Did you get them at this place?
Old 10-11-2015, 06:02 PM   #21
stevesnj
stevesnj's Avatar
No I didn't get them from there. They look great!!
Old 10-11-2015, 06:03 PM   #22
extrashaky
Keep telling yourself that while everyone else on the road laughs at your ugly yellow headlights.
Old 10-11-2015, 06:09 PM   #23
stevesnj
stevesnj's Avatar
lol, obviously you have a reading comprehension issue. I clearly wrote that I didn't use the yellow. Thanks for your kind words!
Old 10-13-2015, 08:35 PM   #24
Josh Ehlert
Drives:
I've actually been running these in my fog lights for awhile. Couldn't be happier.
2013 UltraMarine Fr-S - Open flash tablet, Open flash UEL Header, Injen Intake, E85
Josh Ehlert is offline   Reply With Quote
The Following User Says Thank You to Josh Ehlert For This Useful Post:
stevesnj (10-13-2015)
Old 10-14-2015, 05:02 AM   #25
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Because you guys have stock headlights, are you guys cool with running no high beams then?
Old 10-14-2015, 01:55 PM   #26
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Hows the output of these compared to the stock H11 halogens in the fogs? I barely tell the fogs are on. I figure at 2000 lm each, these LEDs should be signifcantly brighter, but will it cause glare in the reflector housing?
Also @stevesnj jsut to confirm... the "8000k" H11 kit also comes with the 3300k and 6500k?
cdo221 is offline   Reply With Quote
Old 10-14-2015, 02:03 PM   #27
stevesnj
stevesnj's Avatar
The high beams are the DRL lights with the low beam projectors. Low beams the DRL's are off. So I have highs still.
Old 10-14-2015, 02:04 PM   #28
stevesnj
stevesnj's Avatar
Its just at bright and actually slightly brighter than Halogens.
N/A typical oil temps JB86'd Engine, Exhaust, Transmission 13 12-16-2014 01:42 AM
Oil temps with JR SC and JR oil cooler dp1 Tracking / Autocross / HPDE / Drifting 87 11-14-2014 01:35 AM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 06:53 PM
Intake air temps mrk1 Engine, Exhaust, Transmission 2 07-10-2013 08:56 PM
