Old 10-09-2015, 10:15 AM   #1
vien
Drives: subaru brz
brakes
Hello all im about to hit 60k on the brz and of course the service states to inspect the brakes so they do look a little worn not much life yet but i was curious im about to change the rotors and pads for the front but is the brake distribution even or more towards the front? i might as well change the rears at 60k also no?
vien is offline   Reply With Quote
Old 10-09-2015, 10:58 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
If they're in good shape, no need to change unless you are after a change in behavior for tracking, or something. Fronts wear much faster than rear, but an inspection tells all.
If it's time and you upgrade the front pads, do so in the back too (pads...) The car typically works best with matching compound front and rear.
Old 10-10-2015, 02:10 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Usually rotors outlive pads. And usually rear pads outlive front ones. If replacement pads are of same compound and there is lot of thickness left in rears (of course, inspection needed), you can aswell change just fronts. If you change pads to those of different compound then i'd change rears aswell though, to keep brake front-rear bias.
Old 10-11-2015, 12:48 AM   #4
vien
Drives: subaru brz
Gotcha thanks guys what I ended up doing is getting the stoptech front rotors and got new pads front and rear only thing I'm keeping is the stock rear rotors. I'm also changing the front t lines to SS and changing out fluid to motul rbf and also doing the brake master cylinder stopper.
Brakes, Brakes, and more Brakes Fish Eagle AFRICA 282 06-18-2019 04:36 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Regarding brakes fito68 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-21-2015 03:15 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 04:52 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
