Drives: '13 BRZ | '04 E55
Review: Edelbrock Supercharger Kit
Hey Guys! I recently had the opportunity to install my Edelbrock kit on my 2013 Subaru BRZ. Below are my initial impressions of the kit from installation to first drive, and will update this thread with my findings as I continue to drive the kit.
Installation Time: 7 Hours Installation Difficulty: **** Installation Items: - Edelbrock Kit - Koyo Radiator w/ Perrin Hoses - Perrin Water Pump & Alternator Pulleys Previously Installed Engine Items: - ACE Type B / 350 Header - Fluidampr Crank Pulley Unboxing: This kit arrived via freight secured to a pallet. Everything was tightly packed, and no damage present on any components. The kit included a binder containing detailed, color instructions as well as a checklist of all parts in the kit. ![]() ![]() Engine Preparation: The detailed instructions provided every detail needed to prepare your engine for installation of the supercharger. Everything went smoothly on disassembly, aside from the nest I found under my intake manifold around my knock sensor. Turns out something decided to call it home by packing my engine with insulation and feathers, who knows how long that was in there! ![]() Koyo Radiator Installation: The Koyo radiator is slightly thicker, and was expected to create fitment issues with the Low Temp Radiator that is included with the supercharger kit. Surprisingly, I was able to run the Koyo radiator without any modification by simply flipping the rubber isolators in the upper radiator brackets upside down. With a little finesse, the brackets slide right in, and everything lined up well. The welds on the LTR do touch the bumper beam, but I don't forsee any issues. ![]() ![]() Supercharger Installation: Again, instructions to the rescue, everything went smoothly, and fit perfectly. This kit took everything into consideration and was 100% bolt in. Brackets were provided for anything requiring relocation so no issues with fitting anything that was non factory or relocated somewhere non factory. ![]() ![]() ![]() ![]() ![]() ![]() Initial Impressions: This kit has a great powerband, and the power delivery is very linear. This will be the perfect setup for someone who autocrosses, and wants a predictable setup. Based on the capabilities in the TVS blower, I think there is still a lot to be had in terms of horsepower with a custom calibration. But so far it seems to hold its own. My roomate runs a Vortech kit on his BRZ, and the Edelbrock kit pulls about a car length on him even on the CARB tune. I did notice some tip-in knock with the CARB tune, however my IAM still eventually timmed to 1.0 (factory set to 0.7) so everything must be happy! Sounds: From in the cabin, there is no supercharger whine from the TVS, even over my quiet Borla factory axleback. However, it sounds like I can hear the bypass valve ever so slightly under heavy driving. Maintenance: The belt for this kit is $10 on Amazon, making it a very cheap replacement should any issues arise! The belt is also easily accessible, and can be changed without removing anything from the car. Everything is easily accessible with the exception of the clutch slave cylinder bleeder. But it is still doable. ![]() ![]() ![]()
| The Following 52 Users Say Thank You to NotSoJDM For This Useful Post: | 86 South Africa (10-14-2015), AceHeader-MT (11-29-2015), alvinli217 (10-26-2015), azian_advanced (10-10-2015), BatStig (10-10-2015), BigFatFlip (10-10-2015), Calum (10-12-2015), ck-GT86 (10-11-2015), continuecrushing (10-10-2015), CSG Mike (10-10-2015), Dadhawk (10-11-2015), DAEMANO (10-10-2015), djdnz (10-10-2015), drewbot (10-15-2015), Edelbrock LLC (10-13-2015), Efferalgan (12-07-2015), finch1750 (11-01-2015), Firesnake (10-10-2015), FRSBRZGT86FAN (11-22-2015), funwheeldrive (10-10-2015), G-awesome (10-12-2015), GhostOp86 (10-15-2015), GotBRZ1691 (10-26-2015), hav0c (10-11-2015), Iceman (10-10-2015), illmatic (10-10-2015), Irace86 (10-10-2015), jawn (10-10-2015), JohnnyP (10-22-2015), KalbiCool88 (12-10-2015), Lonewolf (10-26-2015), LucidMomentum (10-15-2015), MisterSheep (12-11-2015), Nitro22 (10-10-2015), Porcupint (10-10-2015), raven1231 (10-14-2015), Redbrz (10-17-2015), RIP.S2000 (10-10-2015), ScionOfHorus (10-10-2015), shiumai (10-10-2015), slaxx (10-23-2015), snk828 (10-19-2015), solidONE (10-19-2015), SPCorBUST (11-17-2015), sw20kosh (10-10-2015), tobin (10-11-2015), Toyota86.ir (02-17-2016), TRD-X (10-14-2015), trigger happy (02-01-2017), TylerEvil (10-11-2015), whataboutbob (10-27-2015), zerodark (10-10-2015) |
#2 |
Here are some videos from this weekend at Tail of the Dragon [ame="https://www.youtube.com/watch?v=lfvidoUx940"]Dragon Run 3 Oct 2015 - YouTube[/ame] [ame="https://www.youtube.com/watch?v=GL9ObGLXtOE"]Dragon Run 2 Oct 2015 - YouTube[/ame] Last edited by NotSoJDM; 10-26-2015 at 12:26 AM. |
#4 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Great pics and review. Looking forward to future updates.
Also... MOO! lol |
#5 |
Moo.
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | drewbot (10-15-2015), jawn (10-10-2015), NotSoJDM (10-12-2015), raven1231 (10-14-2015), ravisraval (10-10-2015) |
#6 |
Drives: 2013 Firestorm FRS
#8 |
lol. That is my buddies watermark. His last name is Cao...so yeah...
| The Following User Says Thank You to NotSoJDM For This Useful Post: | Freeman (10-11-2015) |
#9 |
Drives: 2014 Porsche Cayman S
Thank you for posting this. I am really interested in this kit and need something that will require little maintenance and be reliable for a daily driver. Let us know how your experience progresses
Sent from my BN NookHD+ using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
#10 |
Drives: WRB Limited BRZ
Are you going to get some dyno results?
#11 |
Yes. I'm going to schedule some Dyno time soon. Still looking to get some videos too. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NotSoJDM For This Useful Post: | Alltezza (10-10-2015) |
#12 |
I love the SC whine, too bad that you aren't able to hear it
#13 |
Yea, I wish she had some whine, but if that's the price I pay for efficiency, I'm ok with that!
Also, First fill up shows 23mpg average which is about 4mpg loss over when I was NA. Sent from my iPhone using Tapatalk
| The Following 5 Users Say Thank You to NotSoJDM For This Useful Post: | azian_advanced (10-15-2015), B T (02-26-2016), funwheeldrive (10-10-2015), GotBRZ1691 (10-26-2015), KalbiCool88 (12-10-2015) |
#14 | |
Drives: Scion FR-S (Hot Lava)
Hey Jordan, I actually have some whine in the higher rpms. Its very faint and low pitched. My previous car (MINI Cooper S) had a high pitched whine in comparison. I think I can hear something maybe since I have the stock exhaust system still. -Aaron Sent from my iPhone using Tapatalk |
| Tags |
| :popcorn:, mawr powwa |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Tour of Edelbrock and their new Supercharger! August 28th | The Racers Line | Northern California | 62 | 09-04-2015 02:59 PM |
| Edelbrock supercharger is out. Need expert thoughts on it. | stockysnail | Northwest | 125 | 09-04-2015 01:51 PM |
| iGarage Markham supercharger install review | wbradley | CANADA | 7 | 05-30-2015 08:45 PM |
| Innovate Supercharger Review! | Teeeg28 | Forced Induction | 19 | 11-25-2014 01:26 PM |
