Old 10-04-2015, 11:59 PM   #1
lupindub
Drives: Scion FR-S
Has anyone gone through winter on there All-Seasons?
I know most people refer to there All-Seasons as a three season tire but has anyone gone thru a proper northern winter on there All-Seasons?
Yay? Nay?
lupindub is offline   Reply With Quote
Old 10-05-2015, 12:19 AM   #2
Cole
Not a troll
Cole's Avatar
Do. Not. Do. It.
I bought my car on 9 December, 2 days after that, I picked up my snow tires. The next day we got our first snowfall of the year as I was leaving my girlfriend's house. I decided as soon as I got home, I'd go to a shop and get them installed. It's a 25 minute drive from door to door, I didn't even last 5 minutes before I decided to stop at the very next tire shop I saw to get the snow tires put on. I was sliding all over the place, and became a huge hazard not only to myself, but to everyone else on the road.
Cole is offline   Reply With Quote
The Following 4 Users Say Thank You to Cole For This Useful Post:
drewbot (10-05-2015), hmong337 (11-18-2015), imanedrn (11-04-2015), Tcoat (10-05-2015)
Old 10-05-2015, 12:27 AM   #3
TM
TM's Avatar
Drives: DGM BRZ 6MT
Yep. This was me going 15-30mphs straight on a highway.
TM is offline   Reply With Quote
The Following 2 Users Say Thank You to TM For This Useful Post:
drewbot (10-05-2015), Tcoat (10-05-2015)
Old 10-05-2015, 03:51 AM   #4
lupindub
Drives: Scion FR-S
Originally Posted by Cole View Post
Do. Not. Do. It.
Just so there's no confusion, you guy's weren't using the stock summer tires the car comes with and using All-seasons?
Old 10-05-2015, 04:53 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
In before a keyboard warrior says he been through 30 Arctic winter with nothing but racing slicks and recommends "you'll be fine if you are careful"
OP, if you can afford snows get them. All season may get yo by but your have to be very careful and choose when to drive and when to park. I tried new conti dws in 2 inches sof snow and I was sliding considerably. I decided not to drive my car in snow after that but I have a second car with snow tires.
You may also consider it an investment. I can't miss work because of snow. If I do I won't get paid and its considered absence. And I live 25 miles from work. I just bought replacements for my car only $700 for cheap wheels and tires. I say only because the last set went through 6 seasons. And it only needs to get me to work through two snow storms to be worth it. That's not to mention how much safer you will feel with them.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Cole (11-18-2015)
Old 10-05-2015, 08:54 AM   #6
DarkSunrise
DarkSunrise's Avatar
I'm using the OEM all-season tires (Bridgestone Turanza) in the winter. If there's anything more than ~2" of unplowed snow on the ground and an incline, you will have a hard time getting moving. The car will crab-walk with road camber and the rear end wants to snap around under acceleration even in a straight line. I leave the FR-S in the garage if there's more than a light dusting on the ground.
My other car is a 2011 GTI and it is MUCH better in unplowed snow, even on OEM all-seasons (Pirelli P Zero Nero AS). Don't expect the FR-S to perform close to a FWD econobox in the snow on all-season tires - it will not.
On plowed roads you should be fine. Just be cautious about ice buildup/black ice as you would in any car.
2022 BRZ Build
2013 FR-S Build
Old 10-05-2015, 09:42 AM   #7
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Yay? Nay?
Really.....it snows in MI....don't be that guy
drewbot is offline   Reply With Quote
The Following 2 Users Say Thank You to drewbot For This Useful Post:
Cole (10-05-2015), wparsons (10-05-2015)
Old 10-05-2015, 09:54 AM   #8
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Buy snows /end
mkivalex is offline   Reply With Quote
The Following User Says Thank You to mkivalex For This Useful Post:
hmong337 (10-05-2015)
Old 10-05-2015, 10:40 AM   #9
mrk1
Drives: Sterling BRZ Ltd
With proper snows this car is pretty good in the snow for what it is, well worth the investment.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-05-2015, 11:17 AM   #10
"All" season tires are the perfect study in compromise. They work OK in most conditions but do not work really great in any. So many people focus on tread pattern but totally ignore the real factor that needs to be considered which is stiffness. An all season tire is designed to hit the middle range but that means they are way too soft for hot weather and way to stiff for cold.
Frequently you will see written "if there is more than X inches of snow all seasons are no good". The fact of the matter is that the depth of snow really doesn't come into play as much as people think. It is the temperature that causes issues. Anything under about 40 degrees means the all season tires are starting to stiffen up to the point they no longer grip no matter how great the tread is. Get into sub zero temperatures and you may as well be trying to drive on solid plastic discs.
With proper winter tires (be they snow and/or ice rated) these cars are tanks that will walk through just about anything. There is nothing quite like to looks you get when you blast past all the AWDs and SUVs that are stuck in 3 inches of snow when it is minus 10 out.
BirdTRD (10-25-2015), Cole (10-05-2015), fatalelement (10-05-2015), wparsons (10-05-2015)
Old 10-05-2015, 11:45 AM   #11
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
*their.
jawn is offline   Reply With Quote
The Following 3 Users Say Thank You to jawn For This Useful Post:
Akari (10-28-2015), NWFRS (10-16-2015), wparsons (10-05-2015)
Old 10-05-2015, 11:46 AM   #12
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
I drove a camry in MI for 4 years in college on all weathers for the first year. Several large dents later from sub 10 mph slides into ice and rails, I got winter tires.
Disclaimer: I'm from cali, but even then I knew how to drive very well but many of these slides were unrecoverable due to the tires and conditions.
Get the tires yo.
Edit: as @Tcoat describes, I often felt like I was on plastic discs. On more than one occasion I was literally unable to proceed up a hill, along with other cars, because I would simply slide back down. MI is no joke.
Sent from my SAMSUNG-SM-G925A using Tapatalk
fatalelement is offline   Reply With Quote
The Following 2 Users Say Thank You to fatalelement For This Useful Post:
Cole (10-05-2015), Tcoat (10-05-2015)
Old 10-05-2015, 12:32 PM   #13
Hoahao
Drives: 2014 Monogram Hot Lava
I ran Michelin A/S 3's last winter. They seemed to handle the cold alright, and I only drove once in about 1 1/2 to 2 inches of snow. Got caught at the Y when the forecast was snow after 10 pm and it started just after 9 pm with me planning on heading home at 9:30. They got me home, but I had to watch things carefully. I would not willingly want to drive them in the snow.
I'm retired so can watch the flakes come down. If you gotta be out in the snow for real, get steel wheels and snow tires and enjoy the experience.
Hoahao is offline   Reply With Quote
Old 10-05-2015, 12:34 PM   #14
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
All-seasons do nothing well, and are a menace when people try to get by on them anywhere in the snow belt. It's amazing how people will spend $3K+ on huge wheels and tires for dry driving, but then moan about having to shell out 600 bucks for a real set of mounted snows on steels. Smarten up.
The Following 2 Users Say Thank You to venturaII For This Useful Post:
hmong337 (10-05-2015), why? (10-06-2015)
Should I consider getting some all seasons? radroach Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-24-2015 01:22 AM
Automobile Four Seasons Wrap Up MarcL BRZ First-Gen (2012+) — General Topics 4 11-06-2013 06:27 PM
Automobile: 4 Seasons Test DarkSunrise BRZ First-Gen (2012+) — General Topics 0 11-28-2012 04:47 PM
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 01:49 AM
