Old 10-04-2015, 07:32 PM   #43
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
For what it's worth, at 30psi on a 62mm I never went 9's or 10's on a stock trans. You can only make so many attempts on a stock trans when you have good traction. 500+ on a supercharger, even with a good shot on it is pretty out there. You need to be trapping like 135+
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
#maverick# (10-06-2015)
Old 10-04-2015, 09:49 PM   #44
BRZ'13
BRZ'13's Avatar
Drives: subaru
I assume 10 hard pulls at 350+ torque the tranny is done.
Your better off swapping in a 2jz. Will be cheaper in the long run
BRZ'13 is offline   Reply With Quote
Old 10-04-2015, 10:08 PM   #45
spitfire481
Drives: 2JZ FRS
I got 3 passes with it bogging off the line on et street radials and lost 3rd and 4th. Killed another trans on the street.
MoTeC
Build Thread
@spitfire481
Old 10-04-2015, 10:16 PM   #46
STV3
Señor Member
STV3's Avatar
I also see you listed a clutch with a street disc that you're going to buy. That's not gonna cut it for the amount of torque you're gonna make to run 9's. You're going to need a pucked clutch, or better yet a twin disk.
STV3 is offline   Reply With Quote
Old 10-05-2015, 03:27 AM   #47
FRS Justin
Drives: 2013 Asphalt FRS
Have 20K laying around to get you started then start spending that 20k with people who know how to make a fa20 stay together. Then figure out how transfer all that power down to the ground 9s is no easy task. I went to the track to play and test my new setup nothing like boiling the tires in 5 gears and running 12s at 133mph lol
and that was only 29psi not the 35 its capable of.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Old 10-05-2015, 09:57 AM   #48
dallenj
Drives: Grey FR-S
Was you time in the low or high 12s. Just interested in seeing some other times that aren't horrible. And have you got any dyno numbers.
dallenj is offline   Reply With Quote
Old 10-05-2015, 10:01 AM   #49
dallenj
Drives: Grey FR-S
Thanks for the info but I have been looking at other Clutch setups like a twin disk but this is my street car right now. Should be picking up a new car when the engine comes out of this one. And I was uncertain what I was going to do with the trany. I saw that fbm has workeed on a supra trany conversion for this engine and they offer a twin disk.
Old 10-05-2015, 10:58 AM   #50
STV3
Señor Member
STV3's Avatar
Well to save money, instead you could go with a clutch like this http://www.advancedclutch.com/sb8-xtg6
It will hold a lot more TQ than a street disc but will still be streetable. Just takes a little getting used to. I daily drove my other car with this clutch for quite a few years and it really wasn't bad at all.
Old 10-05-2015, 11:24 AM   #51
dallenj
Drives: Grey FR-S
Thanks man glad to have some help on here instead of just being insulted.
Old 10-05-2015, 06:14 PM   #52
dallenj
Drives: Grey FR-S
http://www.forgedperformance.com.au/...-cut-gear-set/
What do you guys think about these to strengthen up the trany
Old 10-05-2015, 10:12 PM   #53
spitfire481
Drives: 2JZ FRS
They are still untested. The trans shop we deal with installed a set for another shop but they had fitment issues that had to be worked out. Guessing that's why they are on back order, Par is still sorting that out. Biggest downfall is that if you break it, you're screwed. That's why we didn't get them for testing. Our guy is working on a set from another company, a helical cut set. Timeframe is unknown. I plan on running 9's, we are doing a pretty nasty auto swap in my car for the task. The manual just won't cut it for what I want my car to do
MoTeC
Build Thread
@spitfire481
Old 10-05-2015, 10:30 PM   #54
JTOFJPN
You're like the...
JTOFJPN's Avatar
Drives: '13 6MT FRS / '14 Ram 1500 Sport
What is a dogbox
and you want to build a 9 second car?
sigh.
await my FR-S FS: thread...
2013 Whiteout 6MT FR-S
2014 Ram 1500 Sport
JTOFJPN Build Thread
JTOFJPN is offline   Reply With Quote
The Following 3 Users Say Thank You to JTOFJPN For This Useful Post:
cdrazic93 (10-05-2015), raven1231 (10-07-2015), Spartarus (10-05-2015)
Old 10-05-2015, 11:46 PM   #55
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
What it takes to get to 9sec wiht an FA20 engine
https://www.facebook.com/rolando.res...6006021160442/
http://dodsonmotorsport.blogspot.co....frs-world.html
https://www.facebook.com/EcuTek/posts/853016888138504
Vid from the old 10 sec record run showing the parts (They are still making the vid of the 9 sec pass) they have a sequential transmission as well.
Cartman is offline   Reply With Quote
Old 10-06-2015, 12:07 AM   #56
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Fiebruz sounds like a great supplier. Their coilovers have "32 levels of dampening". It really wets my appetite for a pair.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 05:52 PM
