Old 08-19-2015, 01:45 AM   #1
craigpitts7
craigpitts7's Avatar
Drives: 2013 WRB BRZ
HKS GT Supercharger v2 |BRZ DD & Track
Current as of February 2017
Name:  Velox Drive way labs splitter.jpg
October 2015
Name:  BRZ CCW D240.JPG
Modification list
Interior
Suede dash mat
TRD Shift knob
Weather Tech floor mat
HKS OB link
Beat Sonic 7" Tablet Mount
Exterior
CCW D240 18x9.5
Michelin Pilot Supersports
OEM style rear diffuser
STI Gurney Flap
Velox Adjustable Race Splitter
Velox Front Splitter End Plates
Driveway Labs Side Splitters
Suspension
Cusco front tower brace w/ brake stop
Cusco rear lower control arms (LCA)
Cusco rear toe arms
HKS Hipermax SP coil overs
Brakes
DBA rotors
Stop tech SS brake lines
Motul high temp brake fluid
Exhaust
HKS EL header w/ Catted front pipe
HKS Legamax axle back muffler
Engine
ECUTek re-flash by Delicious Tuning Flash & Go
Delicious Tuning 11 PSI Map Sensor
HKS hybrid intake filter
HKS SC oil cooler
HKS high flow oil filter
GrimmSpeed light weight crank pulley
Nameless Performance cam plate
GReddy oil plug
HKS GT Supercharger v2 - as of August 23, 2015
Exhaust clip (just in-case anyone was considering a similar setup). No CEL nor torque dip.
[ame="https://www.youtube.com/watch?v=-Mx0d4nUibE"]BRZ FRS GT86 HKS Catted Header & Legamax Muffler - YouTube[/ame]
The idea of this build is to enhance what's already there however, parts must be purposeful and somewhat proven at the track.
Name:  BRZ on way to track.JPG
Brake fade was handled by installing DBA rotors, SS brake lines, and high temp brake fluid. FYSA, the stock pads will melt a bit at the track (had to get some life out them before I installed the Hawk pads). Credit goes to FT86SpeedFactory.com for a legit brake setup.
Name:  BRZ DBA Rotor.JPG
Lateral G's increased by HKS Hipermax SPs. These coilovers out perform their looks.
Name:  BRZ HKS Cusco suspension.JPG
Well everything wasn't exactly for performance unless looks count?
Name:  BRZ engine bay.JPG
The oil cooler kept things relatively cool. After four 20min of wide open throttle there was nothing to worry about.
Name:  BRZ HKS oil cooler.JPG
Fender liner modification for oil cooler.
Name:  BRZ HKS oil cooler crate.JPG
Bumper modification to let air get to the cooler. I need to make a bigger hole. . .
Name:  BRZ HKS oil cooler cutout fog light.JPG
Checked temperature using HKS Carscope.
Name:  BRZ HKS Carscope.JPG
Installed this after rounding off the stock bolt.
Name:  BRZ Greddy oil plug.JPG
Up next, the GT Supercharger
To be continued . . .
craigpitts7 is offline   Reply With Quote
Old 08-25-2015, 08:27 PM   #2
craigpitts7
HKS GT Supercharger installed
After about 14 hours of labor, I was able to complete the install of the GT Supercharger. Keep in mind that I am by no means a grease monkey. So someone with experience can probably get this done in half the time.Name:  BRZ HKS GT Supercharger front mount.JPG
Here's a picture of the engine bay
Name:  BRZ HKS GT Supercharger engine bay.JPG
Radiator cut out. I didn't cut enough of the radiator support. Put a piece of rubber pipe to keep off metal on metal contact.
Name:  BRZ HKS GT Supercharger Radiator cut out.JPG
Larger engine bay view
Name:  BRZ HKS GT Supercharger engine bay (2).JPG
Picture of MAP sensor. I'm currently waiting on a good sensor so I drive the car. I think I received a dud.
Name:  BRZ MAP sensor.JPG
Brake vacuum hose modification
Name:  BRZ HKS GT Supercharger brake vacuum hose.JPG
Oil dip stick bracket
Name:  BRZ HKS GT Supercharger Oil dip stick bracket.JPG
Oil dip stick relocation
Name:  BRZ HKS GT Supercharger Oil dip stick relocation.JPG
This canister purge solenoid was kicking my behind. Below is a picture of it located under the intake manifold in the back of the engine. Its the hex bolt peeking out.
Name:  BRZ HKS GT Supercharger canister purge solenoid.JPG
The charger from the left
Name:  BRZ HKS GT Supercharger.JPG
Old 08-25-2015, 08:42 PM   #3
craigpitts7
HKS GT Supercharger installed cont . . .
Right side of engine bay
Name:  BRZ HKS GT Supercharger engine view.JPG
Here is a picture of the inlet pipe bracket. This is a well engineered kit.
Name:  BRZ HKS GT Supercharger inlet pipe bracket.JPG
Traction fluid tank for the charger and airbox modification.
Name:  BRZ HKS GT Supercharger air box modification.JPG
The engine bay incomplete
Name:  BRZ HKS GT Supercharger engine bay incomplete.JPG
I plan to do another exhaust clip with the supercharger installed. As of now I have to wait for a MAP sensor to come in. Hence I left the cover off.
I want to reiterate that this is a well engineered kit. It bolted up as if it was a factory part besides of the modifications to prep for the installation (that's another story). I am impressed with the fit and finish of the kit. It is superb! If only I could get a good drive . . . to be continued
Old 09-04-2015, 11:29 AM   #4
craigpitts7
Here is a short clip of the HKS GT Supercharger v2. The car runs great and the power is incredible. Delicious Tuning delivered a spectacular tune.
[ame="https://www.youtube.com/watch?v=b0_n0H8R5lk"]HKS GT Supercharger v2 BRZ - YouTube[/ame]
Driving about testing RaceRom. Warning low quality video.
[ame="https://www.youtube.com/watch?v=z28Gqk4dbV4"]BRZ HKS GT Supercharger Test Drive - YouTube[/ame]
Beat-Sonic provided the tablet mount. I'm using the Samsung Galaxy TAB 4 which was too small but a cover gave it more height to fit.
Name:  BRZ interior with tablet.JPG
Old 10-03-2015, 08:55 AM   #5
10Stars
Drives: 14 Subaru BRZ Limited WRB
Nice build. Any recent videos?
I plan on getting the V3 sometime in the future. Not sure if I should go with the HKS included Flash Editor or with Delicious Tuning(e-tune).
10Stars is offline   Reply With Quote
Old 10-03-2015, 10:26 AM   #6
craigpitts7
Thanks. HKS changed the supercharger bracket which on the v2 was very tedious to install. Maybe it will be a breeze for the v3. The tune would be a hard choice. But speaking from experience I have had zero issues with Delicious.
Sent from my HTC6435LVW using Tapatalk
Old 10-03-2015, 10:45 AM   #7
10Stars
Yeah I'm hoping with the V3 there is less cutting/modification for it to fit.
Seeing the HKS owners thread with all the failures as well kinda turned me off but im still very interested in the kit now with the revised V3.
Looking forward to your build
Old 10-03-2015, 11:13 AM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Talk about HKS fanboy! :p
Just kidding. Nice build. I have that same brake kit, and it works great.
MS, CSCS, TSAC-F, CPT
Old 10-03-2015, 01:59 PM   #9
craigpitts7
Yeah I'll admit, HKS has a soft spot for my money.
Oh, yeah the pads are insane compared to stock.
Old 10-03-2015, 02:13 PM   #10
craigpitts7
Unboxing of ccw's
Arrival at door
Name:  d240 boxes.JPG
Name:  d240 back2.JPG
Attachment 122683
Name:  d240 front lip.JPG
Name:  d240 rear2.JPG
Name:  d240 rear lip.JPG
Name:  lugs packed.JPG
Old 10-17-2015, 05:19 PM   #11
craigpitts7
Bath time
Got a chance to wash her today
Name:  WRB BRZ on CCW D240.JPG
Old 10-17-2015, 06:34 PM   #12
craigpitts7
Pictures!
Name:  BRZ D240_2.JPG
Name:  BRZ D240_3.JPG
Name:  BRZ D240_4.JPG
Name:  BRZ D240_5.JPG
Name:  BRZ D240_6.JPG
Name:  BRZ D240_7.JPG
Name:  BRZ D240_8.JPG
Name:  BRZ D240_9.JPG
Name:  BRZ D240_10.JPG
Name:  BRZ D240_11.JPG
Name:  BRZ D240_12.JPG
Name:  BRZ D240_13.JPG
Old 03-20-2016, 04:31 PM   #13
craigpitts7
Dash Mat Suede Mat
I was impressed how well the Suede Mat fit. I think it adds to a retro feel.
Old 06-17-2016, 10:14 PM   #14
craigpitts7
Road Atlanta June 11-12 2016
This was my first track event with the Supercharger. The car held up through two days of abuse without a problem.
Road Atlanta is a high-speed track and the FT86SpeedFactory brake upgrade kit held up multiple laps without any noticeable fade.
[ame="https://www.youtube.com/watch?v=9WROY1nD2Vs"]Road Atlanta - HKS Supercharged BRZ - YouTube[/ame]
daily driven, hks brz exhaust, hks coilovers, oil cooler, track build
Pixel67's Daily Driver Build - Journal pixel67 Member's Car Journals 44 06-16-2016 10:48 PM
Build Document: Autocross & Daily Driver (FR-S, Argento, M/T, Base) bimmer635csi Member's Car Journals 32 02-07-2015 12:19 PM
Daily Driver + Autocross/Track Car build on a Budget ToyoburuBRZ Member's Car Journals 29 12-19-2014 09:32 AM
Mr. Sociable's BRZ Daily Driver (slow) Build Mr. Sociable Member's Car Journals 23 11-01-2012 09:46 AM
