Old 09-29-2015, 08:28 PM   #1
Zardoman
Zardoman's Avatar
Drives: 2013 Subaru BRZ limited
How does this button work!?
Hi guys,
this is the question for those east coast/snow terrain peeps. On your BRZ/FRS, in the middle console you should have a "sport-snow" button/switch.
Can anyone tell me if it works like a 3 way rocker switch, OR its a toggle between the 2 (meaning once it is pushed, it stays "powered on")
Further explaining my question, I am hoping this button is only momentary switch, meaning the button once pushed will send the ON signal to computer, but goes back to off position after that.
I've just purchased this to modify, hoping to just wire it up like a 3 way rocker.
anyone have done this please advise.
Thanks!
Here's the link on ebay.
http://www.ebay.com/itm/331575637056
Zardoman is offline   Reply With Quote
Old 09-29-2015, 08:29 PM   #2
LWAA
Drives: Subaru BRZ
I have that in mine. I played with it a couple of times and I think you just press whichever one is on to turn it off. Press it once to turn on and once again to turn off.
Sent from my iPhone
LWAA is offline   Reply With Quote
Old 09-29-2015, 08:34 PM   #3
Zardoman
Zardoman's Avatar
Thanks,
but when you press it, does the button itself stay "depressed" or it bounces back to normal position? this is what i meant by Momentarily ON then off.
once the signal is sent, the switch bounces back to normal position until it is pressed to another mode, such is to go off sport mode and to snow or normal mode.
You can probably feel that with your finger tip after you press it, and visually see if the button is compressed.
Old 09-29-2015, 09:03 PM   #4
dalli
dalli's Avatar
Drives: Toyota
only the auto have this
snow starts car in 2nd gear and cannot go into 1st at all (if you put it in snow, it will stay in snow till you turn it off), also keeps revs low and trys to not give rear wheels too much torque for spin which can result in bad things in bad weather or fun things in bad weather.
Sport mode just hangs the revs on the high band of the rev-o-meter(), will stay on till you turn it off.
Digital signals bro :d its just like the buttons on your key fob for unlocking doors or locking. You press it but doesnt stick in and pops back up(even if not noticable).
dalli is offline   Reply With Quote
The Following User Says Thank You to dalli For This Useful Post:
Zardoman (09-30-2015)
Old 09-29-2015, 09:15 PM   #5
LWAA
Drives: Subaru BRZ
I just took a video but this will only let me upload stills. The switch moves back to the central position after you press either snow or sport.
Sent from my iPhone
Old 09-29-2015, 09:18 PM   #6
LWAA
Drives: Subaru BRZ
Hope this helps:
https://www.dropbox.com/s/7aidw1h53k...%20pm.mov?dl=0
Sent from my iPhone
Old 09-30-2015, 04:52 AM   #7
Zardoman
Zardoman's Avatar
[QUOTE=LWAA;2405531]Hope this helps:
Has anyone told you that you are awesome!?
Thanks man, this is exactly the type of button im looking for, I think I can wire this just the way I hoped.
Old 09-30-2015, 08:25 PM   #8
LWAA
Drives: Subaru BRZ
:-) no problem
Sent from my iPhone
Old 10-01-2015, 12:05 AM   #9
extrashaky
Drives: 2014 BRZ Limited
Be aware it doesn't close a conventional switch. It pushes a plastic finger that presses a rubber-clad button on a circuit board. There's a board inside the unit with all the little switch buttons mounted on it.
I'm curious what you're doing with it. I bought one myself with the thought of running a secondary horn to it, but after popping it open, I'm not sure whether I can make that work. I may rig up some separate contacts inside there instead.
Old 10-02-2015, 12:44 AM   #10
s0sl0w
Proud of Boxer
Why do people buy these cars with automatics?
s0sl0w is offline   Reply With Quote
Old 10-02-2015, 07:03 AM   #11
LWAA
Drives: Subaru BRZ
Because I hate manuals. When I left England and came to Canada 15 or so years ago and drove my first automatic, I swore I'd never drive manual again. The AT BRZ is great fun l, and I can always paddle shift if I want to, but I never have yet.
Sent from my iPhone
Old 10-02-2015, 08:02 AM   #12
Zardoman
Zardoman's Avatar
Im planning to use it as my toggle switch for my Exhaust cutout, Sport for open, Snow for closed. Thanks for telling me about the circuit board, if it is true what you are saying, i would just plan to use the top button cover and glue a 3 way rocker below it to activate it the same way.. Currently the switch came with the cutout motor is a 3-way toggle, it functions as flick up (activates motor flip the valve one way ex. "open"), then it goes back to middle; then when you want to "close" valve, you flick the other way then the switch goes back to middle again. This switch is just purely ugly and antique.
With this switch, I can keep the car stealth/oem looking, slick and keeps the cops from questioning me if they pull me over.
NYC ONLY Work Emotion Cr Kai w/ Tires and Blue Work Lugs 86_dion Wheels and Tires 12 04-21-2015 12:56 PM
new 2014 Wheels - RAYS VOLK Racing ZE40 | WORK Meister M1 | WORK Seeker Series RavSpec Wheels and Tires 8 06-15-2014 11:07 AM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 06:19 PM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 04:14 AM
