Old 09-29-2015, 01:29 AM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by caliprep View Post
I drive around without the spare tire....does that count
I do as well, I'm gonna ditch the tools and the rear seats eventually
Old 10-01-2015, 07:00 PM   #16
JEDI
JEDI's Avatar
Drives: 2015 FR-S RS 1.0 #0993
There is a Seibon Carbon fiber back seat delete for around $1800.
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In!
2015 Scion FR-S RS 1.0 - My DD , GF, and BFF!
JEDI is offline   Reply With Quote
Old 10-01-2015, 08:21 PM   #17
ravisraval
Drives: 2013 FRS
Different weight oil?
ravisraval is offline   Reply With Quote
Old 10-01-2015, 09:21 PM   #18
FRSBRZGT86FAN
There's one for $300 from shrader performance, they claim a 23 lb loss of weight but you only lose about 10-15lbs doing it though because you have to remove the seats as well as the seat belts and seat belt clips etc on your own.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
JEDI (10-21-2015)
Old 10-16-2015, 05:10 PM   #19
mortybryant
mortybryant's Avatar
Drives: Scion FR-S RS 1.0
Quick update on this.
Fuel mileage is averaging around 22mpg. Prior to my last service I was averaging 27-29mpg on 93 octane fuel. I increased tire pressure before my last fill-up because my "Low Tire Pressure" light came on. All four corners were sitting at 32psi, so I increased to 40psi. No change.
I checked both of my receipts from first and second service. The only thing different was that my first service used bottled oil, my last service used bulk oil. I've done some research, and I don't see where this would make that much difference. Thoughts???
mortybryant is offline   Reply With Quote
Old 10-16-2015, 05:45 PM   #20
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Oil level? Oil weight? An overfill can cause resistance inside the motor and a thicker oil will slow everything down decreasing fuel economy.
Problem is you can't really determine oil viscosity, tech could have grabbed the wrong gun and you wouldn't know. It shouldn't account for a ~20% drop in fuel economy, maybe 10% at the most.
ineedyourdiddly
Old 10-16-2015, 05:48 PM   #21
mortybryant
Receipt said 0w20. What's the spec for oil level? Manual said 5.7 quarts, but I've read some places that is too much.
Old 10-16-2015, 06:50 PM   #22
Impureclient
Drives: 2015 FR-S
The extra gas cost is about $20 every 1000 miles you are going from the 28 to 22 mpg. If you wait the 7K oil change interval, that is $140 extra in gas spent.
I would drain the oil and either watch them put the correct weight oil in or do it yourself.
Old 10-16-2015, 07:00 PM   #23
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
I've been losing my mpg at the exact same time I got with my girlfriend - granted I've been progressively getting fat all at the same time. Coincidence?
KalbiCool88 is offline   Reply With Quote
The Following 2 Users Say Thank You to KalbiCool88 For This Useful Post:
86geek (10-18-2015), Tcoat (10-17-2015)
Old 10-16-2015, 07:15 PM   #24
Impureclient
Drives: 2015 FR-S
Ask girlfriend to go on diet?
girlfriend -><- you
Old 10-16-2015, 07:19 PM   #25
KalbiCool88
girlfriend -><- you
Or vice versa. But that sounds about right lol.
Old 10-16-2015, 09:36 PM   #26
mortybryant
I'm probably going to change the oil this weekend myself. It's frustrating when I go out for some spirited driving and I can easily notice the fuel level going down. We'll see what happens.
Old 10-16-2015, 11:17 PM   #27
radroach
Drives: car
I had my battery disconnected about a month ago. Before my averages were about 28, now it's 26.
Also winter fuel blends typically get worse mpg's compared to summer blends. They probably started phasing in the winter blends this month.
Old 10-17-2015, 08:52 PM   #28
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by Packofcrows View Post
DC the battery for like 2min. Then turn car on, idle for like 5min, then go drive for like 20-40 hwy miles at 60mph and youll see that itll be almost 40 (36+) mpg.
Then drive it like that for a few weeks, then drive it however you want. It'll eventually get lower with your avg though.
You don't have to disconnect the battery to reset the avg mpg calculation/display.
With Avg MPG displayed, just hold the Display button down for a few seconds. The display will zero and start over, calculating and displaying MPG from the new point.
I reset mine at each fill up.
billwot is offline   Reply With Quote
WORKS BRZ/FR-S Service - Watch For Specials! WORKS Northern California 115 01-13-2017 04:40 PM
Gas mileage? Otterbrawten Northwest 28 04-27-2016 10:07 PM
Most mileage while FI Triumphrider Forced Induction 14 09-15-2014 08:27 AM
So what mileage are you getting? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 76 01-22-2013 04:23 PM
how do you get the gas mileage in you sig? EvoXDD Scion FR-S / Toyota 86 GT86 General Forum 6 07-15-2012 02:22 PM
