Old 06-04-2012, 03:39 PM   #1
blalor
Drives: WRB BRZ Limited 6MT
Hard shifting into first gear; normal?
I've got about 80 miles on my manual-trans BRZ. I'm having a hard time getting it into first gear, and 2nd seems more difficult than it should be. 3rd and 4th feel fairly normal. From a stop light with the trans in neutral, I'll put the clutch all the way in, then move the shifter into first. Most of the time the shifter doesn't want to move forward. When it doesn't want to go in, I can hear a faint whine from the transmission when I apply pressure to the shifter.
This is definitely not normal in most circumstances; is it common for a new car to need a little time before the transmission loosens up?
blalor is offline   Reply With Quote
Old 06-04-2012, 03:42 PM   #2
DantKR
Drives: Subaru BRZ LT
Sounds like you might need to get it looked at.
DantKR is offline   Reply With Quote
The Following 3 Users Say Thank You to DantKR For This Useful Post:
Guff (06-05-2012), Oilers99 (06-07-2012), Prava (06-07-2012)
Old 06-04-2012, 03:43 PM   #3
blalor
Old 06-04-2012, 03:57 PM   #4
Tainen
Drives: First SWP BRZ-L
thats the 1st gear synchro whining at you, trying to match the speed of the engine with the speed of the tranny.
Try this as a test:
in neutral, let out the clutch, push the clutch back in, and then shift into 1st. That first clutch engagement in nuetral will match the speeds, so the shift into 1st will be nice and easy.
If that works, then it's definitely the 1st gear synchro having trouble spinning up- if it's really bad, definitely get it looked at.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 06-04-2012, 04:13 PM   #5
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
I have an issue similar to this as well though I'm not going to do anything about it unless it gets worse. When I let out the clutch, push it back in and go into first, most of the time I can hear the Synchro come to a slamming halt. It equates to a clunk.
It's a little discerning.
Starscream15 is offline   Reply With Quote
Old 06-04-2012, 04:25 PM   #6
Lowellrenzo
Drives: Civic Si coupe
The same problem but with second gear
Lowellrenzo is offline   Reply With Quote
Old 06-04-2012, 04:25 PM   #7
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
All S2000's (assuming the same transmission parts) make a clunk in first gear as well. If you hold off about 2-3 seconds then put it in first gear the clunk won't happen.
I'd say it's normal, just slow the motion a bit.
But the car is under warranty, don't hesitate to take it in.
http://www.s2ki.com/s2000/topic/6141...two-questions/
Read posts #11 and #17.
86'd is offline   Reply With Quote
Old 06-04-2012, 04:30 PM   #8
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
In my experience transmission issues never "fix themselves". If you have a problem now it will only stay the same or get worse until it is fixed.
If I suspect issues with the transmission on the car I preordered then it's so long BRZ. I already know what having a mediocre tranny in a high revving low torque car is like and I won't have it again.
MmmHamSandwich is offline   Reply With Quote
Old 06-04-2012, 04:33 PM   #9
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
With the clutch still out and the shifter in neutral, blip the throttle, then push the clutch in and it should go into first easily. If everything is stopped (you've been sitting at a light for a while) you will be pushing on the synchros, which are trying to spin the gears to line them up. That's why it takes a lot of effort. If you get the input shaft moving it will do all the work for you.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following User Says Thank You to Spaceywilly For This Useful Post:
gatorac (04-14-2016)
Old 06-04-2012, 04:43 PM   #10
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
Sounds more like a clutch adjustment issue to me.
JP is offline   Reply With Quote
Old 06-04-2012, 05:01 PM   #11
MmmHamSandwich
Drives: '13 FR-S
This shouldn't be ignored. The old Si's had bad clutch master cylinders that would manifest as 2nd gear shifting problems.
Old 06-04-2012, 05:23 PM   #12
blalor
I was at the dealership when I posted this and the service manager went for a quick ride with me. Of course, first engaged perfectly every time. He said (a) there's no synchro for first gear and (b) to give it a little time for the gears to get acquainted. Driving home it felt fine. If it continues to be a problem, I'll hound them about it.
Move along, folks. Nothing to see here.
Old 06-05-2012, 03:28 AM   #13
yuli8466
Drives: MX5
Looks like another MT BRZ user. 1st Gear issue.
is this MT gearbox used in any other car? Silvia S15?
yuli8466 is offline   Reply With Quote
Old 06-05-2012, 06:23 AM   #14
Cheddar
Saving them pennies...
I have this issue also.
Cheddar is offline   Reply With Quote
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 07:52 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
Hard compound street rubber? slaxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-01-2012 07:47 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
