Old 09-28-2015, 01:14 PM   #9521
fenton
Two more PM's sent out today. Skipped two, one already has a phantom @KoolBRZ and one is boosted by Kraftwerks @JoonPrime (hope everything is great with your current boost).
Cheers all,
fenton is offline   Reply With Quote
Old 09-28-2015, 01:30 PM   #9522
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by fenton View Post
Two PM's were sent out yesterday. We will move down the list after the weekend if there are no responses.
Rev 3 kit has had some updates, mostly with ease of installation and compatibility additions for Procede:
I want to applaud @Shiv@Openflash, the procede hits all the marks when it comes to boosting our platform with a ESC. After using it for 2 weeks it is simply the best addition anyone could add to the ESC. I have been using the sport map and it is truly awesome. Sure it takes a bit of getting use to but once your brain readjusts to the new power it cannot be beat. Merging in with traffic in 4th or 5th gear is awesome, you squeeze the throttle and dial in the power effortlessly. Gone is the "too much / not enough" feeling that boosting in lower RPM ranges could bring out with the WOT switch. I have had 5 friends drive my car (they own a STI, WRX, GTI, 135i and 370z). They all loved how the power came on, no lag, no drama just smooth boost.
I urge everyone that hasnt given the procede a try to try and fit it into the mod budget, it really is great.
With that being said, almost all users of the part throttle switch have migrated to the procede and loved it. Rob is going to suggest that if a user wants the advanced partial throttle boost that they go the procede route. If the user really doesn't want the procede they can go with the standard WOT switch(at reduced cost) or the partial throttle switch(at normal cost).
The V3 kit has connections on the control box for both Procede and Throttle switch, no more need to splice into your existing connection to add the procede for ESC control. This kit also has updates to the Voltmeter(slimer) and the motor to controller connections are the biggest yet.
Thanks for the kind words Fenton. We should soon be releasing a firmware update to the Procede which will allow both generations of Procedes to use the same map files
shiv
Shiv@Openflash is offline   Reply With Quote
Old 09-28-2015, 07:33 PM   #9523
bikecarbfred
Drives: VW POLO 1.4 16v
Hi, I don't hear much talk about changing pistons to lower compression when adding the phantom electrical supercharger.
Is it because the boost tapers off at top end rpm's therefore low compression for safety zone is not required?
bikecarbfred is offline   Reply With Quote
Old 09-29-2015, 12:48 AM   #9524
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Progress on an economical Low-End Torque tune
I've been trying to achieve the best MPG I can, while getting the best power in all RPM ranges. To get a feel for how much fuel my car is using at any one time, I've been using my OFT to watch my Engine Load. I've found that anything over .6 load is uneconomical. So, I've been trying to optimize power below .6 load. All this time I've been wondering whether the ECU does it's averaging of cells vertically by RPM, or Horizontally by Engine Load. That gave me the idea to add more degrees of retard to the cells between .7 and 1.4 Load, and 1000 to 2000 RPM's that currently have zero's in them on the OFT OTS Phantom tune. My experiment worked! I got more acceleration with a lower Engine Load. More work and open road tuning followed leading up to the tune shown below that I have yet to test. I've taken pics of the stock OTS tune and my newest, untested tune and circled the area I'm working on. For any fearless drivers out there, I will soon have even better tunes for you to try out.
KoolBRZ is offline   Reply With Quote
Old 09-29-2015, 11:37 AM   #9525
fenton
YOu are right, since we are only running 2-3psi at the top end we do not need to even think about lowering compression.
The reason we are able to extract so much performance out of 2-3psi is because of the high compression. With Shiv's tunes on OFT we are completely in the safety zone for street driving. This setup is not recommended for track duty.
Most stock cars pull low 170's and boosted by only 2psi we are able to push WHP to about 210-220 depending on the quality of gas used.
That being said we are nearly at the limits of what can be done without a intercooler of some sort if boost were to be raised. Right now we are at the sweet spot of price to performance for Electrically boosted application. If Rob were to add more boost(more AMPs/Watts) the cost of the kit would be more expensive than a traditional turbo or SC.
Currently the Phantom fills a nice big gap between bolt on mods and entry level super/turbo's. Although the whp gains are certainly decent(nobody can argue with another 35 to 45hp) the biggest gains the ESC provides is a massive wtq bump in the dip(most see 70wtq or more gain).
Old 09-29-2015, 02:30 PM   #9526
bikecarbfred
@ fenton. Just for info can I ask what compression you run at?
Second question: Also if worried about high compression when boosting. Better to overfuel and run slightly richer ?
Old 09-29-2015, 03:08 PM   #9527
fenton
The FT86 is 12.5:1 compression ratio.
Shiv has it tuned so that it is safe for us to run this boost at that compression ratio.
Old 09-30-2015, 12:33 AM   #9528
Kpage
Kpage's Avatar
Drives: 2015 FRS Release Series 1.0
new to the forum
1) cost is on the first post. It changes as the kit has been modified.
I understand but where are we with the mods, V3 tq300? i'm not arguing with the price just trying to budget
2) not sure. Is there a different intake on the rs?
no the intake is the stock intake (with a TRD air filter)
3) procedes are almost always in stock so just wait until your name comes up for the phantom. (1.3 years)
Which proceed are we dealing with the 495 module or the 800 dollar tuner with the 400$ module
4) no worries
I love the solution and don't want to push the car past it's design point this seems like the perfect solution.
KP.
Kpage is offline   Reply With Quote
Old 09-30-2015, 10:22 AM   #9529
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
4) no worries
KP.
So far the cost of the kit hasn't really gone up or down, so you can budget for that to stay the same. Throw in the $500 procede and that's pretty much all you need. I'd say with the procede you don't really need the AUX charger.
You don't need the $800 tuner one, just the GT86 Procede from openflash:
http://www.openflashtablet.com/Autom...des/index.html
Old 09-30-2015, 11:33 AM   #9530
fenton
Two more PM's sent out today, flying down the list now! @zc06kisstherain Only two away now
As far as the price goes. It has changed slightly as Rob has modified/altered the kit. Depending on the activation method you choose you can save up to 100 bucks.
Old 09-30-2015, 01:44 PM   #9531
Kpage
Kpage's Avatar
Updated List
Fenton is there an updated list somewhere? I am going to put my name on it, but want to be sure funds are in place before doing so, especially if things are starting to move now.
thanks!
Old 09-30-2015, 02:16 PM   #9532
Namuna
Namuna's Avatar
Hello All!,, I am new to the forum and new to the FRS (having just purchased a '15 FRS RS 1.0. I have been following this thread for a while and have read almost all 433 pages. I know there is quite a long list of buyers at this point and wanted to get a couple clarifications before adding my name to the list.
1. total cost (not including the batteries) out the door. I would like a total budget cost on the ESC (tq250 or tq300) and proceed tuner as this seems to be the top combination.
2. has anyone added this to the RS1.0 yet? any possible glitches that you are aware of?
3. being that the two components above come from different shops and the ESC has a known wait list, how long does it take to get a proceed tuner. don't want to order until I know the ESC is ready and Vice Versa.
4. I want to thank all of the members for all the feedback its helped a lot.
Thanks in advance!
1. Currently shipping kit is "V3" with some upgrades on the controller but still the same tq250 turbine:
MUST HAVES:
* The main kit ($1850 USD + shipping, verify on the 1st page in case of any changes)
* Replacement batteries (varies based on cost of recommended batts at time of purchase. (I paid $256 shipped for my set of 3))
* A Tuner kit (~$500 + shipping for the OFT, unless you already have a Tuner kit)
OPTIONAL
* Procede ($459 + shipping)
* AUX Charger (Actually don't know how much it costs, it's not advertised on the 1st page but is an optional add-on to recharge the ESC batts faster.). I don't have it and really don't feel I need it, the batts recharge plenty fast as-is.
NOTE: If you don't already have the OFT and can get it with the Procede for $800, then that's a damned good combo price!
2. The intake is the only concern, if it is indeed stock with just a TRD filter, then you are golden.
3. Wait until you get notification that your turn on the list is coming up "soon". At that point you're still at least a few weeks out so order the OFT and Procede at that time.
Namuna is offline   Reply With Quote
Old 09-30-2015, 02:17 PM   #9533
LucidMomentum
thanks!
Most recent list is here:
http://www.ft86club.com/forums/showp...postcount=9471
Old 09-30-2015, 02:47 PM   #9534
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Finally!!! waiting for year!
MUST HAVES:
OPTIONAL
this helps me to choose some options. i probably just go with standard without AUX charger. maybe upgrading with Procede later
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
