Old 09-30-2015, 01:17 AM   #1
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
Trying to Untighten Seat Rails
So I got this Arkon Phone Mount I'm trying to install
But I need to untighten the bolt on the passenger side seat railing.
I believe it uses an 8mm, since that's the only socket that fit.
I tried forcing it to be loosen but no luck..
Any suggestions?
Thanks!
Hentai is offline   Reply With Quote
Old 09-30-2015, 06:11 AM   #2
Max FRS
Drives: 2015 Halo FRS Automatic
You need a E10 socket that fits the seat bolts. Standard sockets or wrenches will not fit. After I removed mine, I replaced all of them with standard hex-head bolts. They are tight but with the right socket, a good ratchet or breaker bar, they should come out.
Max FRS is offline   Reply With Quote
Seat Rails: My seat will no longer slide forward or backwards? Vic_RSA AFRICA 3 05-25-2015 11:36 AM
Seat Rails/Sliders TouchMyHonda Cosmetic Modification (Interior/Exterior/Lighting) 1 07-29-2013 04:47 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
Seat rails diss7 Cosmetic Modification (Interior/Exterior/Lighting) 1 02-22-2013 05:03 AM
Seat rails... poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 10 12-17-2011 08:47 AM
