Old 09-17-2015, 08:33 AM   #407
steve99
Drives: FT86
Originally Posted by Kodename47 View Post
Here's a new ROM: ZA1JF01G - EUDM 2015
Hey steve
is that rom from the my16 car that issupposed to have a few more hp, dont have a def to look at tables can ecutek see them ? be interested if thier was tuning changes or its all to o with revised intake manifold ?
Old 09-18-2015, 12:50 AM   #408
BRZ Fanboi
Drives: WRB Limited BRZ
[32pfom
BRZ Fanboi is offline   Reply With Quote
Old 09-18-2015, 02:47 AM   #409
Kodename47
Kodename47's Avatar
Drives: UK GT86
Hey steve
I don't now much more that what I said in the post. Also realised that the file was named wrong, it's an F10G.
I've just checked the AVCS, Ignition timing and fueling against an A02G. There are no differences.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-18-2015, 02:56 AM   #410
steve99
Drives: FT86
thanks,
i got an F00C usa rom and ecuflash def, theier are some rearly minor changes in knock correction max A, ol fueling and throttle mapping, cl compensation tables, so minor to be negligable.
Old 09-26-2015, 06:02 AM   #411
Kodename47
Kodename47's Avatar
Drives: UK GT86
I've gone through and updated all my definition files. I found some poorly defined idle ignition tables and I have added some tables so that many of the files are now more complete and matching across types.
Standard File Definitions:
ZA1JB01C Definition xml
ZA1JB01D Definition xml
ZA1JA01G Definition xml
ZA1JA02G Definition xml
ZA1JA01I Definition xml
Custom File Definitions:
ZA1JA01G with Metric Conversion
ZA1JA02G with Metric Conversion
ZA1JA01G with Metric Converion & Ratio Tables (ECUtek Comparison)
ZA1JA02G with Metric Converion & Ratio Tables (ECUtek Comparison)
OFT Zip Files
OFT Manual - Contains LC and FFS
US C Series OFT
ADM/EUDM G Series OFT
OFT Auto
US D Series OFT
ADM/EUDM I Series OFT
.: Stealth 86 :.
Kodename 47 DJ:
The Following 7 Users Say Thank You to Kodename47 For This Useful Post:
aagun (09-28-2015), D_Thissen (01-28-2018), HLHachiRoku (04-29-2017), keen as (08-10-2018), Spuds (05-05-2017), steve99 (10-20-2015), XCO (01-10-2018)
Old 09-26-2015, 10:00 AM   #412
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Hey steve
This one will come in the my17
Old 09-26-2015, 05:14 PM   #413
steve99
Drives: FT86
I had a quick look at the latest ZA1JF00C rom and its same tuning as previous roms bar some very minor fueling and timing changes like 0.5 degrees and 0.5 or less AFR changes in a couple of places cannot see any HP in it.
Old 09-29-2015, 04:58 AM   #414
Kodename47
Kodename47's Avatar
Drives: UK GT86
After the last complaint, I have done a complete set of cross checking and fully defining what may reasonably be required. As I possibly have the most defined G series definition, I have gone through C,D and I and defined all the same tables. The folder structure may be different to others but I have tried to stick to Romraider's native naming structure where possible. I have checked that all tables are directly comparable. The links below have been updated. The only things that I now can't define easily are the CEL codes, although if anyone needs any that aren't defined then I'll see what I can do
The main updates:
All cranking tables defined (A through to J)
All Idle Tables (A through to I)
CL/OL Delay tables specific to AT or MT
Rev Limit B
Idle Ignition Timing specific to AT and MT
Idle Throttle Targets & Failsafe
If you downloaded on my last update, I would suggest that you download again.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 5 Users Say Thank You to Kodename47 For This Useful Post:
aagun (09-29-2015), elBarto (09-29-2015), steve99 (09-29-2015), tracerit (10-14-2015), Wayno (09-29-2015)
Old 09-29-2015, 03:40 PM   #415
aagun
Drives: 86
The main updates:
Rev Limit B
no chance for idle AVCS
aagun is offline   Reply With Quote
Old 09-29-2015, 04:19 PM   #416
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not seen it defined and I don't have it on ECUtek either so can't test it. It's not really a required parameter.
.: Stealth 86 :.
Kodename 47 DJ:
aagun (09-29-2015)
Old 09-29-2015, 04:51 PM   #417
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Hey guys - I'm busy defining F10G, just been stupidly busy at work, time's at a premium...
Td-d is offline   Reply With Quote
The Following 3 Users Say Thank You to Td-d For This Useful Post:
Old 09-29-2015, 04:58 PM   #418
aagun
Drives: 86
there are in techstream as a test option , it is single controls
Old 09-29-2015, 05:04 PM   #419
Td-d
Are we talking tables, or logging parameters? Normally, AVCS is not at play during idle for a range of reasons (oil pressure not being the least of them).
If it's tables, PM me, and maybe I can help.
The Following User Says Thank You to Td-d For This Useful Post:
aagun (10-02-2015)
Old 09-29-2015, 05:11 PM   #420
Kodename47
Kodename47's Avatar
Drives: UK GT86
@Td-d feel free to update your github with my defs. They were all originally based on your latest definitions.
.: Stealth 86 :.
Kodename 47 DJ:
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
