Old 09-29-2015, 02:10 PM   #1
86ING IT
Drives: 2013 scion frs
Help choosing right size swift springs.
Hi everybody. I'm running stance coilovers right now and want to upgrade the springs to something more of a 10k spring rate but need help on the right size springs. The sizing chart on their website is confusing. So many options to choose from. Anyone done this upgrade on their coils and can offer any sugguestions?
86ING IT is offline   Reply With Quote
Old 09-29-2015, 02:16 PM   #2
swarb
Go outside, pull a wheel, and use a measuring tape.
Or read the markings on the spring and go back inside and find out what they mean.
There are just two measurements besides spring rate.
Inner diameter and length.
Why 10k? It's going to be bouncy stiff. But maybe you are slammed.
Old 09-29-2015, 02:29 PM   #3
86ING IT
Yes. Close to slammed. Right now it's at a 7k up front and 6k in the rear. Want it to be more stiff on turns
Old 09-29-2015, 02:35 PM   #4
wparsons
wparsons's Avatar
For what reason? To prevent rubbing, or for grip?
If it's for grip, going stiffer isn't going to help unless you have a better shock to dampen the stiffer spring. If it's to stop rubbing, then you'll be fine (albeit bouncy).
flickr
Old 09-29-2015, 02:39 PM   #5
swarb
Pic of car? And details of the setup? (wheels/tires/alignment etc)
How stiff are you on the shock settings?
I understand 10k is good for track or if you are slammed, but if you have a street car and on street tires, 10k is a little too much. And stiffer isn't always better.
Old 09-29-2015, 03:04 PM   #6
86ING IT
I see. Thanks for the input guys. Well currently running stock wheels, but plans are to go rocketbunny with wide wheels low offset.
Old 09-29-2015, 03:05 PM   #7
86ING IT
It's a daily driver with plans on turning it to a track car. Should I go with a 9k spring rate?
KW V3 with Swift Springs smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-17-2020 09:41 AM
WTB: SWIFT Springs iN10City Want-To-Buy Requests 1 07-10-2015 10:33 PM
Help choosing tire size Curtis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 05-28-2015 02:43 PM
RS*R vs Swift Springs SurfAndSand Suspension | Chassis | Brakes -- Sponsored by 949 Racing 90 07-12-2014 09:32 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
