Old 09-29-2015, 12:22 AM   #729
ryoma
ryoma's Avatar
how would a smog shop even tell if the tune is the CARB legal tune or an aftermarket tune if you keep the stock header/front pipe?
Old 09-29-2015, 01:08 AM   #730
s2d4
s2d4's Avatar
Originally Posted by SkiRideDrive View Post
Interesting. I don't have much experience with e85, but aren't the flex fuel lines fairly noticeable in the engine bay?
No, unless you choose to use fruit loop coloured fittings and bling lines. Otherwise it'd be discrete and literally only some twin owners will know.
The Following User Says Thank You to s2d4 For This Useful Post:
SkiRideDrive (09-29-2015)
Old 09-29-2015, 01:09 AM   #731
s2d4
s2d4's Avatar
Originally Posted by Irace86 View Post
I'm not very educated on e85 or specific CARB laws besides the basics. Is it illegal to have it setup in the car or is it illegal just to use it? Like NOS is illegal but if your bottle is empty can you still get a ticket? I understand the argument from the cop, "how do I know you didnt use the NOS on the street and thats why the bottle is empty", but if the e85 is disconnected like a fuel line or a manual switch in the engine bay then would that be legal? I'm guessing no.
Rules against e85 is dumb, we've had plenty of proven data showing e85 is better for emissions.
Old 09-29-2015, 01:38 AM   #732
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Using E85 is technically legal IF your car is originally equipped for E85 from the factory. Getting flex fuel for our cars changes the tuning and therefore is considered modified.
Newer STAR smog shops use a combo of OBD2 check and a visual inspection. I believe the modified tune will pop-up during the OBD2 check.
Oddly enough, I've looked into this myself (for work). Although E85 is proven to be better for certain emissions standards (mostly CO2), it is rated worse for others (NOX). Just so happens CA uses a combination of both, hence the current laws.
The Following 3 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (09-29-2015), Irace86 (09-29-2015), SuperDave (09-30-2015)
Old 09-29-2015, 01:43 AM   #733
Irace86
Drives: BRZ + Ducati M796
I suppose an aftermarket tune might not pass smog if it failed emissions and/or the ecu could be checked that it had a dual map or wasnt closed or something. I dont know I'm just speculating.
Better for emissions but worse on gas mileage, right? They dont like things getting worse drastically. Just my guess. So is that a no on e85 being hooked up?
Irace86 is offline   Reply With Quote
Old 09-29-2015, 01:59 AM   #734
BigFatFlip
BigFatFlip's Avatar
Not necessarily, you can always empty the tank and fill up with regular 91oct then flash back to CARB tune and be all set for inspection.
Old 09-29-2015, 02:17 AM   #735
Irace86
Thanks for the info.
Old 09-29-2015, 03:18 AM   #736
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
My 370z passed star smog with a tune last year.
clayrush is offline   Reply With Quote
Old 09-29-2015, 11:01 AM   #737
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Actually, they have no way of seeing if the car's ECU has been remapped or modified. The OBD2 check is just for readiness monitors.
The Racers Line is offline   Reply With Quote
The Following 2 Users Say Thank You to The Racers Line For This Useful Post:
BigFatFlip (09-30-2015), civicdrivr (09-29-2015)
Old 09-29-2015, 11:53 AM   #738
BigFatFlip
BigFatFlip's Avatar
Ah, good to know. I was coming from a Cobb tuned wrx, but that was several years ago.
Old 09-29-2015, 12:15 PM   #739
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Nothing to do with GT 86's, but here's my last "Edelbrock" engine. I built this and put it in a 49 Chev.
Lunatic is offline   Reply With Quote
The Following 9 Users Say Thank You to Lunatic For This Useful Post:
BigFatFlip (09-29-2015), CSG Mike (09-29-2015), Dadhawk (09-29-2015), Edelbrock LLC (10-05-2015), JohnnyP (09-29-2015), new2subaru (09-29-2015), NotSoJDM (10-06-2015), The Racers Line (09-29-2015), Yoda (09-30-2015)
Old 09-29-2015, 12:53 PM   #740
CSG Mike
CSG Mike's Avatar
It's very easy to install discretely (We like the DT with race lines). The sensors used in the FF kits are all standard sensors used in many production Flex Fuel vehicles, so it doesn't exactly look out of place.
Old 09-29-2015, 12:55 PM   #741
CSG Mike
CSG Mike's Avatar
I believe a technical interpretation of it is that it is illegal to have it installed on a vehicle that is on public roads, whether it is being used or not.
I'm not an attorney, and this is not legal advice.
Old 09-29-2015, 03:12 PM   #742
CSG Mike
CSG Mike's Avatar
Facebook discussion group here:
https://www.facebook.com/groups/1072440386107226/
Page has been parked for a while, but with the kits shipping shortly, time to get the discussion going
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
br_z1Lch (09-29-2015), Firesnake (09-30-2015), funwheeldrive (09-30-2015)
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
