#337 |
Drives: Silver Subaru BRZ
Thank you but for my first question, I mean how do I get Wayno's improved tables that are unique to the manual, if only AT roms are included in the download?
#338 |
Drives: Toyota 86 GTS
The guide indicates the best place to copy maf scales from. For US MT you would start by logging shiv's scale. There aren't any unique to manual anymore.
#339 |
#340 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#341 |
Drives: 2013 whiteout frs
Copied over tables from waynos Stg2 Stock E85 v86 A01I to my A00C. I'm learning all this for the first time so there were a couple questions I came across.
1. Cranking Fuel Injector Pulse Width F (ECT) When I copy this table over, the values on the top of the table keep reverting back to its original. (I pasted the table to get 32 all the way across, save the file and when I reopen it does not remain) 2. Base Timing Idle (In Gear)(Below Speed Threshold) The tables are different sizes. How would I go about changing this? I have read and searched the threads thoroughly before requesting for some help so hopefully someone can offer me some guidance. Thanks! |
#342 | |
The definition and/or the values for the EU roms for Cranking F are incorrect. That should be obvious looking at a US rom with and axis that makes sense and an EU rom with 0 the whole way along the axis. (The rest of the world uses metric guys). Don't copy values that look wrong over values that look correct. I'm going to remove that F table from the list. Please don't touch you region and/or transmission specific tables not on the list. |
| The Following User Says Thank You to Wayno For This Useful Post: | bizintine (09-28-2015) |
#343 | |
#344 |
Still 17!
Drives: 2014 Silver BRZ Limited
Cranking fuel injector pulse width f (ECT) is specified under "Tables changed for E85".... It won't copy. I took that to mean it SHOULDN'T copy!! So I left it.
I see no EU, MT, US, or AT designation......I had trouble with this too. It's just a learning curve I guess. (I did not do the "Total injection ratio port cold, warm, hot maps because it says its for MT)
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
![]() Last edited by MGPAX; 09-28-2015 at 10:45 AM. |
| The Following User Says Thank You to MGPAX For This Useful Post: | bizintine (09-28-2015) |
#345 |
Drives: UK GT86
Use the definitions that I posted above. I have corrected this issue, all the cranking data is the same across all the ROM types.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | bizintine (09-28-2015) |
#346 | |
That's because you're missing the "B" table and have the rest mislabeled. People have enough trouble without having to try to figure out tables that all have different names and are in different categories than the ones available on github and openflash and that in no way match the screenshots in the thread. |
#347 |
Drives: UK GT86
OK, don't use my definitions..... links removed from the thread.
The reason B is missing is because the 2nd cranking table in the ROMs is missing from your definition and is actually 3 rows. But seeing as the tables all match up when you compare them it was easy to copy across. My bad...
.: Stealth 86 :.
#348 |
Drives: 2014 GT86
It would be nice to get THE one location with most complete and up to date definitions that all, including OFT/Shiv, romraider crowd, Wayno, Steve and rest, agreed to use/submit updates/refer to other users. It looks too messy & inconsistent otherwise :/
| The Following User Says Thank You to churchx For This Useful Post: | Chimera (09-28-2015) |
#349 | |
The wrinkle with OFT is that it fakes CAL IDs so is not immediately compatible with other definitions.
#350 |
Drives: 2014 GT86
phrosty: many places may exist. Such site/place is nothing if almost all most influential persons at OFT tuning doesn't agree on it as main reference site for that. And that agreeing/deciding on is what i wish to lessen mess, whichever one site they agree upon at the end.
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 10:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 11:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 01:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 06:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 05:26 PM |
