Old 09-25-2015, 06:58 PM   #1
itsjustdavep
itsjustdavep's Avatar
Drives: Asphalt Scion FR-S
Post Exhaust install
Hoping its just something loose. but im getting the massive shake/rattle you'll see below whenever my AC is on, and whenever i come off the throttle.
ive read its possibly the throwout bearing?
[ame="https://www.youtube.com/watch?v=unTe6RwqQTE"]https://www.youtube.com/watch?v=unTe6RwqQTE[/ame]
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
itsjustdavep is offline   Reply With Quote
Old 09-25-2015, 07:02 PM   #2
itsjustdavep
You can hear it better here. [ame="https://www.youtube.com/watch?v=XIUybrx3SHg"]https://www.youtube.com/watch?v=XIUybrx3SHg[/ame]
Old 09-25-2015, 07:28 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
What exhaust components did you just install? Sounds like you need to get back under there and recheck everything. Either something was left loose like you said or you don't have proper clearance around the new exhaust parts.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
humfrz (09-25-2015)
Old 09-25-2015, 07:39 PM   #4
itsjustdavep
so installed my tomei header myself a month ago. no noise.
got my tomei OP and FP installed by Circuit Motorsports two weeks ago. noise started but i didnt think anything of it.
last friday installed my muffle delete. noise got LOUD under decel.
but it gets BAD when i turn my AC on so im lost
Old 09-25-2015, 07:48 PM   #5
BirdTRD
Simply Forgotus
BirdTRD's Avatar
My guess would be at the overpipe. Not a lot of clearance there. Did you loosen your motor mount from the sub frame to jack up the motor when you installed the OP? Tighten it back down to spec? I think the AC and muffler delete are just amplifying the real problem, not the cause of it. Pull the OP and front pipe back off if you have to and look for signs of rubbing.
Old 09-25-2015, 07:49 PM   #6
itsjustdavep
I had a shop do the install my floor jack wouldn't go high enough for me to do the OP install myself. guess I'm gonna have to bring it back to them
Old 09-25-2015, 08:02 PM   #7
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yeah sorry, I missed that part. Definitely take it back and have them check it out cause whatever it is, it ain't right! But I'll bet a dollar it's related to the OP/FP install.
Old 09-25-2015, 08:12 PM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Isn't @Circuit Motorsports a vendor on here? I'm sure they would be more than happy to take a look at it!
itsjustdavep (09-25-2015)
Old 09-25-2015, 08:15 PM   #9
itsjustdavep
I COULDN'T FIGURE OUT HOW TO TAG THEM. OMG THANK YOU LOL
Old 09-26-2015, 02:28 PM   #10
itsjustdavep
Ok so. Got underneath. Retightened everything to spec. Left my shields off and drove around. Still hear the noise. But only when I come off throttle. Could it be a massive back pressure surge? I'm still running the stock midpipe
Old 09-26-2015, 02:37 PM   #11
itsjustdavep
I think I found the issue. Resonator sitting practically inside the tunnel. Might this be the problem??Name:  uploadfromtaptalk1443292676724.jpg
Old 09-26-2015, 03:07 PM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by itsjustdavep View Post
I think I found the issue. Resonator sitting practically inside the tunnel. Might this be the problem??Attachment 121202
Most definitely adjust it if possible, otherwise I would put some sort of High temp rubber or dampening between the tunnel and resonator
Old 09-26-2015, 04:04 PM   #13
itsjustdavep
Demon noises have subsided! Thanks everyone
The Following 2 Users Say Thank You to itsjustdavep For This Useful Post:
edeekeos (09-26-2015), FRSBRZGT86FAN (09-26-2015)
Old 09-26-2015, 05:54 PM   #14
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
If you are still having issues or want us to take a look at it just give us a call and we can schedule you in.
We normally take any car we work on for a road test before giving it back to the customer so if this was an issue that wasn't noticeable at the time or we didn't see/hear we apologize! If this arose after it left our shop, or just got more noticeable over time the best thing to do is just let us know so we can try and fix it for you.
Either way let us know and we'll be happy to help!
Circuit Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
BirdTRD (09-26-2015), itsjustdavep (09-26-2015)
OFT reflash post intake install? dar3d3vil Software Tuning 13 04-06-2015 11:43 PM
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 05:20 PM
Post Your Exhaust Set Up video/sound Simok Engine, Exhaust, Transmission 2 10-21-2014 06:27 PM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
ECU reset post aFe Takeda CAI install APS86 Engine, Exhaust, Transmission 4 12-16-2012 10:49 PM
