AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Sway Bar Upgrades
Does anyone know the part number for the stock rear sway bar for a 2010 Forester XT? It's 17mm and apparently is a direct swap. Not a crazy upgrade but cheap! I want to give it a shot before I go crazy for aftermarket bars (which I know I will)
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson |
#2 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
The rear bar in the BRZ/FR-S is 14mm. Going to 17mm is a big bump in roll stiffness. The Cusco aftermarket bar is only 16mm. You'll end up pretty tail happy.
#3 |
Drives: race cars
that stuff can be tuned out. for low speed autocross, I'd want a looser rear and then tune it out with toe settings...
but someone needs to try to see if it works.
#4 |
We're planning on testing 16, 17, 18, and 19mm rears. And then again when we have a front to test as well. Also need to do some math when I have more time.
- drew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#5 |
AutoX Addict
Is there any stock bar that will fit that is 16mm?
#6 |
Yes, the current WRX rear I think is 16mm.
- andrew |
#7 |
Kuruma Otaku
Am I doing this right? If lever arm length, attachment point, bar total length and hollow/solid remain the same, and only the diameter increases, will the stiffness increase be (NewDiameter^4)/(OldDiameter^4), so ~ 70% more roll stiffness for a 16mm bar?
Because titanium. |
#8 | |
Rocket Surgeon
Drives: PSM GGA OMG
Actually it will probably end up being a tiny bit more than that, due to reduced deflection in the lever arms. |
#9 | |
Kuruma Otaku
This weekend I'm going to try to see if I can understand David Gould's roll/weight transfer stuff.
Because titanium. |
#10 |
Rocket Surgeon
Drives: PSM GGA OMG
#11 |
Kuruma Otaku
I'm going to try and figure out the front first. 1:1 for both... I was using .8 in the back before, but RCE says ~ .75. So my eyeball wasn't too far off. Will have to see about the rear bar's motion ratio next.
Because titanium. |
#12 |
Drives: 2005 Subaru Legacy GT Stage 1
Those looking for A VERY CHEAP 16mm rear swaybar upgrade. Check out the 10+ Legacy GT rear sway bars. They are the same as the STi which shares the BRZ platform. Guy on my forum selling them for $25
http://legacygt.com/forums/showthrea...la-179658.html |
#13 |
Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
Does anyone think that maybe the stock rear sway bar should be left as is, and only the front should be stiffened up? I ask because i would think a stiffer rear sway bar would increase an already present oversteer.
#14 |
You would think so, but its drivers preference. I have always driven nothing but subarus. EVERY subaru understeers like a pig. So the rule of thumb was always bigger rear bar, but thats my preference. I think a bigger bar upfront as well as a 17mm adjustable rear bar to dial in preferance would be good.
| Cosworth Internal Upgrades Confirmed | DanPO | Engine, Exhaust, Transmission | 60 | 05-26-2015 05:45 PM |
| adjustable sway bars!!! | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-04-2012 08:42 AM |
| STI rear sway bar | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-25-2012 12:58 PM |
