Old 09-25-2015, 11:20 PM   #379
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
best to leave the default values in tool
excapt maybe iat max set it to maybe 100f so it throws away high intake air temp data
So I have to change the cl/ol because default is -1. Assumed it was looking for the break so set it to 2
I will reset the maf volt to 5 rather than 3 but my entire to is in cl.
Thanks for the help
RustySocket is offline   Reply With Quote
Old 09-25-2015, 11:29 PM   #380
steve99
Drives: FT86
Thanks for the help
ol cl transition should be arround 3v maybe 3.2 v
closed loop fueling mode is 2
open loop is 4
make sure your not logging injection mode that is port\direct injection.
Old 09-26-2015, 03:48 PM   #381
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@steve99 this is probably a dumb question, but how do you past from excel into RR? Edit > paste doesn't seem to be working for me...thanks!
1Cor10:23 is offline   Reply With Quote
Old 09-26-2015, 04:49 PM   #382
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What if you only want to process high intake temp data? That would be cool if they also had a min temp setting as well. Can come in useful for tuning for high temp and to do MAF IAT compensation tweaking for specific temp ranges.
Intent > Content
Old 09-26-2015, 05:00 PM   #383
steve99
Drives: FT86
You can cut and paste maf data from VGI tool directly but it does not work from excel to romraider directly.
but you can copy from excel to vgi tool then to romraider.
Old 09-26-2015, 05:01 PM   #384
steve99
Drives: FT86
you could always suggest that to @vgi he may mod the utility
Old 09-26-2015, 05:04 PM   #385
solidONE
solidONE's Avatar
You interact with him more, you ask please. I'm shy... lol
Intent > Content
Old 09-26-2015, 05:14 PM   #386
RustySocket
Slow Learner
Drives: 15 Halo FRS
@steve99, on the vgi tool once you generate the new maf scale and go to the chart page, do you use _copy_ or _copy romraider_ after selecting the cells? What is the difference between the two copy functions ?
As always I appreciate your help and all that you contribute to the forum.
Old 09-26-2015, 05:21 PM   #387
steve99
Drives: FT86
copy_romraider will allow you to copy/paste directly to romraider
copy will only allow you to copy to excell or notepad ect.
Old 09-26-2015, 05:21 PM   #388
RustySocket
Slow Learner
Drives: 15 Halo FRS
open loop is 4
Yeah, I'm logging OL/CL and not injection mode. I logged about an hour of closed loop data yesterday. One thing became apparent, OL would kick in and out depending on how hard I pushed on the throttle. But even if I accelerated as slow as possible (using cruise control to increase speed) once MAF voltage hits 3.0 it goes to OL no matter what else was going on.
When selecting my filters for closed loop data it seemed reasonable to use 3.0 V max on the VGI table. My intention was not to stack multiple logs with OL/CL data mixed but to only attempt to collect closed loop data and scale that first.
Old 09-26-2015, 05:23 PM   #389
RustySocket
Slow Learner
Drives: 15 Halo FRS
That's kind of what I thought. It was late and I was trying to figure it all out. Do you have to select all the cells in the vgi tool and then copy_romraider to get the whole table or is the whole table selected by default.
Old 09-26-2015, 05:35 PM   #390
steve99
Drives: FT86
yep just select all cells and copy_romraider
Old 09-26-2015, 06:04 PM   #391
Kodename47
Kodename47's Avatar
Drives: UK GT86
The reason you can't copy Excel direct to Romraider is that it expects the top left cell to contain [Table2D]. You can use excel if you offset the top row 1 to the right and add that in. It'll look odd at the 2 rows won't line up but it'll work Obviously the Copy Romraider option does that for you. See what happens if you do that and then paste to Excel....
You'll never get a log with just CL. There are multiple reasons the ECU switches to OL. Throttle angle, speed and the OL fuel map are all factors. Realistically I doubt you'll get much reliable data above 2.5V.
@solidONE just use the log stats screen if you want to start playing with IAT compensations. I do everything in that tab, including MAF changes. It's quite powerful.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-26-2015, 06:24 PM   #392
1Cor10:23
1Cor10:23's Avatar
Anyone have a direct link / mirror to VGI tool? RR website is down...thanks!
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
