Old 09-24-2015, 12:39 PM   #15
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Originally Posted by Timmy_Jones View Post
Any word on their tuners working with a header already installed on the car?
The calibrations supplied in the Flash Editor (and the dyno results) were generated using the required HKS Spark Plugs, HKS Stainless Exhaust Manifold, HKS Stainless Center Pipe, and HKS Hi-Power Spec-L exhaust. I'm confident a comparable header/manifold will still work with the pre-loaded calibrations however, the degree of difference in performance vs. the HKS manifold will be the degree of difference in driveability and output. Of course you can always have one of our Pro-Dealers tweak or create a custom cal. for you.
Originally Posted by uspspro View Post
@Scott@HKSUSAScott - Any chance HKS USA will get it thing CARB EO'd?
It's been discussed but at the moment there is no schedule for certification.
Scott@HKSUSA is offline   Reply With Quote
The Following 2 Users Say Thank You to Scott@HKSUSA For This Useful Post:
Timmy_Jones (09-24-2015), ultra (09-25-2015)
Old 09-24-2015, 01:33 PM   #16
Timmy_Jones
Spun
Drives: 23' Supra
Thank you, Scott. Is the HKS 'Exhaust Manifold' an Equal or Unequal Length header? or is it a manifold? Do you guys run a cat?
I have the Tomei UEL Uncatted header and Tomei Overpipe.
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Egyptn (09-27-2015)
Old 09-24-2015, 01:49 PM   #17
Scott@HKSUSA
No cat, UEL:
http://www.hks-power.co.jp/en/produc...haust/db/15331
The Following 3 Users Say Thank You to Scott@HKSUSA For This Useful Post:
CxG (10-28-2015), Egyptn (09-27-2015), Traktor (12-27-2016)
Old 09-24-2015, 01:53 PM   #18
djdnz
1337
Drives: 2013 BRZ WRB S/C
I was interested in the HKS V2, until I read the difficulties the people who had them had when they broke down. It seemed very difficult and costly to get a replacement blower from HKS - are you guys doing anything to streamline the replacement process? Is there a warranty?
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Yoda (09-24-2015)
Old 09-24-2015, 02:56 PM   #19
Scott@HKSUSA
All HKS products have a warranty valid for the territory they are sold in. So if you're in the USA, and you buy a HKS product from a US retailer, your warranty is valid through the retailer you purchased it from.
If you're in the USA and you buy a HKS product from a shop in Japan (for example), you'll have to pursue a warranty case with that shop in Japan.
If you're in Russia (for example) and import a HKS part from a distributor in Japan, you'll have to pursue your warranty case with that distributor in Japan. There's no way for anyone outside that territory to intervene or help.
Our objective isn't to run anyone through a ringer if there is an issue, but we do have to follow the rules and verify legitimacy case by case. And to date, there have been 0 HKS s/c failures in the USA.
Old 09-24-2015, 03:43 PM   #20
Lee
Drives: GT86
How much bigger is the intercooler? the picture on HKSusa site of the 'kit' looks exactly like the V2.
Lee is offline   Reply With Quote
Old 09-24-2015, 04:11 PM   #21
Scott@HKSUSA
The core is thicker, but I don't have a spec from Japan and my car is on a trailer somewhere between MI and CA so I can't measure at the moment
Old 09-24-2015, 04:18 PM   #22
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Money shots of the install? Dyno charts? More info?
JazzleSAURUS is offline   Reply With Quote
Old 09-24-2015, 06:06 PM   #23
Binary_fission
Binary_fission's Avatar
Drives: FRS
If it's not carb certified no point. I'm speaking for people in CA...
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 09-24-2015, 06:08 PM   #24
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
some people like to live dangerously.
Build Thread
Instagram
Old 09-24-2015, 08:13 PM   #25
kch
Senior Misanthrope
kch's Avatar
Roughly 90% of people in the US live outside of California, so....
The Following 2 Users Say Thank You to kch For This Useful Post:
Shit Luck (09-26-2015), Trap63 (09-30-2015)
Old 09-25-2015, 03:59 AM   #26
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
...And to date, there have been 0 HKS s/c failures in the USA.
Did you actually sell any V2s officially in the US? Earlier on this forum it was mentioned that HKS is making V3 for release in the US and V2 was not supposed for the US market.
Also, I'm curious why HKS switched back to the original V1 design of the blower if V2 was so good?
Efferalgan is offline   Reply With Quote
Old 09-25-2015, 06:42 PM   #27
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Still not 100% certain at this point, based on the info here or on the HKS USA or JP websites, whether the flash kit tunes available for the v3 supercharger are intended work with both cats removed or only one.
I ask because on the HKS websites themselves I see various options for exhaust manifolds with and without hi flow cats, plus an 'R type' or 'super exhaust' version which uses no catalytic converter in the header itself but one it in the front/centre pipe.
http://www.hks-power.co.jp/en/produc...ust/index.html
It'd be great to know for sure what type of exhaust + cat (or completely cat less) combo the included tunes are intended to work with.
Fully understand that you guys won't be able to confirm that the flashable tunes will work with each and every permutation and combination of aftermarket exhaust parts out there but if you could please at least double confirm the exact specs of the exhaust components that the included flashable tunes were designed to work with (part numbers/specs/cats etc.) then it'd make it tons easier for folks to determine whether their own exhaust setups would work with the flash kit tunes or not.
Sorry to be pedantic but knowing whether or not the HKS flash option will work with my HKS exhaust setup (I have the header + exhaust combo 'SUPER EXUAUST SYSTEM' on the JDM website) would be a major purchase decision point for me personally.
I like the refinements that have been made since V1, the price is very competitive and I have been looking for a quality FI kit that comes with dealer/out of the box tunes that will work with my (decatted) exhaust setup for EVER - literally years. If this is indeed such a solution then you will have made my year and will take my money.
Assuming that these flashable tunes in question here are NOT Ecutek?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 09-26-2015, 05:38 PM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
I believe their system with the optional OTS tunes will include a device similar to the OFT with several pre-calibrated tunes. The catback is not vital to a tune and most likely it will include calibration for both the first and second cat deleted.
The Following User Says Thank You to wbradley For This Useful Post:
ultra (09-27-2015)
supercharger help... sosick Forced Induction 25 08-15-2013 11:02 PM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 06:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 10:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 10:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 03:11 PM
