Old 09-24-2015, 12:33 AM   #1
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
Hissing/rattle from 3.5-4k RPM after OFT
Hey guys
Running Stage 1 program on the OFT. I have a TRD catback. After 1 tank of gas I've noticed its very nice, open and smooth. Sounds a lot better too.
However from 3.5-4k RPM I notice what sounds like a rattling from under the hood. It's so short in duration thats almost like a hissing sound...
Any thoughts on what this could be? Is it a boxer thing? Airflow changes? Should I be concerned? Any ideas on how I could investigate/check it out further?
Much obliged gents...
illmatic_frs is offline   Reply With Quote
Old 09-24-2015, 12:50 AM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
AVCS. all vendors do it for stg1 to reduce the dip
Old 09-24-2015, 10:01 AM   #3
Shady195
Drives: '13 10 Series FRS #1203
AS stated, its the cam timing. Tuners make it very aggressive to help with the dip. It's a resonance, nothing serious or anything to worry about.
Shady195 is offline   Reply With Quote
Old 09-24-2015, 11:36 AM   #4
illmatic_frs
Drives: n/a
Excellent. thanks for the confirmation
I actually like the sound.. Very addictive :-)
Sent from my HTC One M9 using Tapatalk
Old 09-24-2015, 11:39 AM   #5
kch
Senior Misanthrope
kch's Avatar
To expand on the previous answers, the tunes for EL headers (including stock with the OFT stg1) will have that aggressive cam profile. Tunes for UEL headers don't make that noise.
Old 09-24-2015, 11:41 AM   #6
illmatic_frs
Drives: n/a
Ahh Ok good to know.
Will gladly exchange the 2 seconds of resonance for some o dat UEL gurgle ;-)
Old 09-25-2015, 09:03 PM   #7
Griever423
Drives: 2020 BRZ PP
The UEL tunes absolutely make the same noise. Mine does it right at the same RPM the OP mentioned. Emails to Shiv confirmed this. Running OFH and OFT.
Basically it's nothing to worry about. It's pretty annoying though.
Griever423 is offline   Reply With Quote
Old 09-28-2015, 12:19 PM   #8
kch
Senior Misanthrope
kch's Avatar
Weird. I had the noise when i was on stg1 with stock header, but now that I'm on stg2 with a catless UEL, the noise is gone.
Old 09-30-2015, 10:52 PM   #9
Griever423
Drives: 2020 BRZ PP
I'm not running an OP or catback. Maybe it's just more audible since there isn't as much noise?
Old 10-01-2015, 12:43 AM   #10
steve99
Drives: FT86
I would check you actually running the UEL tune as the cam timing are different in the UEL tune so it should not make the raspy noise arround 4000.like the EL header tune or stage 1 tune.
The noise may also be the overpipe or some other exhaust component loose or hitting on subframe or skid plate or plug up the sound tube
Old 10-01-2015, 01:59 AM   #11
breadcrumbz
breadcrumbz's Avatar
Drives: 2013 FR-S 6MT
I've been running stage 1 oft tune for about half a tank and haven't noticed any noise difference in my nameless axleback. Only difference I can feel is maybe a little smoother 1st gear. Will the car and exhaust be feel and sound smoother after a full tank?? Also, the dead pedal effect is still slightly there, but not as bad as right after a fresh flash.
breadcrumbz is offline   Reply With Quote
Old 10-01-2015, 11:53 PM   #12
Griever423
Drives: 2020 BRZ PP
I have wondered about the rattle. Maybe it's time to get the car back up on the lift.
Old 10-02-2015, 12:04 AM   #13
themajesticone
themajesticone's Avatar
Drives: '13 UM86
There's a snake in your boots
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 10-02-2015, 10:18 PM   #14
Griever423
Drives: 2020 BRZ PP
Checked last night and it is the UEL stg 2 tune. Running the Grimmspeed intake so no sound tube. The noise is definitely metallic in sound. There is some hissing noise too but normal for an aftermarket header from what I can tell. The metallic rasp is what bothers me. It's pretty loud. It's noticeable upon acceleration but VERY noticeable upon decel.
Anyone else's 6MT a rattle box at low RPM? Silver Ignition Scion FR-S / Toyota 86 GT86 General Forum 81 05-29-2014 11:56 PM
Rattle above 5k rpm trippinbillies40 Issues | Warranty | Recalls / TSB 1 05-28-2014 02:55 PM
AC Rattle AVodka14 Issues | Warranty | Recalls / TSB 8 05-21-2014 12:08 PM
Anybody Have this Buzz/Rattle? Gary in NJ BRZ First-Gen (2012+) — General Topics 8 10-07-2013 12:36 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
