Old 09-18-2015, 09:53 PM   #3613
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by EquiFox View Post
First one lasted 5000 miles and second one 1600. Standard C30-94 kit. All oil lines are good and everything was checker by my tuner... whine like crazy so annoying I drive my beater now.
Whining normally points to over to tighten belt.
Sent from my XT1575 using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 09-18-2015, 10:08 PM   #3614
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by wahsaihin View Post
No problem. Airboy is a very reputable tuner and he says this is about right for the setup I have. Gains are as advertised by KW considering our lower quality gas. Another guy tuned by him with the c38 and similar mods was 258 whp. I won't lie though, they don't call it heartbreaker dyno for nothing .
My FR-S with C-38 was tuned on the same dyno by the same tuner 4 weeks ago
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 2 Users Say Thank You to Apoc For This Useful Post:
Freeman (09-23-2015), wahsaihin (09-18-2015)
Old 09-23-2015, 04:31 PM   #3615
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
for those wondering, the Racer X Fabrication oil cooler spacer fits!
Freeman is offline   Reply With Quote
Old 09-23-2015, 05:59 PM   #3616
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Right over the oil fill cap. Out of the frying pan and into the fire haha. I'm sure you'll make it work. That area is so cramped, there just isn't a good solution.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Old 09-23-2015, 06:03 PM   #3617
Apoc
Apoc's Avatar
We need an oil fill cap adapter now.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
Old 09-23-2015, 06:11 PM   #3618
Freeman
Freeman's Avatar
lol yeah that big supercharger bracket gets in the way of good routing/mounting options But this will work for me.
Old 09-24-2015, 10:49 AM   #3619
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Originally Posted by rj101592 View Post
Mine- Tomei uel header, berk overpipe/catted midpipe/invidia n1 catback..c30 13psi 311whp/221tq
His- Borla Uel/not sure on the rest of his exhaust.. Vortech SC, 9psi, 298 whp
U hv a sound clip for ur exhaust system?? I might go the road and just want to kW how it sounds like lol
scionfr_s is offline   Reply With Quote
Old 09-24-2015, 10:58 AM   #3620
zoth
zoth's Avatar
Your leaking issue was at the bottom though, right. Because I'm dealing with the same issue. Changed fittings already but still leaked. Now they send me new hoses, I just don't have enough time to work on it right. The SC and cooler are just too high maintenance for me. I just can seem to set it and forget it.
Old 09-24-2015, 11:04 AM   #3621
Freeman
Freeman's Avatar
It was leaking at the bottom of the spacer, at the fittings for the oil lines, the oil lines blew off and blew oil all over the engine bay, down the side of the car and underneath the car, and it leaked at the fittings on the cooler itself. I took it off and decided to go my own route. Both SC and oil cooler are high maintenance systems in my experience
Old 10-07-2015, 11:32 PM   #3622
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
What brand of header r u guy using the most with the SC?
Old 10-17-2015, 12:18 AM   #3623
jackblack21
Drives: red scion frs
Hey guys. A reputable Garage here in alberta recommends the Kraftwerks Super charger for my FR-S. I have a few questions.
I want this car as my daily and I don't really want a ton of boost 30-40lb of torque across the power band. would be my goal.
Can this system be winter driven?
How does it work on low compression with 91?
Thanks in advance.
jackblack21 is offline   Reply With Quote
Old 10-21-2015, 12:54 PM   #3624
zoth
zoth's Avatar
Stick with the Carb tune you should be okay with 91. I DD mine.
Old 10-21-2015, 12:57 PM   #3625
Freeman
Freeman's Avatar
Drove mine in the winter when the snow wasn't out, no issues.
Not sure what you're asking about how it works on low compression with 91. It does work on 91 octane, their CARB tune should work for you. If you're doing low compression pistons and 91 octane then I don't know because I haven't seen anyone do that yet.
Old 10-25-2015, 01:55 PM   #3626
mscamp02
Drives: 2013 FRS
I recently sold my 71 firebird so I could go FI on the frs. And have bounced all over the map on how I want to do it.
Originally I wanted the c38 kit but now I am leaning towards just the c30 because it's available for 4.45k with ecutek/canned tune from rickspecd.com. so I thought about taking the cash savings over the c38 to upgrade my exhaust completely from header back with a 2.5 in system (no idea on brand or combination but needs to be semi quiet).
I don't really want to stick with the canned tune and I Wil be doing the install myself so I am contemplating the flash n go or driving it on the canned tune to dynosty two hours away and having them tune it (i just don't like the idea of having to drive/haul two hours for issues). My goals are reliability and somewhere north of 250 or 270hp (reason why I'm not going with the c38).
Anyone have any ideas on tune or how I should go about it
Sent from my VS985 4G using Tapatalk
mscamp02 is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
