Old 09-23-2015, 05:51 PM   #1
Teeeg28
Drives: SWP BRZ
+100 Turbo Kit Review from CrawFord Performance
Got to test drive their new kit. I have to say for the price and performance you get out of it...Im very impressed
[ame="https://www.youtube.com/watch?v=2EU8iP9FCV8"]Turbo BRZ Review | +100 Crawford Turbo Kit - YouTube[/ame]
Teeeg28 is offline   Reply With Quote
Old 09-23-2015, 06:41 PM   #2
kbye
kbye's Avatar
Drives: 2014 FR-S
There's tons of turbo kits in that price range or cheaper that run intercoolers. It's just a bad idea in general to omit one because you're increasing the risk of knock.
Lemme put it this way, if a cheapass CX racing turbo kit has an intercooler, there is no excuse Crawford shouldn't include one.
kbye is offline   Reply With Quote
The Following 9 Users Say Thank You to kbye For This Useful Post:
-Phil (01-11-2016), ajcarson11 (09-23-2015), ATL BRZ (09-24-2015), BRZoomTX (09-23-2015), Decay107 (09-23-2015), hmong337 (09-24-2015), shu5892001 (09-24-2015), solus (10-12-2015), Sportsguy83 (09-24-2015)
Old 09-23-2015, 06:49 PM   #3
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I have to say... Crawford makes me nervous. I don't understand why their dyno graphs are posted in crank figures when everyone else posts WHP and WTQ figures. Seems slightly dishonest to me. When asked about it elsewhere, their response was 'You can't be serious'.
This kit should be pushing more than 100hp on E85 as well, I must be honest. For the price it really isn't putting out numbers comparable to others in the price range.
Some may like this, but I don't understand the real idea behind this unit. Not to be negative! Just my thoughts...
ajcarson11 is offline   Reply With Quote
Old 09-23-2015, 07:45 PM   #4
Teeeg28
Drives: SWP BRZ
This is true. Although, they do offer a intercooler option to the kit if wanted.
Old 09-23-2015, 09:10 PM   #5
CSG Mike
CSG Mike's Avatar
Crawford's own dyno shows a 200hp baseline (okay slightly less) and about 280 with the turbo.
Are these crank figures, or are both plots on E85? Either way, that's a pretty marginal gain for running 12psi. The greddy kit makes more power, on 91, with less boost, which to me, means less risk.
Also, based on pics, it looks like the charge pipe runs over the oil filter, so.... can you even fit an oil cooler with this thing?
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
10Stars (09-24-2015), ajcarson11 (09-23-2015), ATL BRZ (09-24-2015), solus (10-12-2015), Sportsguy83 (09-24-2015)
Old 09-23-2015, 09:12 PM   #6
ajcarson11
Crawford admitted... these are crank figures. Seems deceiving... huh?
Old 09-23-2015, 09:15 PM   #7
CSG Mike
CSG Mike's Avatar
Name kit +100, really adds 91, and requires E85.
What happens for those that don't have E85?
Old 09-23-2015, 09:29 PM   #8
kbye
kbye's Avatar
Drives: 2014 FR-S
Probably can't run pump gas due to high IATs. If only there were some method to cool the hot air
The Following 11 Users Say Thank You to kbye For This Useful Post:
ajcarson11 (09-23-2015), ATL BRZ (09-24-2015), cdq85 (10-01-2015), CSG Mike (09-23-2015), DocWalt (09-24-2015), flippy (09-24-2015), hmong337 (09-24-2015), kanundrum (10-01-2015), kch (09-24-2015), Njnickd (10-09-2015), Sportsguy83 (09-24-2015)
Old 09-23-2015, 10:31 PM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
IAT would be way too high to run 12psi on pump gas with this and have no knock. Crawford failed here unfortunately.
270crank HP I'd probably put anywhere from 220-240whp... Not impressive at all, and that is on 12psi! Ask yourself: do you really want to run so much boost on a high compression motor, on pump gas, with nothing cooling the air?
SBD still dominates the budget kit market at this point.
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
10Stars (09-24-2015), DustinS (09-24-2015)
Old 09-23-2015, 11:05 PM   #10
DAEMANO
Time Traveller
$4395.00
The Following User Says Thank You to DAEMANO For This Useful Post:
Calum (09-24-2015)
Old 09-24-2015, 12:06 AM   #11
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by DAEMANO View Post
$4395.00
It must be nice living in Crawford's "low-cost" world. $4400 w/o intercooler?! $1400 more for the intercooler and plumbing. Full Blown, MAP, Revolutions Performance, Greddy, SBD, AVO, ETC. Essentially, every other kit on the market is capable of more, safe, power; for less money.
Are people really buying Crawford's stuff?
The Racers Line is offline   Reply With Quote
The Following 15 Users Say Thank You to The Racers Line For This Useful Post:
10Stars (09-24-2015), 2013GTRNate (10-12-2015), ajcarson11 (09-24-2015), Apoc (09-24-2015), ATL BRZ (09-24-2015), Calum (09-24-2015), DAEMANO (09-24-2015), DustinS (09-24-2015), flippy (09-24-2015), hmong337 (09-24-2015), industrial (09-24-2015), MAPerformance (09-24-2015), Sportsguy83 (09-24-2015), sw20kosh (09-24-2015), xuimod (09-24-2015)
Old 09-24-2015, 03:02 AM   #12
sw20kosh
Drives: 2013 Black FR-S
Junks
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 09-24-2015, 07:34 AM   #13
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
These guys have been in their own reality for a while now. It would be one thing if they charged high prices for really nice fabrication but that's not even the case. They are the Hennessey of the Subaru world.
industrial is offline   Reply With Quote
The Following 2 Users Say Thank You to industrial For This Useful Post:
2013GTRNate (10-12-2015), Sportsguy83 (09-24-2015)
Old 09-24-2015, 07:51 AM   #14
raven1231
"would you just listen to it?!". # cracklesofbackfire. #gonnaturnthisbitcharound
The Following 4 Users Say Thank You to raven1231 For This Useful Post:
ajcarson11 (09-24-2015), cdrazic93 (09-24-2015), rjsf (09-24-2015), Sportsguy83 (09-24-2015)
Crawford Performance Turbo Kit kalamitykode Forced Induction 66 11-28-2014 11:53 AM
Crawford Performance Turbo Kit chiefshayan Forced Induction 21 05-08-2014 10:29 AM
The 450 HP Crawford Performance Turbo BRZ mackeye BRZ Photos, Videos, Wallpapers, Gallery Forum 7 07-27-2013 05:53 AM
Crawford Performance Turbo BRZ ! Visconti Forced Induction 57 10-12-2012 07:45 AM
