Old 09-18-2015, 11:08 AM   #29
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
@racerx1715 any progress on release of the alternative (top) mounted oil cooler?
Also interested in the Bell core option. Any more details on that core? ie model, number or rows, etc.
Old 09-21-2015, 10:00 AM   #30
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Originally Posted by 1Cor10:23 View Post
@racerx1715 yes, re-tune* my bad. Sounds great, when will it be available?
We are working to have it completed in the next month. Its been a LONG project, certainly longer than expected. To date we have 15 prototypes, around 150 dyno pulls, and countless of hours of design work.
We are finishing the alternate mounting position now, I will have pictures for you soon.
The bell core from the pictures above is slightly larger than the Setrab 613.
Setrab 613 core: 9.5"L x 2.0"W x 3.75"H
Custom Bell core: 10"L x 2.25"W x 3.8" H
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
BigFatFlip (09-22-2015)
Old 09-21-2015, 11:50 AM   #31
DAEMANO
Time Traveller
Thanks very much. A custom quality sandwich plate, top mount and larger than 613 cores make such good sense, but few mfgs cared to deliver. This kit is going to be the one to have and definitely worth the wait.
The Following User Says Thank You to DAEMANO For This Useful Post:
Jeff@Racer X Fab (09-22-2015)
Old 09-22-2015, 11:46 PM   #32
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@racerx1715 Just received my plate - this thing looks superb! Definitely better suited for our application than the generic Mocal plates.
2 quick questions I have though:
1. -10AN fittings came pre-installed, are they torqued to spec? If so, at what torque value?
2. Seems like dowty seals aren't used on the fittings? Or is there a seal / o-ring that is counter-sunk on the inside?
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 09-23-2015, 04:47 PM   #33
Jeff@Racer X Fab
Thanks!
Glad to hear it arrived!!
Yes we do pre-assembly the AN fittings for the thermostatic adapter plate. We use viton o-rings to seal all fittings on the adapter plate. The o-ring groove is cut to depth and size during machining. Torque spec for the fittings is 22ft/lbs however you should not need to re-torque them.
1Cor10:23 (09-23-2015)
Old 09-23-2015, 04:49 PM   #34
1Cor10:23
1Cor10:23's Avatar
@racerx1715 - good call on the O-ring, I've recently had trouble with dowty seals shearing. Thanks for quick response! Quick question, do you have a recommendation for the -10AN connection to female end? My understanding is 1 and 3/4 hex turns for -10AN or 1/4 turn overall from hand tight.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Jeff@Racer X Fab (09-24-2015)
Old 09-23-2015, 06:39 PM   #35
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Any plans on making a non-thermostatic adapter plate?
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 09-24-2015, 02:29 PM   #36
Jeff@Racer X Fab
Tightening the female fitting by hand and then an additional 1/4 turn should be sufficient. AN fittings do not typically take a lot of force to seal. Hope that helps.
Currently we do not plan to make a non-thermostatic version of the adapter plate.
1Cor10:23 (09-24-2015)
Old 09-24-2015, 10:23 PM   #37
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Will the alternate mounting be available for purchase for those of us whom already bought an oil cooler from you guys?
Old 09-25-2015, 02:41 PM   #38
Jeff@Racer X Fab
Once we have the alternate mounting position completed we will be offering it for sale separately, along with other items for individuals that want to piece together their own kit.
DAEMANO (09-25-2015)
Old 09-27-2015, 09:44 AM   #39
1Cor10:23
1Cor10:23's Avatar
@racerx1715 so I tried installing on Friday... Unfortunately does not fit with stock airbox right now... Gets pinched by the metal line (?) by the thermostat bolt. At this point, can't put the airbox back on :/ I'm using the same 45 degree an fittings as your kit.
Sent from my SM-N920W8 using Tapatalk
Old 09-27-2015, 10:52 AM   #40
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I would like to purchase with the top mount when ready. Please add me to the list.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Jeff@Racer X Fab (09-27-2015)
Old 09-27-2015, 11:58 AM   #41
Jeff@Racer X Fab
Well that's frustrating! Give this a try. Its a tight fit with the OEM air box but there is enough clearance.
1) Remove the thermostatic adapter plate, and spacer.
2) Install the OEM air box, and leave the mounting bolts a little lose.
3) Re-install the spacer and thermostatic adapter plate, hand tighten the bolt so the adapter plate can be rotated.
4) Install the 45 degree fittings and rotate the adapter plate until it clears the Air box.
5) Tighten all components.
If you are still having problems let me know or shoot an email over to tech@racerxfabrication.com
1Cor10:23 (09-27-2015)
Old 09-27-2015, 12:00 PM   #42
1Cor10:23
1Cor10:23's Avatar
@racerx1715 thanks for the weekend response, really appreciated! However there is physically just not enough clearance at the moment, not a matter of slotting things in one at a time.
Don't worry too much about me, I'm thinking of going CAI route with an aluminum tube so clearance won't be able issue later. Looking at your photo, clearance if it were to fit will be tight, less worried about box more so about the metal line near the tstat. Even the rotation of the tstat hex could impact the clearance if you know what I mean. Simplest fix might be taller spacer to clear the metal line.
The Following 2 Users Say Thank You to 1Cor10:23 For This Useful Post:
DAEMANO (09-27-2015), Jeff@Racer X Fab (09-27-2015)
Racer X Fabrication oil pan design and development! Jeff@Racer X Fab Engine, Exhaust, Transmission 87 06-03-2015 11:10 AM
Racer X Fabrication Holiday sale!! Ends Dec 2nd. Jeff@Racer X Fab Announcements, Contests, Giveaways 2 12-01-2014 09:24 AM
DIY Changing Cam Plate Racer X fabrication Mr. DIY (Do-It-Yourself) Guides 0 08-06-2014 12:56 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
Racer X Fabrication, New vendor intro Jeff@Racer X Fab Announcements, Contests, Giveaways 0 03-12-2013 11:50 AM
