Old 06-01-2012, 05:14 PM   #1
Kieranz
Drives: Tribeca, GBS BRZ-L
Direct wire radar detector
Given the the CLA is near the cupholders in this car, I am going to want to direct wire my radar detector Has anyone cracked into the cabin fuse panel on the vehicle yet? Wondering 3 things: 1) Are the fuses micro sized and which position would be a logical one to piggyback off of and is also switched with the ignition of the car? Any ideal locations for a grounding wire as well? 2) Is there clearance in the panel box to use an "add a circuit" so I'm not splicing any wires? 3) Any space behind the panels and trim to neatly fish a wire up to the a detector placed near the driver side visor? thanks.
Kieranz is offline   Reply With Quote
Old 06-01-2012, 05:30 PM   #2
otoz
Drives: 2013 Whiteout FR-S
There's a 12v plug in the glove box that is switched with the ignition, that will be the one i use. I'll be wiring mine this weekend and will try to get pix.
otoz is offline   Reply With Quote
The Following 2 Users Say Thank You to otoz For This Useful Post:
MarkRacerX (06-01-2012), uptown (08-20-2012)
Old 06-04-2012, 05:09 AM   #3
earthsscum
earthsscum's Avatar
Drives: 2013 BRZ premium dgm
i'm also hardwiring my passport wednesday.. glovebox seems to be a winner, i'm also having a viper alarm installed
earthsscum is offline   Reply With Quote
Old 06-04-2012, 07:33 AM   #4
blalor
Drives: WRB BRZ Limited 6MT
I've got a Valentine 1 I'll be hard-wiring, with a remote display. I prefer to go the add-a-fuse route (similar to [ame=http://www.amazon.com/Littelfuse-FHA200BP-ATO-Add-A-Circuit-Kit/dp/B0002BGELQ/ref=pd_sim_auto_1?tag=acleint-20]this[/ame]), rather than cutting existing wires.
blalor is offline   Reply With Quote
Old 06-04-2012, 10:03 AM   #5
otoz
I hardwired my escort redline yesterday, it turned out to be very easy to use the glove box power. Visor mounted, its pretty tough to see from outside the vehicle. I wired the remote to be next to the passenger seat near my shifter so i can mute it without moving my arm very far. I didn't take anything apart for that, i just tucked the cables under the plastic and velcro'd it to the side of the center console.
http://i.imgur.com/dsVQO.jpg
First, take the glove box out and the little plastic panel off the side of the door jam. There's a clip on the right side that disconnects the actuator and lets it fold all the way down, then you can take it off completely to get it out of the way.
Once its out of the way it'l look something like this.
http://i.imgur.com/X5NWP.jpg
http://i.imgur.com/j9eMi.jpg
There are ~4 Phillips head screws you can take off which will let the whole thing hang, it was caught up on something in the center, but i was able to reach behind the power plug and wire it no problem so I didn't mess with it. I hardwired the radar detector, and just plugged in my dash cam and ran the wires behind. I had a little clip to sap power off the 12v+ line, then I just screwed the ground to the chassis using one of the pre-drilled holes they have back there with nothing on them.
Next, take off the pillar cover, it has an airbag behind it so you'll want to be careful, I was able to pop it off without too much trouble, it has a weird bendy green clip that will hold it on in the event the airbag deploys, use a pair of needle nose pliers and turn it 90 degrees to release it.
http://i.imgur.com/ihRSM.jpg
Next, take the visor off, you'll need to undo 2 screws. The other side not shown just clips on, use a small Flathead to push the clips in on both sides and release it. Once you do that the headliner is easily bent down a little to slide cables under.
http://i.imgur.com/OLvvh.jpg
Here you can see my dash cam.
http://i.imgur.com/Blv1y.jpg
Once all the wires are run put everything back together. The power port in the glove box is switched with the ignition, so I didn't even have to do anything fancy.
The Following 8 Users Say Thank You to otoz For This Useful Post:
brybot (04-14-2016), chanomatik (07-01-2014), DjDATZ (02-04-2014), Indestruct (06-07-2012), mines13 (06-04-2012), NRGBalanced (06-04-2012), uptown (08-20-2012), wrb (10-16-2013)
Old 06-04-2012, 11:52 AM   #6
ayau
Drives: Some rust bucket
Has anyone tried to tap into the center light wire when hardwiring?
Old 06-04-2012, 12:18 PM   #7
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
I was curious about the A-pillar removal myself. Planning on doing a hard wire radar detector setup, but I will use the foot well fuse panel for power so as to keep the glove box 12v DC free.
mines13 is offline   Reply With Quote
Old 06-04-2012, 12:23 PM   #8
otoz
i used a "t-tap" connector, http://solutions.3m.com/wps/portal/3...beVB2NDGZBTHgl
Old 06-04-2012, 12:32 PM   #9
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
What kind of dashcam is that? Are you happy with it overall?
NRGBalanced is offline   Reply With Quote
Old 06-04-2012, 01:01 PM   #10
otoz
Its a Blackvue DR400G-HD. It works pretty well, but the fit and finish could be much better. As a dash cam for continuous use it seems to work pretty well, it does continuous recording with gps/gforce data but don't expect it to be a go pro replacement. The firmware is a little quirky, and you have to reformat the SD card often to keep it from having errors, but for the money, not a bad investment I think.
Old 06-06-2012, 09:22 AM   #11
avusblue
avusblue's Avatar
Drives: 2013 FR-S, Manual, Argento
I, too, just used the switched power port behind the glovebox. See page 26 of the document available here. You should be able to do this in under ten minutes. Good luck.
avusblue is offline   Reply With Quote
Old 06-06-2012, 11:37 AM   #12
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
any of these cop proof for us canadians?
Old 06-06-2012, 12:08 PM   #13
otoz
There are 2 at the moment i believe, the bel sti and the escort redline. Both are ~$450. You'll want to get it out of sight though. Google is your friend.
Old 06-06-2012, 12:11 PM   #14
ayau
you don't have to deal with splicing/circuits if you use the glove box cig lighter.
[ame="http://www.youtube.com/watch?v=9i2bEoTbjpA"]Brz radar detector install - YouTube[/ame]
The Following 5 Users Say Thank You to ayau For This Useful Post:
brybot (04-14-2016), DjDATZ (02-04-2014), Indestruct (06-07-2012), NRGBalanced (06-10-2012), uptown (08-20-2012)
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 05:31 PM
Gasoline Direct Injection... DoogenBurns Engine, Exhaust, Transmission 5 05-21-2012 03:05 PM
Does anybody direct/cut film? Guff Off-Topic Lounge [WARNING: NO POLITICS] 27 02-08-2012 02:12 AM
Canadians using radar detectors & laser jammers Lo CANADA 0 01-30-2012 11:29 AM
drive-by-wire systems... Axel Other Vehicles & General Automotive Discussions 6 01-15-2010 02:41 PM
