Old 05-27-2015, 06:23 PM   #197
Ed @ EQ Tuning
Ed @ EQ Tuning's Avatar
Drives: 2013 Turbo BRZ
FI Sonoma Raceway / 1:49.5 / Ed Susman / 5/23/15 / SBD Turbo Kit, Equilibrium Tuned, Coilovers, Hankoook R-Comps /
[ame=http://youtu.be/FROKKfGEGL8"]http://youtu.be/FROKKfGEGL8[/ame]
Ed @ EQ Tuning is offline   Reply With Quote
Old 06-03-2015, 11:02 AM   #198
YodrOne
Drives: 2013 Scion FRS
Silverstone Grand Prix - UK
NA
Silverstone Grand Prix / 2.45.62/ Dan / 25 May 2015 / BF Goodrich g-Force Rival tires 225/40/17; PFC 08 race pads and Castrol SRF fluid; RCE yellow springs w/stock dampers - no camber plates (stock alignment); Harry's LapTimer
[ame="http://https://www.youtube.com/watch?v=8vtEXXNNiAc"]http://https://www.youtube.com/watch?v=8vtEXXNNiAc[/ame]
The speed was correct, it was the corner that was too tight.
YodrOne is offline   Reply With Quote
Old 06-03-2015, 11:06 AM   #199
YodrOne
Circuit Park Zandvoort - Netherlands
NA
Circuit Park Zandvoort / 2.11.47 / Dan / 27 May 2015 / BF Goodrich g-Force Rival tires 225/40/17; PFC 08 race pads and Castrol SRF fluid; RCE yellow springs w/stock dampers - no camber plates (stock alignment); Harry's LapTimer
[ame="http://https://www.youtube.com/watch?v=FZUnAnITlTQ"]http://https://www.youtube.com/watch?v=FZUnAnITlTQ[/ame]
Old 06-03-2015, 11:11 AM   #200
YodrOne
Nurburgring Grand Prix Sprint Configuration
NA
Nurburgring Grand Prix Sprint Configuration / 1.53.92 / Dan / 28 May 2015 / BF Goodrich g-Force Rival tires 225/40/17; PFC 08 race pads and Castrol SRF fluid; RCE yellow springs w/stock dampers - no camber plates (stock alignment); Harry's LapTimer
[ame="http://https://www.youtube.com/watch?v=8kqALMFXjeE"]http://https://www.youtube.com/watch?v=8kqALMFXjeE[/ame]
The Following User Says Thank You to YodrOne For This Useful Post:
juliog (06-04-2015)
Old 06-03-2015, 05:20 PM   #201
Imsteak
Drives: Whiteout FrsMono MT, E63
NA
NJMP Lightning/ 1:19:82 / Donald / June 1 2015 / BFG G-Force Rival 225/45/17; Project Mu HC+800 front pad, Hawks HP+ rear with SS line; OFH+Nameless FP/OP+ Tomei Ti80; OFT stg2; TRD Spring and Sway set
http://postimg.org/image/6fla6thcz/
Imsteak is offline   Reply With Quote
Old 06-22-2015, 09:49 PM   #202
redlined600
redlined600's Avatar
Drives: Fr-s
Track: Road America
Time: 2:44.35
Driver: Redlined600
Date: June 2015
Mods: Oil cooler, motoeast 93 tune, Tarmac II coilovers, 17x9 RPF1s with 245 RE71R tires.
I seriously don't get why the embedded video wont show up.
redlined600 is offline   Reply With Quote
Old 06-29-2015, 07:55 PM   #203
Ed @ EQ Tuning
are these still being updated?
Old 06-30-2015, 04:19 PM   #204
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by rever5e View Post
@Element Tuning - do you have any video of the run at Road Atlanta? In NA form i'm struggling to get past 1:49:xx. Would love to see what you're doing to achieve such stellar times!
Here's a 1:43.7, NA on 245/40/17 RS-3s.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
EAGLE5 (06-30-2015)
Old 06-30-2015, 07:39 PM   #205
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I haven't been updating. It's a pain in the ass. I figure people will just read through or search.
Old 09-23-2015, 02:31 PM   #206
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I think I've got the NA 86 record for Barber now!
NA Barber Motorsports Park / 1:47.11 / Scott Bartlett / Sept 20, 2015 / HKS Drop-in Filter w/ snorkel mod, OFT custom tuned by TopSpeed Motorsports, RevWorks header, stock OP, DC front pipe, stock midpipe, Nameless Race Muffler (single exit), Mishimoto Oil Cooler, AP Sprint Kit with Hawk DTC-60's front and Cobalt XR2 rear, Torque RT700 Fluid, 225/40R17 NT01s w/ ~28 heat cycles on Motegi MR125 17x7.5 wheels, RaceComp Engineering Tarmac 2 w/ 500lb springs, stock tophats, crash-bolts (-3* front camber, -2.2* rear camber), AP harness bar w/ Schroth Profi II ASM harness, Motul gear oil in trans/diff.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
The Following 4 Users Say Thank You to smbstyle For This Useful Post:
CSG Mike (09-23-2015), DarkSunrise (10-27-2015), JSube (11-08-2017), LOLS2K (10-27-2015)
Old 09-23-2015, 03:14 PM   #207
Pat
Pat's Avatar
Drives: 2023 BRZ
Congrats! How did you get 3* of camber in front without camber plates? How much have you lowered your car?
Old 09-23-2015, 03:18 PM   #208
smbstyle
smbstyle's Avatar
Had a shop in the Atlanta area work their magic on the track alignment. Not exactly sure on the ride height specs, but it was corner balanced, and the fronts were almost maxed out, with the rear having a little bit of rake.
2013 SWP BRZ
Old 09-23-2015, 04:02 PM   #209
Pat
Pat's Avatar
Drives: 2023 BRZ
Can you be a little more specific, please? You say the fronts were maxed out. Does that mean they are super low? Any idea of the approximate drop?
What do you mean by the rear having rake?
How would they work "magic" without something to adjust? Or is all the camber just due to the drop in ride height and camber bolts?
The Following User Says Thank You to Pat For This Useful Post:
Slick (09-23-2015)
Old 09-23-2015, 07:21 PM   #210
smbstyle
smbstyle's Avatar
Yes, fronts are pretty much as low as they go. I'd measure the ride height for you but the car wont be back at my house for another two weeks. Rake means the rear sits up a bit higher than the front - that was just a result of the corner balancing.
The shop adjusted the crash bolts as much as they could to gain maximum camber. You can also push in the top of the strut I believe as you're tightening to get a few more fractions of a degree.
2013 SWP BRZ
The Following User Says Thank You to smbstyle For This Useful Post:
Pat (09-23-2015)
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
Before/After Track Times (Sonoma Raceway) CorteXracing Tracking / Autocross / HPDE / Drifting 5 11-26-2012 10:28 PM
POST YOUR FASTEST GT5 NURBURGRING TIMES.... FT-86GOD Other Vehicles & General Automotive Discussions 96 07-15-2012 12:45 PM
GT5 - fastest Suzuka (full track) times NESW20 Other Vehicles & General Automotive Discussions 11 04-03-2011 12:20 AM
