Old 09-22-2015, 12:57 PM   #15
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
what makes this technology only available in high end products, what are the component complexities and costs that prohibit this being used universally?
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
Calum (09-22-2015), fika84 (09-22-2015)
Old 09-22-2015, 01:06 PM   #16
RBbugBITme
Drives: S60R/Corvette
Nothing but money. It'll fit on pretty much any Penske shock.
http://shop.penskeshocks.com/PENSKE-...ALVE-ASSEMBLY/
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following User Says Thank You to RBbugBITme For This Useful Post:
CSG Mike (09-22-2015)
Old 09-22-2015, 01:28 PM   #17
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I bet half the parts alone for a penske shock could pay for some Teins.
Old 09-22-2015, 01:35 PM   #18
fika84
fika84's Avatar
Raceseng has the Penske shock prices starting at $7K... http://www.raceseng.com/penske-shock...ubaru-brz-2013
fika84 is offline   Reply With Quote
The Following 3 Users Say Thank You to fika84 For This Useful Post:
BatStig (09-22-2015), cdrazic93 (09-22-2015), strat61caster (09-22-2015)
Old 09-22-2015, 03:02 PM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
is that mostly R&D cost?
If demand was much higher (say, OEM) would the cost go down significantly?
Old 09-22-2015, 03:13 PM   #20
RBbugBITme
Not R&D, just quantity limits. OEMs would not be paying anywhere near that much.
Ryan M.
Strange Engineering
Old 09-22-2015, 09:12 PM   #21
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Just about the same as two sets of SRCs
The Following User Says Thank You to cdrazic93 For This Useful Post:
drewbot (09-22-2015)
Old 09-22-2015, 11:00 PM   #22
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Did you see it can rise to $12k!!!!
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 09-23-2015, 01:40 AM   #23
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Given the exchange rate atm the double adjustables without springs would end up costing approximately AUD18k with import taxes. Yeah, I guess I'm passing on these
Old 09-23-2015, 04:50 AM   #24
ajc209
Drives: GT86 Cosworth
Oh looorrrrd wont you buy me a 2way-set-of-penzkes? my friends all have Ohlins-DFV, I must make amenze......
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
strat61caster (09-23-2015)
Old 09-23-2015, 08:45 AM   #25
bfrank1972
Drives: 2013 FR-S Argento
I just have to wonder, with all these complex (and expensive) valve designs, when aftermarket computer controlled/magnetic dampers are really going to hit their stride. Like these people: http://www.magneshocks.com/roadracing.htm
Program any curve you want, have selectable curves based on terrain. Heck have a Nurburgring setting that knows via gps when you're about to hit the carousel and adapts accordingly. I have to think it will eventually obsolete designs discussed in this thread.
Old 09-23-2015, 08:52 AM   #26
RBbugBITme
For the performance aftermarket, not likely going to happen. Magnetorheological dampers are literally the worst thing you could do for a performance damper. Its the fluid equivalent of sand paper, we developed the first set for McLaren over a decade ago and they couldn't match curves before and after a test due to wear of everything internal.
Ryan M.
Strange Engineering
The Following 3 Users Say Thank You to RBbugBITme For This Useful Post:
Aki (04-02-2016), Captain Snooze (09-24-2015), Wepeel (09-23-2015)
Old 09-23-2015, 08:57 AM   #27
bfrank1972
Ahh interesting. Do you know how the factory magnetic setups (like GM) are getting around this longevity problem?
Old 09-23-2015, 09:00 AM   #28
RBbugBITme
Other than starting with looser tolerances to hide it and minimal damping rates, they're not.
Ryan M.
Strange Engineering
The Following 4 Users Say Thank You to RBbugBITme For This Useful Post:
Aki (04-02-2016), bfrank1972 (09-23-2015), mokinbird87 (09-23-2015), Wepeel (09-23-2015)
BRZ/FRS ABS Module/Pump/Valving Grambi Brakes, Suspension, Chassis 4 08-22-2015 02:59 PM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Eibach R2 valving and spring rate question owenxguo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-10-2014 07:43 AM
Penske Coilovers. miwialex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 12-20-2013 08:17 PM
Penske 8300 vs Ohlins TTX36 CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 09-12-2013 07:08 PM
