Old 09-22-2015, 02:33 PM   #9507
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
not to disagree, just a random observation, but when it's hot out, and I drive for more than 10 minutes, I regularly see a reading of 29.0v; when It's cold out I never get above 28.8v
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 09-22-2015, 02:34 PM   #9508
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
The voltmeters typically have a variance of about .2 volts I've seen. The higher voltage could be due to the alternator charging the batteries to keep them peaked in hot weather.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Target70 (09-22-2015)
Old 09-22-2015, 07:40 PM   #9509
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by LucidMomentum View Post
@KoolBRZ's map has been pretty good, even with the 91 Octane we have in Cali.
However Kool, I tried your new Best Ever Procede map and I don't like it as much as the cool map from your last set of tunes. It's probably more efficient as it doesn't kick in until that higher end of the rev / rpm range, but the mid range delivery under the cool / warm map is what I really wanted from the Procede.
So, I'll be swapping out that Procede tune for the previous one, but keeping the OFT tune. Good stuff!
I'm not completely satisfied with either the B.E. tune, or the PROcede map, and so I've been trying to tune closer to what I want. Your CAL ID is D00D right? I'm getting pretty close to the best tune I can get, and I wrote another PROcede map. Tried 3 tunes today and the newest PROcede map. I like the PROcede map, but the tune still has a tiny bit to go to be just right. If you want to try the PROcede map, it's attached below.
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
LucidMomentum (09-22-2015)
Old 09-22-2015, 10:14 PM   #9510
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Sweet! I'll take a look at it then
Old 09-22-2015, 10:39 PM   #9511
TM
TM's Avatar
Drives: DGM BRZ 6MT
For those of you in the US who sent stuff back to Rob for repair, which carrier did you go with?
TM is offline   Reply With Quote
Old 09-22-2015, 10:40 PM   #9512
Sojhinn
Sojhinn's Avatar
Usps
Installed Mods:
Old 09-23-2015, 12:20 AM   #9513
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Sojhinn View Post
Usps
Yup. Rob actually emailed me that. I assumed he saw my post here. Talk about service.
Old 09-23-2015, 01:49 AM   #9514
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by DAEMANO View Post
Welcome back.
It's probably mostly the weather. We've had so many 90+ degree days that if you're going to drop some power.
Our 91 gas really sux. Have you logged recently. Check to see if your IAM is dropping under 1.0 and staying there. If that's the case then you have your answer.
Oh yeah something else, when was the last time you cleaned your intake filter?
Lastly, what codes were you throwing? How are you certain that running Torco was the cause?
I'll clean out the intake filter and run log the IAM and AFR and see how it is.
Regarding the codes, I was throwing a P0463 (Fuel Level Sensor High Input). How am I certain it was the Torco causing it? To be honest, I'm not certain and it's purely anecdotal. I do know that I was not throwing the codes prior to using it and I have not thrown the code since I stopped using it. I've done research on forums and there isn't any conclusive evidence of what is causes it.
I'm guessing you are mostly on e85 but were you able to run Torco long term without any issues?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
DAEMANO (09-25-2015)
Old 09-25-2015, 04:06 PM   #9515
fenton
Two PM's were sent out yesterday. We will move down the list after the weekend if there are no responses.
Rev 3 kit has had some updates, mostly with ease of installation and compatibility additions for Procede:
I want to applaud @Shiv@Openflash, the procede hits all the marks when it comes to boosting our platform with a ESC. After using it for 2 weeks it is simply the best addition anyone could add to the ESC. I have been using the sport map and it is truly awesome. Sure it takes a bit of getting use to but once your brain readjusts to the new power it cannot be beat. Merging in with traffic in 4th or 5th gear is awesome, you squeeze the throttle and dial in the power effortlessly. Gone is the "too much / not enough" feeling that boosting in lower RPM ranges could bring out with the WOT switch. I have had 5 friends drive my car (they own a STI, WRX, GTI, 135i and 370z). They all loved how the power came on, no lag, no drama just smooth boost.
I urge everyone that hasnt given the procede a try to try and fit it into the mod budget, it really is great.
With that being said, almost all users of the part throttle switch have migrated to the procede and loved it. Rob is going to suggest that if a user wants the advanced partial throttle boost that they go the procede route. If the user really doesn't want the procede they can go with the standard WOT switch(at reduced cost) or the partial throttle switch(at normal cost).
The V3 kit has connections on the control box for both Procede and Throttle switch, no more need to splice into your existing connection to add the procede for ESC control. This kit also has updates to the Voltmeter(slimer) and the motor to controller connections are the biggest yet.
fenton is offline   Reply With Quote
The Following 9 Users Say Thank You to fenton For This Useful Post:
Aztec (09-25-2015), BBDGriptonia (09-29-2015), DAEMANO (09-25-2015), Fever (09-25-2015), gtfapollo (09-26-2015), LucidMomentum (09-28-2015), Shiv@Openflash (09-28-2015), Sojhinn (09-27-2015), zc06_kisstherain (09-26-2015)
Old 09-25-2015, 05:15 PM   #9516
DAEMANO
Time Traveller
I'm sure you've done your share of research on P0463. This link suggests the following:
- Faulty fuel level sensor
- Fuel level sensor harness is open or shorted
- Fuel level sensor circuit poor electrical connection I ran Torco for ~3 months. No codes, very little knock and rock solid IAM.
As far as I go, yep still on e85. No issues other than trying to keep under the posted speed limits .
The Following User Says Thank You to DAEMANO For This Useful Post:
l0aded (09-26-2015)
Old 09-25-2015, 05:23 PM   #9517
DAEMANO
Time Traveller
Thanks Fenton. I find it hard not to talk about the PROcede + Phantom kit and sound objective. The hardware rocks, and every ride along/test drive I've given nets similar positive responses to yours. The combination feels refined, powerful and accessible.
Big upgrades to the kit too. New buyers are going to be very happy with fit and finish as well as how easy it is to add the PROcede should they choose.
Great work!
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
fenton (09-25-2015), Sojhinn (09-27-2015)
Old 09-28-2015, 09:56 AM   #9518
Kpage
Kpage's Avatar
Drives: 2015 FRS Release Series 1.0
Hello All!,, I am new to the forum and new to the FRS (having just purchased a '15 FRS RS 1.0. I have been following this thread for a while and have read almost all 433 pages. I know there is quite a long list of buyers at this point and wanted to get a couple clarifications before adding my name to the list.
1. total cost (not including the batteries) out the door. I would like a total budget cost on the ESC (tq250 or tq300) and proceed tuner as this seems to be the top combination.
2. has anyone added this to the RS1.0 yet? any possible glitches that you are aware of?
3. being that the two components above come from different shops and the ESC has a known wait list, how long does it take to get a proceed tuner. don't want to order until I know the ESC is ready and Vice Versa.
4. I want to thank all of the members for all the feedback its helped a lot.
Thanks in advance!
Kpage is offline   Reply With Quote
Old 09-28-2015, 10:14 AM   #9519
Sojhinn
Sojhinn's Avatar
Thanks in advance!
1) cost is on the first post. It changes as the kit has been modified.
2) not sure. Is there a different intake on the rs?
3) procedes are almost always in stock so just wait until your name comes up for the phantom. (1.3 years)
4) no worries
Installed Mods:
Old 09-28-2015, 12:47 PM   #9520
LucidMomentum
Taken at this month's Cars & Coffee:
The Following 2 Users Say Thank You to LucidMomentum For This Useful Post:
DAEMANO (09-28-2015), raven1231 (10-14-2015)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
