Old 08-23-2012, 03:28 PM   #15
Racecomp Engineering
With a budget coilover you are sacrificing the quality of the valving for height adjustment and stiff springs. With a Koni or Bilstein you get a good shock with quality valving but none of the extra features. It depends on what's important to you but a quality shock is very important to me.
Coilovers aren't automatically better.
- Andrew
Matt Andrews (08-23-2012)
Old 08-24-2012, 11:40 AM   #16
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
One question to you suspension guys. I plan to go quality coilovers a year from now, KW V3 or Bilstein if they have a product at that time. In the meantime I would love to remove the fendergap without sacrificing lap times on trackdays. If I go with the Eibach Pro's and stock shocks will handling be worse because the shocks work in in a suboptimal area or will it actually improve with 1" lower CoG?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 08-24-2012, 11:58 AM   #17
Synack
Boosted
Synack's Avatar
Drives: Sideways
- Andrew
Well if I can get the front and the rear near flush with springs and other mods then all I would need is just good shocks.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-24-2012, 12:38 PM   #18
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
you might be in the bump stops at track days with a 1" drop on stock dampers, but not sure. These dampers can take a bit more spring than stock, so I would imagine that a drop spring would be fine to hold you over.
see the link in my sig. My car was only dropped .75". Not sure you really need more than that to close the gap...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-24-2012, 12:50 PM   #19
Synack
Boosted
Synack's Avatar
Drives: Sideways
It's at least 2" to close the gap even with my 19" wheels on 255/35/19's
When I mean close the gap, I mean NO GAP, I would be fine with 1/2" or less wheel gap. Looks like you've got around 1.5" gap still.
Old 08-24-2012, 01:08 PM   #20
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Shame what we have to deal with to go fast...
mines13 is offline   Reply With Quote
Old 08-24-2012, 01:35 PM   #21
Synack
Boosted
Synack's Avatar
Drives: Sideways
This has nothing at all to do with "going fast". I just don't want any wheel gap on my car. It's a show car/bi monthly drifter/daily driver. If it was purely a race/drift car I could care less what the gap was. But the show car part require minimal wheel gap, and eases my conscious because I hate wheel gap.
Old 08-24-2012, 05:58 PM   #22
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
With a 2" drop on stock shocks it will ride pretty bad, You'll be on the bump stops a lot.
That will go for any aftermarket shock too on 2" drop springs.
For something like what you want you're better of with a dual-height adjustable coilover, where you can drop it low but retain the travel of the damper. BC Racing makes a good kit for the money IMO.
Circuit Motorsports is offline   Reply With Quote
Old 08-24-2012, 06:14 PM   #23
Synack
Boosted
Synack's Avatar
Drives: Sideways
There isn't a 2" drop spring that exists, I was just saying that it would take about 2" to make that gap disappear. I'll be buying the Eibach Sportlines and might find additional ways to drop that extra 1/2" without affecting travel so I'm not constantly slamming on the bumpstops. Thanks for the coilover recommendation.
Old 08-28-2012, 02:46 PM   #24
Circuit Motorsports
Yup, No problem.
Old 09-21-2015, 12:03 PM   #25
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
that was a really good read. i'm doing my research on which coil system to get right now. I suppose its really hard to want both form and function... I want a red coil system that is good quality and the setup i want. i know, i know no one is going to see it, but thats not the point.
I guess my question is, for autox and spirited driving on the weekends(not very competitive, yet.) as well as a daily driver, what should i be looking for spec wise. i'm hearing I should get lower spring rates on the front and stiffer in the rear, and that i ideally shouldn't run a square setup. While i know why it would be good to run a stiffer rear, is the spring rate the only thing controlling this? can i not adjust the damper while i have a square spring rate setup?
I hope i'm asking the right question, kinda of a noob... currently looking at the Apexi N1
slyphen is offline   Reply With Quote
Old 09-22-2015, 09:47 AM   #26
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
If you're just autocrossing and doing spirited weekend driving, go with adjustable dampers/shocks (like the Koni Yellows) and lowering springs. The Eibach Pro*Kit and TRD springs, which are just rebranded Eibach Pro*Kits with slightly different rates, are both red and will give you a slight drop (slightly over 1" once they settle).
For the money, properly chosen springs and shocks will generally be better than a cheap coilover system.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
slyphen (09-22-2015)
Old 09-22-2015, 04:57 PM   #27
Calum
That Guy
Drives: 2013 asphalt FRS MT
Lots of us are running square spring rates. Racecomp Engineering basically pioneered it on this platform when they brought out their "Yellow" lowering springs. I ran their yellows for a couple of years and was very happy with them. The spring rates and drop were a perfect pairing for the stock dampers and the suspension geometry. They worked very well together without putting undue stress on the dampers. To my surprise, the result was a car that felt better at spirited driving and cruising. The ride wasn't smoother, but more composed and less jarring over bumps. The chassis was much more composed over mid corner bumps that seemed to upset it. I honestly don't know if grip was significantly increased, or if it was driver confidence from the more predictable setup, but I was noticeably faster in the corners.
This year I moved up to a set of Racecomp Engineering's T0 coilovers. These still use a square spring setup. The main reason I stayed with Racecomp Engineering is because of how well their lowering springs worked. I figured if they could do that with just springs, then a complete setup from them could only be better. I had to play with the tire pressures to get the ride perfect, but with a good alignment, corner balancing, and the T0's, the only word I can use to describe the way the car handles is nirvana. Turn in is crisp, the grip is immense, the ride is stiff but still very comfortable, and the car is flat out amazing at the limit. I didn't know this level of control would be possible at this price range.
Tein has also released a square spring setup recently. I regret that I don't have any first hand knowledge to offer, but there's a couple of threads about them if you'd like to read more.
To my knowledge, neither of these come in red, but you might be able to change that manually, or speak to a vendor about sourcing springs from a different company. Honestly that red requirement is going to be very limiting, especially if you stay with a lowering spring and fixed perch damper. But don't be afraid to look at square spring rate setups. At higher spring rates all reports are that they don't work as well, but with a modest spring rate setup they do work very well.
The Following 3 Users Say Thank You to Calum For This Useful Post:
Racecomp Engineering (09-22-2015), RJasonKlein (09-24-2015), slyphen (09-22-2015)
Old 09-22-2015, 08:05 PM   #28
slyphen
Drives: Man
thanks for the input. i'm looking at the Apexi N1 ExV, spring rate are square at 6K. I was pretty set on getting this one till someone told me not to run square setup. i'll be lowering my vehicle by 1" and will send it to a notable tuner shop for balancing.
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
AutoX Parts Setup NYC BRZ Tracking / Autocross / HPDE / Drifting 38 08-17-2012 05:42 PM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
