Old 09-22-2015, 12:24 PM   #15
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by ATL BRZ View Post
Fundamental design flaw. Sell your KW kit and get the Jackson Racing kit if you don't want to keep breaking belts.
This
Old 09-22-2015, 12:45 PM   #16
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I heard broken belts are a very common flaw to the kraftworks system. If you knew about the problem why didn't you go with a different system to begin with?
Instagram: trevor.parque
Old 09-22-2015, 12:46 PM   #17
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I'm going to bet it was the price.
Old 09-22-2015, 12:52 PM   #18
MisterSheep
Killed Scion
Spend a little bit more money and could got a jackson racing. Very similar supercharger to the kraftwerks.
Old 09-22-2015, 01:03 PM   #19
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Fundamental design flaw with both. Sell your supercharger and get a turbo if you don't want to waste horsepower spinning it with a belt.
Because dealing with overboost, surge, leaks and creating several other possible failure points is such a good trade-off
Each system has it's benefits and it's downsides. From what I have seen so far the KW kit is perfectly fine, most people just cannot adjust the belt at the proper tension or are too lazy to check it periodically to ensure it doesn't require to be re-tightened.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
ATL BRZ (09-22-2015)
Old 09-22-2015, 03:44 PM   #20
FirestormFRS
By very similar you mean the exact same charger with a different drive design.
FirestormFRS is offline   Reply With Quote
Old 09-22-2015, 03:54 PM   #21
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
Well kraftwerks is sending me a new belt. i am also going to make sure to get the belt tensioned correctly and not too tight and maybe use that belt tension frequency check app.
interesting comments about trading it in for the jackson racing supercharger. maybe i should of went with that, but oh well. i think it would too much of a hassle to find someone willing to buy my kraftwerks and for me to get the jackson racing at this point. that would just be more money and time and a huge hassle.
ill just hope and pray i dont have anymore belt problems with kraftwerks. and if i still have problems then maybe i will seriously consider getting the jackson racing one.
morswestford is offline   Reply With Quote
Old 09-22-2015, 03:59 PM   #22
morswestford
because i was able to find a distributor with the kraftwerks system in stock and i didnt want to wait 2 months for jackson racing to build their system for me. so i just went with that instead. i knew all along about the potential risks with the belt beforehand. the jackson racing was my first choice. and i just gambled and took the risk and lost.
i only hope when i get the new belt and after its tensioned correctly, i wont continue having these problem, or else i may seriously consider getting the jackson system at some point.
Old 09-22-2015, 05:12 PM   #23
fumanchu1
Want my tip? Buy another 2 belts that way if ever you do snap another you are not stuck waiting on a belt to enjoy your car.
Old 09-23-2015, 12:25 PM   #24
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Yep, better throw the whole kit away and get something else. And if you install a borla header your engine will explode too. God forbid you've got parts on it made by someone who's last name starts with a V.
post_break is offline   Reply With Quote
Old 09-23-2015, 09:53 PM   #25
morswestford
what do you mean? actually yes i do have an unequal borla header. why? what does that have anything to do with the supercharger?
Old 09-23-2015, 11:35 PM   #26
post_break
post_break's Avatar
It was just me poking fun at someone else on here. Header is fine.
Old 09-30-2015, 02:35 AM   #27
morswestford
re: belt noise
OK so i got the belt replaced, and had it installed and tensioned properly..
at least i thought.
It worked fine for several days. it was smooth and wasnt loud.
now the belt is extremely loud and noisy and violently shakes the entire car. it's almost embarrassing. It's very loud and shakes when idling. i almost cannot wait to rev the engine so the exhaust noise overpowers it.
attached is a video.
does anyone know what the problem is now?
does the belt need to be tensioned again? or what is the cause of this? it doesn't sound right, or feel right, and this can't be normal.
[ame="https://www.youtube.com/watch?v=aM-Tir9McB8"]Kraftwerks Subaru BRZ Supercharger Loud Belt Noise Problem. Why me? - YouTube[/ame]
Old 09-30-2015, 06:12 AM   #28
FirestormFRS
The belts is moving way too much. Loosen the belt and take it off @ the crank and check your pulley and idlers and make sure they are not loose. Did you get the gates carbon drive app? That thing works really well. I wouldn't run it until you figure out what is loose. You can damage the supercharger.
Kraftwerks Review projek_01 User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-23-2015 03:44 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 02:33 PM
DPS Kraftwerks Scion FRS - KW / Invidia / Kraftwerks / Enkei rickspecd Member's Car Journals 40 06-26-2014 12:42 PM
