Old 09-20-2015, 12:30 PM   #1
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
Kraftwerks Broken Belt
I purchased the Kraftwerks supercharger for my 2013 Subaru Brz a few months ago. I only drove 1k miles with it with the supercharger so far and yesterday my belt broke. I wasn't even driving it fast. I just heard a loud snaping noise.
crazy. You know i was hesitant to purchase this system because of all of the other people's horror stories with the broken belts. I'm pissed. Is this because of the belt was too tight, or is this a design flaw? I am certainly not alone. I wish kraftwerks can fix this problem.
I wonder how many more belts will i have to go through before kraftwerks fixing there design issues.
morswestford is offline   Reply With Quote
Old 09-20-2015, 12:58 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Weird never had a broken belt. Best of luck to you!
Freeman is offline   Reply With Quote
Old 09-20-2015, 01:11 PM   #3
Dream20b
Y u do dis?
You knew about it, and ignored it? Not to be a ****, but you took a risk and lost.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following 2 Users Say Thank You to Dream20b For This Useful Post:
Freeman (09-20-2015), mou (09-20-2015)
Old 09-20-2015, 01:54 PM   #4
FirestormFRS
More than 5k miles and no belt issues. Maybe it's an install error.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Dream20b (09-20-2015)
Old 09-20-2015, 05:40 PM   #5
morswestford
maybe. i had the belt tightened just a few weeks ago because it was too loose. maybe it was tightened too tight. crazy. i guess it needs to be just right.
Old 09-20-2015, 05:49 PM   #6
DJCarbine
Thupercharged
DJCarbine's Avatar
I think there is an app floating around where you can use your smartphone to record the noise of the belt and it will determine its frequency/vibration or something along those lines. People seemed to have good results
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 09-20-2015, 05:57 PM   #7
Freeman
Freeman's Avatar
Yes this^^^^ it's called the Gates Carbon Drive app. Works fairly well. Target is 60Hz
Old 09-20-2015, 06:04 PM   #8
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I think the belt needs to be just tight enough not to slap. It doesn't help that the belt continues to stretch once installed. Over the last 5000 miles I've had to tighten a quarter turn here and there to get rid of the slap and keep things happy in there. I just did it again the other day and maybe turned the tension nut 1/8 a turn.
I don't think the system is a flawed design from an engineering standpoint. It works just fine. There is just way too much room for user/installer error. The saving grace is that the primary mode of failure we've seen are just broken belts for the most part. It's not like some kits where user/installer error leads to catastrophic failure.
industrial is offline   Reply With Quote
Old 09-20-2015, 08:52 PM   #9
morswestford
thanks great information, i will def. check that out
Old 09-20-2015, 09:03 PM   #10
morswestford
i think you're right. this belt setup is very sensitive. def. is a learning curve to getting it right. it's still very frustrating to learn how to get it exactly right.
Old 09-20-2015, 09:05 PM   #11
DJCarbine
Thupercharged
DJCarbine's Avatar
Would a spring loaded/hydraulic tensioner be appropriate for this application?
disclaimer : I don't know crap about belt harmonics and engineering of serpentine belts/cogged belts
2013 FRS
Vortech V3 11psi
Old 09-21-2015, 10:43 AM   #12
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Fundamental design flaw. Sell your KW kit and get the Jackson Racing kit if you don't want to keep breaking belts.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Porcupint (09-22-2015)
Old 09-21-2015, 10:43 AM   #13
Freeman
Freeman's Avatar
Lol I was waiting for Ian to show up
Old 09-21-2015, 12:01 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Fundamental design flaw with both. Sell your supercharger and get a turbo if you don't want to waste horsepower spinning it with a belt.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Freddy@PTUNING (04-12-2016), hmong337 (02-19-2016)
Kraftwerks Review projek_01 User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-23-2015 04:44 PM
SOS. Monterey area. Belt tensioner/belt The Racers Line Northern California 11 04-06-2015 03:33 PM
DPS Kraftwerks Scion FRS - KW / Invidia / Kraftwerks / Enkei rickspecd Member's Car Journals 40 06-26-2014 01:42 PM
