#4033 |
#4034 |
Miata traitor
Drives: 2002 Miata SE
Yep. Still only 3 three signed up. I know Derek will be signing up too but I'm still surprised it's only 3. I'm sure the day before it'll be like 5 late sign ups.
#4035 |
Drives: 2013 FR-S Series 10 and 2010 Camry
#4036 |
Miata traitor
#4037 | |
Drives: '14 FRS TT5
For autox, DCTC and similar, I think the HP+ is good. For full track like BIR, other big road courses, I think a higher temp pad is needed. But if you go too aggressive, you'll overpower "street" tires. Another thing to be mindful of when you go to a more aggressive pad (not saying you're having this problem, just general info), is that you have to learn to brake later and use more of the brake. A friend of mine said he was running DTC-something and was over heating them at BIR because he was braking too early and not aggressive enough - thus longer pad to rotor contact, more heat, more fade. Later, more aggressive braking = less friction time, less heat. There is of course a happy medium.
Follow my NASA TT5 build here: JHill Motorsports
#4038 |
Drives: '14 FRS TT5
I'm still trying to decide if I'll compete on the 10th...it's either compete, instruct/work the event, or go the Nordeast Big River Brew Festival. Too many options!
#4039 |
#4040 |
Miata traitor
I was wondering if thats what he meant. I was going to make a 'ringer' crack.
#4041 |
Miata traitor
#4042 | |
Hey, local guys. I have some brakes and wheels for sale here in MN in case anyone is interested. http://www.ft86club.com/forums/showthread.php?t=95103 http://www.ft86club.com/forums/showthread.php?t=94696 I was only at BIR once with these brakes and never got there with the newer pads. One other track trick I would like to pass on. I slotted my factory struts and used camber bolts to get -3 camber up front. This stopped the edge wear I was getting on the tires. I also could go for longer sessions. Before I did this I would get maybe 4-5 laps in before the tires felt greasy, after that I could go the full 25 minutes without an issue. I sold my car last week so I am motivated to move these parts. I also have a WRX spare wheel/tire for sale. This clears the brake kit. Pat |
#4043 |
I may be interested in the brakes. Need to look at my budget and I'll let you know.
#4045 | |
Do those clear rpf1? |
#4046 |
I would sure think so but I don't have any firsthand knowledge.
You can get the template to check here:http://www.essexparts.com/shop/compl...43mm-disc.html Pat |
| Check in, eh? | NorthFool | CANADA | 24 | 02-23-2012 07:32 AM |
| *NSFW* "Check Out My Subaru" on You Tube | Axel | Other Vehicles & General Automotive Discussions | 4 | 01-17-2010 05:56 PM |
| how do you check a site | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 11-21-2009 09:27 PM |
| Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. | JDMinc | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 10-25-2009 08:53 PM |
