Old 09-15-2015, 12:39 PM   #1
HatchirokuV2.0
Drives: 2013 FRS
Ambit RE02's in 17x9 +35?
Hey!
I've recently began to really feel these limits of the "prius tires" that come on these knarly vehicles. I've done a lot of searching and I am beginning now to put a parts list together for this car. The Ambit RE02's are the only wheels that really seem to fit my taste/budget/needs. The question at hand is this:
Can I run these without having to roll or pull both front and rear fenders? And what is the widest tire I can run without running into rubbing?
I've seen that Toyota has "pre-rolled" the fender lips due to the fact that they knew it was a "modify-ready" platform.
HatchirokuV2.0 is offline   Reply With Quote
Old 09-16-2015, 02:46 PM   #2
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
with oem suspension is fine, if u lowerd, 245/40 tires is better, right now im running 255 and it is a little wider
ZHoward is offline   Reply With Quote
Old 09-16-2015, 03:25 PM   #3
vroom4
I have a set for sale in wilmington nc if you are interested in the gunmetal color. 245 tires installed. Can try before you buy that way?
vroom4 is offline   Reply With Quote
Old 09-16-2015, 04:35 PM   #4
8R6
8R6's Avatar
Drives: FRS
depends on your suspension setup. for the most part, 17x9 +35 with 245/40/17 tires will be fine without rubbing unless you're really low... but adding negative camber can easily take care of that.
8R6 is offline   Reply With Quote
Old 09-16-2015, 05:13 PM   #5
HachiEnam
UCSB!!!
HachiEnam's Avatar
Drives: 2017 GTI sport
i have the same wheesl in 18x9.5 +38 with 245/35/R18 MPSS. I dont rub. Wheels are super close to the spring perch though. probable "| |" away from each other.
HachiEnam is offline   Reply With Quote
Old 09-16-2015, 05:16 PM   #6
raven1231
Are you rad rolling? or not?
Old 09-16-2015, 05:44 PM   #7
HachiEnam
UCSB!!!
HachiEnam's Avatar
sorry what? I have stock suspension if thats what youre asking.
Old 09-21-2015, 04:32 PM   #8
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Pmd
Rifle is offline   Reply With Quote
Old 09-22-2015, 04:24 AM   #9
TheMuffinMan
Slowpoke
TheMuffinMan's Avatar
Drives: FR-S Whiteout MT
I've also been running 17x9 +35 RE02's for a little while now on 245/40/17 tires. No rubbing on stock suspension. No need to roll your fenders.
TheMuffinMan is offline   Reply With Quote
Just In: Ambit Wheels RE02 (NOW IN 18" INCHES!) JonMotoring Groupbuys 34 08-04-2015 07:04 PM
Ambit Wheels | RE02 17x9 +35 | RT8 18x9.5 +38 AmbitWheels Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-14-2015 11:46 AM
FS: BRAND NEW AMBIT WHEELS RE02 RSMD626FRS Wheels and Tires 6 04-01-2015 12:06 PM
