Old 09-14-2015, 06:10 PM   #183
NonStopTuning
NonStopTuning's Avatar
Drives: AE86
Originally Posted by Joe-G View Post
So, its almost been 2 weeks and wanted to give an update.
Pulleys are great so far. Car seems like it would wind up faster at the autocross event this past weekend.
However, is it normal for the anodize to wear from the belt ribs? Are the grooves cut into the pulley cut with a specific tolerance?
Glad to hear your car is doing well.
And yes, anodizing does eventually wear away a little where the belt rides. This should not affect the performance of the pulley.
Hopefully the throttle response helps a little at the track!
Best of luck!
NonStopTuning is offline   Reply With Quote
Old 09-15-2015, 08:26 AM   #184
markitect
Drives: Scion FRS
I got my 7 piece kit yesterday, I can't wait to get it on the car this weekend. In the mean time here are some quick pictures with the weights of the new ones
markitect is offline   Reply With Quote
The Following User Says Thank You to markitect For This Useful Post:
CarzCarzCarz (09-15-2015)
Old 09-18-2015, 04:37 PM   #185
markitect
Drives: Scion FRS
I installed the idler, tensioner and water pump pulleys today. The tensioner pulleys are actually heaver then stock, but I don't know how much of the mass rotates/if the bearing has less resistance. The net weight for the idlers and tensioners is about the same as stock.
Install tips:
The Tensioner pulley is held on with Blue threadlocker. So I will need to re-do it.
Don't use the dust cover washers, they will defiantly bind.
Don't use size adapters on your breaker bar, you will sheer the adapter off.
Old 09-21-2015, 03:25 PM   #186
m00shu
Drives: GBS Brz JRSC
I probably missed it but is there a list of torque specs for all of the pulleys somewhere?
m00shu is offline   Reply With Quote
Old 09-21-2015, 03:32 PM   #187
NonStopTuning
Drives: AE86
A few pointers again:
Snap Rings should face OUT
Dust Covers NOT necessary
Slightly more than hand tight, apx 30 lbs ft, torque spec on accessory pulleys
Please be sure to use good judgment/common sense when attempting DYI!
The Following User Says Thank You to NonStopTuning For This Useful Post:
axelo (10-28-2015)
Old 09-29-2015, 06:06 PM   #188
NonStopTuning
Drives: AE86
Who else has new pulley pics?!
Old 10-28-2015, 01:30 PM   #189
NonStopTuning
Drives: AE86
Bump just as a reminder for new customers
Old 10-28-2015, 08:41 PM   #190
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Isn't there a vendor section for this shite.
The Following User Says Thank You to Wayno For This Useful Post:
kch (10-29-2015)
Old 10-28-2015, 08:54 PM   #191
Hawk77FT
Drives: GTS 86
Don't want to burst your bubble but the idler pulleys need to be made of a much harder material otherwise the belt will create a groove in it over time!
Hawk77FT is offline   Reply With Quote
Old 10-29-2015, 12:42 PM   #192
NonStopTuning
Drives: AE86
Thank you for the concern. We have built quite a few of these pulleys and they all seem to be doing fine. We'll be keeping a close eye on them and will update anything if testing shows a real world need to do so. So far, so very good.
For anyone else who may be thinking along the same lines, please note: NonStopTuning has designed and manufactured pulleys like these for over a decade now, has hundreds of pulleys in its catalog of offerings, and has served thousands of customers across the globe. In addition, NST offers a great warranty program and less than once percent of all customers have ever required service.
Thank you all, best of luck with all your projects!
Old 10-31-2015, 05:06 PM   #193
NonStopTuning
Drives: AE86
For anyone interested in some tech info/reading, we've added a couple new pages to the NST website...
NST DYNO TESTING: http://nonstoptuningusa.com/dynos/
NST FREQUENTLY ASKED QUESTIONS: http://nonstoptuningusa.com/faq/
Old 11-01-2015, 03:33 PM   #194
axelo
Drives: Whiteout frs
Thanks for support!!!!
axelo is offline   Reply With Quote
Old 11-02-2015, 11:33 AM   #195
NonStopTuning
Drives: AE86
Those look great
Old 11-06-2015, 04:04 PM   #196
NonStopTuning
Drives: AE86
AST 5200 Dampers Updated 25th Feb DYNO CHARTS ADDED Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 12-17-2015 05:06 AM
NonStopTuning FRS BRZ Pulley Kit Group Buy NonStopTuning Groupbuys 8 05-23-2015 02:27 PM
NonStopTuning 3 piece Pulley Kit - RED harkbrz Canada Classifieds 4 11-01-2014 12:12 PM
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 10:38 PM
Run in method Dyno charts Surok AUSTRALIA 0 10-07-2012 11:29 PM
