Old 09-21-2015, 02:24 PM   #6567
NIKOLA
NIKOLA's Avatar
Drives: 2013 Scion FR-S in Ultramarine
Smudge..... Other than the 335 SC what else did you do? I only went back a page and didn't notice any talk about what you've done. Have you changed the piston heads to a lower compression rating (10:1 or 9:1). Change the rods? Anything changed at the rear end?
Currently driving a Sprintex Supercharged FR-S in Ultramarine with an Invidia N1 Catback with Catless Front Pipe, Invidia Over Pipe, Injen Catless 4:1 EL Headers, Perrin Aluminum Drive Pulley & Driveshaft Shop Aluminum Driveshaft. Also, looking to upgrade wheels someday to Enkei PF01's (17x8's).
NIKOLA is offline   Reply With Quote
Old 09-21-2015, 03:50 PM   #6568
smudge
Drives: Supercharged GT86
Fully forged build using the HKS stroker kit. So that's rods, pistons and crank coupled with the HKS cams too
Not done anything to the driveshafts if that's what you mean by the rear?
smudge is offline   Reply With Quote
Old 09-21-2015, 05:07 PM   #6569
smudge
All here in my progress thread
http://www.ft86club.com/forums/showthread.php?t=94451
Old 09-27-2015, 01:44 PM   #6570
Pekingduck
Drives: 4 wheels
Sprintex at 86fest
Pekingduck is offline   Reply With Quote
Old 10-03-2015, 11:01 AM   #6571
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
What is everyone using for the intercooler coolant? I read in an old post to use Subaru super blue coolant. I would assume this would be used the same for both the BRZ and GT86, just Toyota probably has a different named variant. Is this something I would just grab from the local Subaru dealer?
http://parts.subaru.com/p/Super-Cool...A868V9270.html
Chad86 is offline   Reply With Quote
Old 10-03-2015, 11:58 AM   #6572
stockysnail
Just the tip
stockysnail's Avatar
Yes you'd buy it from a local Subaru dealer or order it online.
Old 10-03-2015, 01:49 PM   #6573
Kodename47
Kodename47's Avatar
Drives: UK GT86
I used the Toyota pink stuff so it's a different colour to what's in the engine. Same quality and lifespan.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-03-2015, 02:02 PM   #6574
Gets a little cranky every few weeks, though.
Old 10-03-2015, 02:45 PM   #6575
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Use a 50/50 mix of distilled water and ethelyne glycol. Premix is fine, too.
Propylene glycol we just don't use. It does not absorb as much heat.
Either type of coolant will work and not harm our system. Ethylene glycol absorbs more heat.
http://www.engineeringtoolbox.com/et...col-d_904.html
SprintexUSA is offline   Reply With Quote
Old 10-11-2015, 11:07 PM   #6576
Chad86
Chad86's Avatar
Drives: Toyota GT86
Arrow
Any specific brand better than others?
Also, I have been reading the forums and cannot find much information on upgrading the MAP sensor. Some say there is a boost limitation on the stock sensor and to upgrade, but this might be refering specifically to turbo, while others say stick with the stock sensor on supercharged applications specifically Sprintex. Lastly, I read a post the other day about there being a break in period for the Sprintex supercharger? This is the first I heard...
@SprintexUSA can you confirm?
I also have seen people using an aftermarket Aluminum Supercharger Suction Pipe. Are there any real benefits to using aluminum piping over the stock plastic tube?
Nameless had a pipe, but it is no longer in production. PREracing also makes one, but I am still waiting to confirm availability.
Old 10-12-2015, 05:53 AM   #6577
smudge
I believe the Nameless one was ceramic coated on the inside as well. When I enquired to if they still made one or if they ever did one for the 335 kit, I got no reply
Simply having the metal intake over the plastic would lead me to think it'd heat up quicker and push hotter air into the intake of the charger, making it less efficient
Old 10-12-2015, 12:25 PM   #6578
tegunulgener
tegunulgener's Avatar
Drives: Dark Side
Hey smudge... How the progress going?
Sent from my HTC One M9 using Tapatalk
tegunulgener is offline   Reply With Quote
Old 10-12-2015, 01:05 PM   #6579
smudge
Slowly 3" catback now ordered but still researching on best manifold, overpipe and front pipe for the setup. Looks like custom may be the way forward
Nearly 1,000 miles done on the new engine and charger
Old 10-12-2015, 01:38 PM   #6580
tegunulgener
Drives: Dark Side
Not full pawa yet then
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
