go_a_way1
Old 09-09-2015, 01:34 PM   #2955
CSG Mike
CSG Mike's Avatar
Originally Posted by LostSalad View Post
Hi @CSG Mike, this is quite the thread you have going here.
I have an 86 with no power mods, but I'm considering upgrading to a BBK. My local track is hard on brakes and I have the budget right now, so I figured I might as well.
I have the option of going with semi-float or full-float discs. As far as I'm concerned, both are probably more than ample performance-wise. I just need to deal with the heat, not necessarily stopping power or braking feel. Therefore my main concern is long-term running costs and street performance because the car is my daily.
So far I am considering going with semi-float, because in my mind less moving parts = less maintenance. Would you agree that this is a good idea? The larger discs are pretty much guaranteed to sort out my heat issues, so I don't need many other benefits from a floating assembly. What's your opinion?
Don't concern yourself whether the system is a semi-float or full-float. Heat dissipation is the real benefit, like you mentioned. Get the largest BBK you can afford that doesn't affect your brake bias, and your heat issues should be greatly reduced.
LostSalad (09-10-2015)
Old 09-17-2015, 12:05 AM   #2956
Jeffsu350
Drives: Frs
I have tried to search, but I've been unsuccessful. I am going to auto club ROVAL on Saturday and just got some 215/45/17 rivals on stock wheels. The rest of the car is 100% stock (minus the W5 pads). Any suggestions for starting cold tire pressure. I'm bringing chalk so I can adjust, but I really have no idea where to start. 30 psi? 32 psi? 28 psi? Thanks
Jeffsu350 is offline   Reply With Quote
Old 09-17-2015, 12:06 AM   #2957
CSG Mike
CSG Mike's Avatar
30 driver side, 28 passenger side.
Cop (09-17-2015), Jeffsu350 (09-17-2015)
Old 09-17-2015, 12:09 AM   #2958
Jeffsu350
Drives: Frs
THANKS! I can't wait to try the new tires and pads. I'll let you know how it goes after this weekend.
Old 09-19-2015, 10:47 PM   #2959
Jeffsu350
Drives: Frs
Thanks again CSG Mike! Had an awesome day at autoclub speedway. The new tires and W5 pads were amazing. I've never felt more confident in my car or my driving.
As always, thanks to counter space garage and mike for all the help and awesome service getting me the right stuff for the track.
The Following User Says Thank You to Jeffsu350 For This Useful Post:
CSG Mike (09-20-2015)
Old 09-21-2015, 11:22 AM   #2960
ShadowTS
Drives: Toyota GT86 SWP
Maximize the camber; bolts will not be able to get you so much camber that it will significantly change your tire wear.
Align any time your steering wheel is not straight. Ideally, have your alignment checked if possible, anytime you spin our or go flying off track sideways. Keep an eye on yuor tire wear, and if you notice unusual wear, have your alignment checked.
Hi Mike,
I had my car aligned. I've suggested the mechanic to maximize the front camber, and set 0 toe front, and a little toe in back (0.05° - 0.1° each tire).
I forgot to tell the shop to measure the stock setup. They have first installed the camber bolts and than measured the setup, therefore I don't know the real values before alignment. However, after camber bolts installation, the values where: about -0.1° front toe total (toe out), about +0.1° back toe total, front camber like -0.1° each tire, rear camber -0.8° left and -1.3° right (I've noticed this strange pattern - right rear tire with more camber than left rear - on most values read on this forum). After the alignment I have the requested values: front camber is now -1.4° on each tire, front toe is perfect 0, rear toe is +0.07° on each tire.
My issue is: now the front of my car feels much lighter then before. The steering wheel is a lot lighter, and also it feels like the first inch of steering wheel movement is less sensible. I have to say that my tires are over-inflated, I inflated my AD08R (215/45 R17) at 2.7 bar at the beginning of the summer season (for street fuel economy, and also because the weight of the steering wheel increased a lot from the winter tires to the AD08R), however the pressure has not been changed with the alignment, and before the alignment the weight of the front and the steering wheel was very good.
Is it due to the change in camber, or maybe the cause is the change in front toe? What can I do, considering I've not the correct values of the toe before the alignment?
ShadowTS is offline   Reply With Quote
Old 09-21-2015, 01:49 PM   #2961
CSG Mike
CSG Mike's Avatar
Originally Posted by ShadowTS View Post
Hi Mike,
The steering is lighter because you're getting less wasted "scrub". This is a good thing, usually.
A good alignment shop will always set your tire pressures before doing any other work.
Old 10-01-2015, 06:30 AM   #2962
RandomDeception
Drives: Stock FR-S
How long can the stock car be continuously pushed near the limit with respect to the engine and cooling? Maybe for around half an hour at 200 kilometres per hour (over 120 miles per hour)?
Brakes and tires would not a part of the equation in this case.
RandomDeception is offline   Reply With Quote
Old 10-01-2015, 08:45 AM   #2963
jvincent
jvincent's Avatar
In what gear? RPMs are what matter for heat so if you're doing that speed in 6th it will be better than in 5th. I think that 200 is reachable in 5th.
The Following User Says Thank You to jvincent For This Useful Post:
RandomDeception (10-01-2015)
Old 10-01-2015, 11:16 AM   #2964
Pat
Pat's Avatar
Drives: 2023 BRZ
I have to think the car is capable of doing 120 mph indefinitely without cooling issues. I don't know this for sure, but I'd be surprised if engineers didn't design and test the car to do this. 120 for a modern sports car isn't all that fast. I'm looking forward to what other more experienced people have to say about it, though. It is an interesting question.
The Following User Says Thank You to Pat For This Useful Post:
Old 10-01-2015, 11:44 AM   #2965
CSG Mike
CSG Mike's Avatar
Without an oil cooler? Maybe a minute before oil temps go crazy. Try watching oil temps at 3rd gear at 70mph.
With an oil cooler? Forever as far as engine and oil temps go.
Old 10-01-2015, 12:49 PM   #2966
Pat
Pat's Avatar
Drives: 2023 BRZ
So what do you think happens to the car when the "temps go crazy"? Would the average driver even know anything is different/not right? Do you think the engine would blow up or something?
Old 10-01-2015, 01:02 PM   #2967
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I can't imagine a problem running steady at 120. Ask a German.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 10-01-2015, 01:14 PM   #2968
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
The OEM oil cooler conversion seems pretty enticing. Would you recommend skipping that option and going with an aftermarket oil cooler setup, if the car will see occasional track use?
LOLS2K is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
