Old 09-19-2015, 09:30 PM   #225
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Bramick View Post
Full stiff is clockwise till it won't turn anymore?
yes
Old 09-19-2015, 10:27 PM   #226
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
So day one of my track day went well. I ran 3 clicks all around. 1/10th toe in front and 0 rear. Front camber was -2.5 and I'm not sure where the rear ended up. My rear LCAs arrive in 1-2 months then I'll get tge car corner balanced.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 09-20-2015, 12:34 PM   #227
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Originally Posted by racecarshots View Post
Curious what you mean by this? 98% of my driving is freeways and boring stuff, but when I do hit the mountain roads I want something to work really well. If these aren't good for uneven mountain roads I'll stay stock haha.
I have those and do a lot of mountain "rally" style driving on road here in south France around my house. Many road from French Chamionship of rally just out from my gateway.
For that I will definitely not recommend those. Not enough travel plus when you cut curves put two will outside of the road you touch under the car because car is too low. I don't understand how you can use that car with 1" drop???
I think with 1" drop it's a track dedicate car but noway Tarmac rally style driving.
1" drop it's even get boring on every day drive as you have to slow down so much on speed bump road connection were as with Oem set up you can pass without slowing down.
I will go back to OEM set up in the next days because on the tarmac rally stage next to me I'm at least 2 second slower with those Flex Z than I was with OEM set up.
Mars2 is offline   Reply With Quote
Old 09-20-2015, 01:35 PM   #228
ajc209
Drives: GT86 Cosworth
Sounds like the Flex A might suit you better.
Sent from my GT-I9300 using Tapatalk
ajc209 is offline   Reply With Quote
Old 09-21-2015, 06:19 AM   #229
churchx
churchx's Avatar
Drives: 2014 GT86
ajc: You think so? I was under impression, that Flex A = Flex Z + hydraulic bump stop + rebuildability.
Old 09-21-2015, 06:20 AM   #230
ajc209
To be honest I dont know what the similarities are between the two. Best to ask Tein, but the HBS should help keep the car stable on really rought surfaces.
Old 09-21-2015, 06:43 AM   #231
churchx
churchx's Avatar
Drives: 2014 GT86
I was more thinking along the lines, that it's possible that travel / height adjustment range might be similar for A as for Z, so it's possible that A not being best alternative to suggest of, if Zs didn't do it.
Old 09-21-2015, 06:56 AM   #232
ajc209
You might be right. I'm not sure what is avaliable in that price range with more bump travel?
I know a chap in sweden that has the same problem with bump travel on rough surfaces.
On side note @Mars2
The front dampers do benefit from a bit more spring rate on rougher surfaces becuase they have a bit too much rebound.
Old 09-21-2015, 09:00 AM   #233
bfrank1972
Drives: 2013 FR-S Argento
Tein Flex Z opinion
On side note @Mars2
Guys with bump travel issues, how is your preload set? If you want more bump travel vs. rebound, you can increase your preload to achieve that effect.
Old 09-21-2015, 10:54 AM   #234
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Hey all, just installed these yesterday. Have yet to get an alignment so I am assuming this is part of the problem.
Have the coils set to full stiffness, and before I installed I snugged up the preload, but these things still feel floaty as hell. Defs not as solid as I had hoped. Maybe my expectations were just too high.
BDotG is offline   Reply With Quote
Old 09-21-2015, 11:25 AM   #235
Shady195
Drives: '13 10 Series FRS #1203
Define "Floaty" because on full stiffness the car is far from floaty. Is it like riding a brick? No, not really, it's pretty stiff but not 3 wheeling over over a pebble stiff.
Keep in mind, "Stiff" does not mean good, it gives the illusion of "performance" and feels like the cars on rails, however generally far from the case. A lot of people are used to the "my car is stiff as fuck" feeling from cheap coil overs and misconceptions that stiff is better.
Shady195 is offline   Reply With Quote
Old 09-21-2015, 11:32 AM   #236
BDotG
BDotG's Avatar
Okay that makes sense. This is my first set of coilovers on any car ever so maybe I was just used to the feeling of shitty coils in my friends cars.
I think for me it just seems like full stiff doesnt feel harsh. Maybe our roads are just decent here. Gonna play around with the settings tonight and see how less clicks from stiff feels.
Old 09-21-2015, 12:58 PM   #237
CSG Mike
CSG Mike's Avatar
You need a rally specific type setup that will *raise* your car quite a bit, if you plan on doing rally type driving.
CSG Mike is online now   Reply With Quote
Old 09-21-2015, 12:59 PM   #238
CSG Mike
CSG Mike's Avatar
Start from 8 clicks, and work your way up. Search out a bumpy road to use as your test loop.
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
