Old 09-19-2015, 05:39 PM   #11929
c4lvinnn
Drives: Toyobaruion
washed it
c4lvinnn is offline   Reply With Quote
Old 09-19-2015, 11:37 PM   #11930
humdizzle
Drives: 2018 GT3 / 2015 M3
throwing these on tomorrow.
still waiting on my winjets to show up from fteightysix ( i guess they ship seperately?) and my trd rep spoiler from ft86speedfactory... then round 1 of mods will be done.
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
The Following 2 Users Say Thank You to humdizzle For This Useful Post:
OrangeGuitar (09-19-2015), thien (09-19-2015)
Old 09-20-2015, 03:18 PM   #11931
sachu
Drives: rocketship
Originally Posted by Johnny. View Post
Got new wheels and tires put on today.
nice!! just installed mine today. Been sitting in the garage for 4 months now :P
Also put on new project Mu 800HC+ pads and type 200 brake fluid.
17x9 +35 wheels
245/45 RE71R tires.
thanks @Decay107 for the help!
sachu is offline   Reply With Quote
Old 09-20-2015, 04:55 PM   #11932
Vroomin86
Drives: 2015 Fire
Originally Posted by Terran View Post
Thanks. They are TRD side skirts
they flow beautifully with the rest .. legg sport spoiler? what roof spoiler is that? I been looking to get one forever now but only one I can find is a HIC on ebay
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 09-20-2015, 08:19 PM   #11933
Parappa
Parappa's Avatar
Drives: Scion FR-S White Out
Found a great looking baby seat that matched and fit nicely in the car at Walmart for $99 cdn.Name:  ImageUploadedByTapatalk1442794781.241652.jpg
Size:  276.5 KBName:  ImageUploadedByTapatalk1442794793.245321.jpg
Size:  276.9 KBName:  ImageUploadedByTapatalk1442794804.100338.jpg
Parappa is offline   Reply With Quote
The Following 2 Users Say Thank You to Parappa For This Useful Post:
Lorico (09-20-2015), Vroomin86 (09-21-2015)
Old 09-20-2015, 09:11 PM   #11934
Parappa
Parappa's Avatar
Nice looking wheels!
The Following User Says Thank You to Parappa For This Useful Post:
Johnny. (09-21-2015)
Old 09-20-2015, 09:12 PM   #11935
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
Thank you. It's a VIS AMS cf one piece trunk. The roof spoiler is the HIC one. TBH I wish there were better choices, as I like the HIC at only some angles. I wanted the beatsonic one, but it's too expensive.
Terran is offline   Reply With Quote
Old 09-21-2015, 12:43 AM   #11936
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I just finished installing these items this afternoon...
What a difference they make! The Perrin engine mounts and transmission support really changed how the car handles - really makes the ride quality better and the handling is much more precise and immediate. I was going to start with the mounts on Friday, but I was reading about melting issues with them in certain applications and wanted to put a heat shield on them.... used DEI header wrap wrapped twice around the mount as an insulator with outer layer of aluminum tape for a reflective barrier since I wanted to do the install this weekend.
The CAE Ultra shifter is simply a phenominal shifter...takes some work to replace the factory setup with it though, mainly modification of the center console, removal of the stock top shifter mechanism assembly, and fitment of the pin on the transmission shaft into the shifter hole...fitment is so tight and precise you have to have or create a tool to compress fit it in, a micro hydraulic press would have been nice! My first clue to the tight fit should have been the spacers that come with it seem too small for the pin size until it was apparent the tolerances were extremely tight and you had to perfectly align them to get them on and even then it wasn't a slide on easy thing - though able to be done by hand it takes some real effort to slide them on. In the end all the work is totally worth it though, the insanely tight tolerances and shifter design give amazing shifting with absolutely ZERO play and extremely defined and felt gear engagement. Absolute heaven...
The combination of the mounts and shifter has further sharpen the driving experience of the 86 again...Love it! The sound when getting on it at high RPMS....wow....such racecar mechanical noise!
I'll get some installed pictures once it's daylight...center console is still not in it's final configuration yet though...still more work needed to get it how I really want it to properly showcase the CAE Ultra shifter.
Edit: Was not light enough when i got home, but here's an installed picture:
Still not finished, the center console will be further modded with better and more contoured cuts along with the shifter ring contoured and worked over to match and a reverse orientation boot installed to show off the base yet fully hide the interior of the console. Console will also be covered in perforated Alcantara and have protected functional buttons in the seat heater switch location for true traction control shutoff and ABS shutoff (labeled "RACE" and "-ABS" respectively).
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 6 Users Say Thank You to Vracer111 For This Useful Post:
blue cat (09-24-2015), daftpunk (09-21-2015), Figo (09-21-2015), GT86_PRAGUE (09-25-2015), Manic (09-22-2015), MJones_RB (09-23-2015)
Old 09-21-2015, 09:18 AM   #11937
humdizzle
i just did the duct tape mod to the window switches.. my life has changed. This thing BUMPS now!
Old 09-21-2015, 10:15 PM   #11938
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
Picked up a set of 5zigen fn01rc's today off craigslist. 17x8 +35 offset titanium bronze, came installed with Kumho V710 track tires for $300
Then came home to see my ft86sf order had arrived. Oil change products and Whiteline crossmember bushings. This weekend should be fun
JonAvalon is offline   Reply With Quote
The Following 2 Users Say Thank You to JonAvalon For This Useful Post:
calmtigers (09-22-2015), MJones_RB (09-23-2015)
Old 09-22-2015, 12:35 AM   #11939
humdizzle
removed emblems and put toyota badges on
toms tails
2018 GT3 6MT
2021 M2 Comp DCT
The Following 7 Users Say Thank You to humdizzle For This Useful Post:
86geek (09-22-2015), Diode Dynamics (09-23-2015), JonAvalon (09-22-2015), Josue Cafe FR-S (09-24-2015), Pbrown (09-23-2015), rjsf (09-23-2015), WhiteFRS69 (09-22-2015)
Old 09-22-2015, 07:37 PM   #11940
AlexL
AlexL's Avatar
Drives: '13 Whiteout Scion FRS
toms tails
Clean garage, literally and figuratively!!
AlexL is offline   Reply With Quote
The Following User Says Thank You to AlexL For This Useful Post:
humdizzle (09-22-2015)
Old 09-22-2015, 08:44 PM   #11941
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
explain...
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-22-2015, 08:46 PM   #11942
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Originally Posted by calmtigers View Post
explain...
Yeah I was wondering wtf that was as well haha
Sent from my SAMSUNG-SM-G925A using Tapatalk
fatalelement is offline   Reply With Quote
