go_a_way1
Old 09-19-2015, 02:23 AM   #9479
TM
TM's Avatar
Drives: DGM BRZ 6MT
I may have broke my phantom ESC. My battery was dead so I went to jump my car. Little did I know, my car was in the On mode. I have the push to start button and didn't know it works that way. I clicked it a couple of times before I came to the conclusion it was dead and didn't realize it can technically still be On.
Anyway, as soon as I hooked up the jumper cables to my car battery, all the electronics turned on, including the ESC, and the compressor started spinning (thanks to the procede map). I hopped into my car as quickly as possible to turn off the ESC, but it may be too late. I was driving around for an hour afterwards and couldn't get it to work again. The voltmeter is on and reads 28.x. The procede software still reads the RPMs and throttle position. But no series of beeps when the ESC is turned on. No boost or voltage drops when I step on the pedal.
I hope it's just the thermal fail safe and that it'll be back to normal in a little bit. I'll check again tomorrow, which kind of sucks, since I'll be going on a drive with the norcal guys tomorrow morning.
TM is offline   Reply With Quote
The Following 2 Users Say Thank You to TM For This Useful Post:
raven1231 (09-19-2015), zc06_kisstherain (09-19-2015)
Old 09-19-2015, 11:23 AM   #9480
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
yoohoo!!! finally i am on next batch..
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
DAEMANO (09-19-2015), Sojhinn (09-19-2015)
Old 09-19-2015, 11:39 AM   #9481
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Any luck this morning? You may need to double check your connections as they may be grounding out. Double check the connections from the controller to the battery and the connections from the controller to the motor.
Installed Mods:
Old 09-19-2015, 09:23 PM   #9482
TM
TM's Avatar
Drives: DGM BRZ 6MT
Full throttle Electric Supercharger Build Thread
Negative. I'm going to shoot rob a pm when I get home.
Old 09-19-2015, 09:23 PM   #9483
TM
TM's Avatar
Drives: DGM BRZ 6MT
Double post
Old 09-19-2015, 09:30 PM   #9484
DAEMANO
Time Traveller
Send him an email
Old 09-19-2015, 10:52 PM   #9485
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by DAEMANO View Post
Send him an email
Haha, oops, that's what I meant. Rob has always gotten back to me within a couple of hours or the next morning whenever it comes to support.
The Following User Says Thank You to TM For This Useful Post:
DAEMANO (09-20-2015)
Old 09-20-2015, 12:34 AM   #9486
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I've jump-started my car 7 or 8 times already, and haven't had the slightest problem. My OFT keeps draining my starter battery whenever I forget to switch off my OBD2 extension cable with power switch. Fortunately it has only happened at home, where I have one of those rechargeable power-pack, jump-starter, air-pump things. It sits on the shelf for years and now I'm using it every week. I'm thinking about using some kind of high amperage relay or contactor to switch in one of the ESC batteries to help start the car. It has always started when I switched off the OFT though, so maybe I just need to replace that OBD2 power switch with a relay, so it turns off automatically whenever I shut off the car.
KoolBRZ is offline   Reply With Quote
Old 09-20-2015, 02:07 AM   #9487
TM
TM's Avatar
Drives: DGM BRZ 6MT
This is about the 10-20th time I jumped my car. Bad battery, street parking and I only drive it once every couple of weeks now. I have the new odyssey starter battery, but didn't install it yet because I don't drive that often anymore. Just make sure you're car is not on the On mode when you jump it, or at least the ESC switch is not on.
Edit: I leave my stock battery in the trunk and use that to jump my powersonic battery every time.
Old 09-20-2015, 03:36 PM   #9488
KoolBRZ
KoolBRZ's Avatar
Word to the wise, don't jump battery when ignition is on
I have the Odyssey battery, and don't have any problems starting when I remember to turn off the OBD2 switch. That OFT really uses a lot of power when the car is off. Even full-sized batteries have been drawn down too low to start the car. I wish the OFT had a Aux power tap to automatically shut it off when the car is off, and a coin-sized battery to remember your settings when it was off. Maybe those can be new features in the OFT2. I would also like to see the OFT and PROcede throttle controller combined into one unit. Does anyone know of an OBD2 extension cable with a relay-controlled power switch?
Old 09-20-2015, 03:59 PM   #9489
KoolBRZ
KoolBRZ's Avatar
I've just sent a message to the ebay seller who sells the OBD2 extension cable with switch. I asked if they could make an auto-switching extension cable for people like me who forget to turn off their OBD2 switch and draining their battery. I'll post links if they are able to produce such a cable.
Old 09-20-2015, 11:18 PM   #9490
zc06_kisstherain
Drives: SWP BRZ
do you need to connect OFT all the time? can you just disconnect it when car shuts off?
Old 09-21-2015, 12:02 AM   #9491
KoolBRZ
KoolBRZ's Avatar
Yes, I do need it connected all the time
I actively tune with my OFT and need to watch things like IAM, AFR, and Boost. The trouble I'm having is that I can leave it on during daily trips when I don't leave the car for more than 2 - 3 hours, so I set it to show what I want to see and leave it. When I park it at the end of the day, however, I need to remember to switch off the OBD2 extension cable's switch, or disconnect the OFT or I have to jump-start it in the morning.
The real problem is I don't have to disconnect the OFT every time I shut off my car, only when I leave it off overnight.
Old 09-21-2015, 01:04 PM   #9492
mythhelios1
Drives: Scion FRS
Is there any tune for EL or stock manifold ? As I plan to buy an EL header but I didnt see any tune for it other than the tune for OFH
mythhelios1 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
