Old 09-17-2015, 10:03 PM   #29
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by CBrown_BRZ View Post
I found the easiest way to install a rear backup camera in a Subaru BRZ cheap and w/o having to drill any holes is:
1) Buy the following camera (you do not need one with lights for nighttime):
http://www.happyshoppinglife.com/car...on-p-2307.html
2) Buy the following wiring harness:
http://www.autoharnesshouse.com/19867.html
3) Learn how to remove the radio/navigation unit:
4) Remove the factory license plate light cover.
5) Install the new license plate light cover w/ the camera.
6) Remove the radio/navigation unit and remove the 10 and 16 pin connectors. Plug in the new harness 10 and 16 pin connectors in to the back of the unit. Plug the original 16 pin connector into the new harness. Note: the original 10 pin connector is no longer needed and can just rest inside the cavity.
7) Plug the camera RCA jack in to the harness and connect the red wire from the video cable to the 12v connector on the harness.
8) Run the cable to the rear of the car and connect the video RCA cable to the camera and the red 12v wire to the camera. Connect the ground wire to the nearest ground. (You can always run the cable through the center of the car first to test.)
9) Turn the car on and put the car in reverse, you should see the rearview camera image on the screen.
10) Adjust the grid lines on the navigation unit: http://ae64.com/Rear-camera-install-16p-FT.htm
Total cost was under $50.00 and 30 to 60 minutes of your time.
Good luck!
Wait so what does this looks like on car? O.o
mind share a picture?
Old 09-18-2015, 11:43 AM   #30
CBrown_BRZ
Drives: 2015 Subaru BRZ
Photo of camera installed.
Here is a closeup of the camera. Kinda hard to see otherwise because of the color of the car.
CBrown_BRZ is offline   Reply With Quote
Old 09-18-2015, 01:15 PM   #31
bass_114
bass_114's Avatar
Drives: wrb brz
6) Remove the radio/navigation unit and remove the 10 and 16 pin connectors. Plug in the new harness 10 and 16 pin connectors in to the back of the unit. Plug the original 10 pin connector into the new harness. Note: the original 16 pin connector is no longer needed and can just rest inside the cavity.
Good luck!
Does the license plate light still remain functional with that camera mount? And where/how did you tap in for the power to the camera?
bass_114 is offline   Reply With Quote
Old 09-18-2015, 02:04 PM   #32
CBrown_BRZ
Yes the light still works. The wiring harness that attaches to the back of the navigation system has a 6v to 12v relay that connects along with the RCA cable.
Old 09-18-2015, 02:21 PM   #33
CBrown_BRZ
One bad thing is both the camera and the navigation unit display their own grid lines and you can not turn them off but you can get them lined up close to each other.
Old 09-18-2015, 02:32 PM   #34
kch
Senior Misanthrope
kch's Avatar
Not to derail, but wtf is that site? "HAPPY SHOPPING LIFE! CREDIT THE WORLD FORWARD THE GLOBAL"
That's the best engrish I've seen in ages.
The Following User Says Thank You to kch For This Useful Post:
chaoskaze (08-24-2016)
Old 09-19-2015, 03:37 PM   #35
CBrown_BRZ
Here are 2 more pictures from the back and navigation unit.
The Following 2 Users Say Thank You to CBrown_BRZ For This Useful Post:
chaoskaze (09-21-2015), TheBRZsKnees (10-12-2017)
Old 09-20-2015, 12:30 PM   #36
Papi
Drives: Crystal White Silica BRZ Limited
DaJo
You said you have the Subaru BRZ camera. Do you have a part number, where did you buy it? Pictures please
Papi is offline   Reply With Quote
Old 09-21-2015, 03:13 AM   #37
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Thanks that looked really nice
Originally Posted by Papi View Post
DaJo
I don't know which one he get, but if you wanna get oem oem japan rearview camera, you can actually find it on japanparts under BRZ/Others
Old 06-08-2016, 04:30 PM   #38
MrBackhand
Drives: 2014 BRZ Limited
2014 BRZ checking in. Followed the guide from CBrown_BRZ and it worked great!
Thanks!
MrBackhand is offline   Reply With Quote
Old 08-23-2016, 11:54 PM   #39
86Wrath
Drives: 2013Subaru BRZ2.0LimitedWRBluePearl
Hello all I'm trying to decide of what backup camera system to get, I was just wondering if there are any new options that haven't been noted. I'm looking for some thing to look oem and I want to have a front camera as well if any one has installed one on their brz.
86Wrath is offline   Reply With Quote
Old 08-24-2016, 03:24 AM   #40
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Make sure you don't get the one from emeraldintegrations, (the oem style expensive one) unless you like getting trick by their ads & stair @ rear bumper.
Old 08-25-2016, 09:40 PM   #41
86Wrath
Ok so no emeraldintegrations any thing else that wasn't mentioned before?
Old 08-26-2016, 10:14 AM   #42
tobin
tobin's Avatar
Drives: '13 BRZ
Quick question...does the nav screen need to be on for the rearview image to be displayed? In other words, does the reverse signal trigger the screen to turn on? I usually keep mine turned off.
tobin is offline   Reply With Quote
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 02:18 PM
one more car list... Axel Off-Topic Lounge [WARNING: NO POLITICS] 20 12-18-2013 07:17 AM
Interior wish list.... FRiSson Scion FR-S / Toyota 86 GT86 General Forum 0 07-18-2012 08:57 PM
$500 Deposit = First on List IntenseDVDA BRZ First-Gen (2012+) — General Topics 373 02-21-2012 05:44 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 11:21 PM
